Question about Samsung Refrigerators
Hi ,my fridge side of my samsung side by side is over cooling it is showing 4 degrees on the display but the water cooler inside has frozen up and the motor seems to running continuosly is the thermostat defective
  • 29 Answers
Try to unplug the wall outlet for 1 minute and then plug it back up.
Posted on Jan 02, 2011
Fridge warm, Freezer OK
You will find very good info HERE.
Good Luck.
Mar 03, 2008 | Samsung RS2578BB Side by Side Refrigerator
Samsung SRS583HDP fridge not cooling. Side by side
Most likely the thermostat in the fridge, especially if it read 5 degrees until you reset it. Possibly the compressor in the fridge side as this fridge has twin cooling, or the circulating fan in the back of the fridge is frozen, which is a common problem as well.
Easiest things to try is to see if the fan is frozen and check if the fridge cooling is actually working. Turn off the fridge, remove the shelves, remove the 4 screws that hold in the bottom cover and the 2 screws that hold the water tank in. Cover should then come out a few inches. Reach behind and unplug the 2 plugs and pull out the cover. If the cover doesnt come out easily it may be glued to the back of the fridge by ice. Leave for a couple of hours and gently prize it off. Check for ice around the fan and that the fan spins freely. You could try sitting the cover inside the fridge, plug it in turn it back on for a few minutes (be careful) and then open the door and quickly look / listen to see if the fan is still spinning (it stops when you open the door). Leave the fridge off for a while until the ice disappears off the coils. Turn back on for half an hour. The coils should be icy again. Anything else call Samsung. If the deal in your country is the same as mine the fridge has a 2 year warranty but in the fine print the sealed compressor unit has five years on parts only. You could get the unit replaced for labour costs only. Check your warranty card.
Jun 22, 2010 | Samsung Refrigerators
Not getting cool water from dispenser in door
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Samsung RS2534 Side by Side Refrigerator
Samsung fridge RS27KASW not cooling
whats happening is that the refrigerator side appears to be frozen up. what hte controller is doing it's showing yopu the actual temperature inside take everything out og ]=f the refrigerator and thaw i out. then don't pack the frig so that the air can circuate around the food real good.
Mar 06, 2009 | Samsung RS265LBWP 21.6 Cu. Ft. Side by...
Samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Dec 20, 2008 | Samsung RS2534 Side by Side Refrigerator
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Dec 01, 2008 | Samsung 26.0 Cu. Ft. Side-by-Side...
Water dispenser not working
I am currently experiencing the same problem. It happen when I pressed the rapid cool button on the inside of the fridge and the temperature went down to 36 degree F. I assume that my water line is frozen. As soon as we use up some of the food in the fridge, I'm going to clean out the fridge and let the temperature rise, hopefully thawing the blockage. This is the only thing that I can think of.
Mar 25, 2008 | Refrigerators
Refrigerators Logo
49 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
