A temporary solution is to remove all frozen food, ice tray,shelf and bottom plate. you will see the water drain trench and a drain hole in the back center of the freezer. Unplug the drain, free it from ice or debris and flush with hot water. I have the same problem with my frig. This is not a permeant fix, but it will stop water from dripping through the vent ports The defroster may be defective or the air flow is too restricted. Good luck.
What's happening is when the fridge goes into defrost water goes thru the drain and is seeping into the crack by the damper which will run into the fridge section. Why? The drain doesn't come down far enough for all the water to go down the drain tube. Frigidaire has a new drain that is longer and will prevent this problem.
