Question about LG Televison & Video
My tv does not respond when i put memory stick.i have tried to follow a procedure of first pressing OK at the same time on both the tv and remote but nothing was showing on the screen
What is the capacity of the memory stick you are trying to use? How old is the tv? have you tried with a different memory stick?
Posted on Jan 02, 2011
Not remote control but remote code for a celcus tv
Just try a code search method. If your remote control have programmed in codes for your TV, it will respond. If not, make sure that the remote you have no code for your device, and it can't be setup with it.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jun 21, 2012 | Televison & Video
Tip
How to program your Dish Network remote to your tv
Find your Codes for your devices here first: http://www.dishnetwork.com/customerService/troubleshooting/nhagent/default.aspx
The follow these directions:
OK, I understand that you need help programming your remote control to a TV or other equipment.
Note: After this procedure is started, if a button is not pressed within 20 seconds, the remote will end the procedure automatically. Simply start over again.
Step-by-Step Procedure // Step 1 of 6
Click on the following link to find the remote codes for your brand of TV, VCR, or other equipment. Note that codes for each TV brand depend on the remote type.
Step 2 of 6
Press and hold the correct Mode (TV, VCR, or AUX) button for about six seconds until all mode button backlights come on, then release.
Step 3 of 6
Use the number buttons to enter the three digit number (four digit for AUX mode) corresponding to the equipment. The light will blink off after each digit is entered and then return to a steady light.
For AUX mode ONLY: press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device.
Step 4 of 6
Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Step 5 of 6
To verify the code works, press the mode button. Try several different functions for that equipment. Some codes may provide partial function, or respond differently than the button's titled function. Try the other codes listed for that device until you find one that offers more complete functionality.
Step 6 of 6
If the remote still does not operate the device, perform the Power Scan.
If the remote still doesn't operate equipment, it may not be compatible with that equipment.
on Dec 02, 2009 | Televison & Video
I have a citizen television & the code is not in the list to program the remote, i can't get the remote to do anything. Is there a code for a citizen tv?
Hello
Try a code search method. Sometimes it may halp you.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
OK.
Jul 23, 2011 | Sony RMEZ4 Remote Control
No codes for sony t.v.
Hello
Check with these codes. There are no codes specified with this remote manual. Try these.
Three digit universal remote codes for Sony TV are:
002/ 006/ 071/ 128
Four digit universal remote codes for Sony TV are:
0128 0013 0002 0071 0380 0000
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
OK.
Jun 19, 2011 | One For All URC-4605 Remote Control
HI i bought live wiretv remote wanted to know about code for tv my tv is alba make
Hello
Alba TV is not listed with the remone control you bought. You may try a code search process, which is decribed in its manual, to find for a code stored in the code library of the remote control. You can try this way also:
OK.
May 05, 2011 | One For All URC-3021 Remote Control
Need universal remote code.
Hello
Three digit universal remote codes for konka are:
016/ 047/ 066/ 157/ 158/ 176
Four digit universal remote codes for Konka are:
0053 0011 0016 0047 0066 0103 0412 0413 0029
Direct Code Entry
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Mar 25, 2011 | Konka K2038U TV
Does anyone know the Comcast Remote code for NEC LCD-4020-2-av?
hi,
Try the following code for your TV.
0030, 0056, 0497
1.Turn on the TV.
2.On the remote control, press a device key once ( TV).
3. Press and hold Setup until the selected mode key blinks twice, then release Setup.
4. enter any one of the code listed. If you perform this procedure correctly, the selected mode key will blink twice.
5. Aim the remote control at your device and press Power once.The device should turn off. If it does not respond, repeat steps 2 to 6, trying each code listed
ok
Feb 20, 2011 | NEC MultiSync LCD40202AV 40 in. LCD TV
Need to find code for Jumbo Universal Remote to use with Aiwa S2011 MTS television. Thanks for any help!
Hello
Aiwa TV is not lited on Jumbo Universal Remote codes. Anyway try out with these codes. Sometimes may help you.
Three digit codes for Aiwa TV with universal remote are:
195/ 196
Four digit codes for Aiwa TV with universal remote are:
0195 0196 0227 0269
Direct Code Entry
NOTE: Switch OFF and switch ON your TV with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
OK
Jan 27, 2011 | Aiwa TV-S2011 20"
Universal remote need a code ? or a remote
Hello
Universal remote code for Prima TV are :-
1019 0165 0116 0167
Direct Code Entry
OK
Jan 19, 2011 | Prima C2012 TV
Where can I find a book on the different UVerse Remot tv codes for a new tv?
Hello
Universal remote code for Panasonic TV/VCR/DVD combo is
0437
Direct Code Entry
OK.
Dec 19, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
Televison & Video Logo
Computer Repairing
Computer Repairing
