Code erreur 800a 1391 - Computers & Internet
My pt cruiser has code 1391. i changed cam sensor crank sensor wires plugs and coil still getting 1391 code and from 0 mph to 20 mph car skips and revs up any ideas?
The cam and crank sensors have the same power wire. Go after that one. They also have the same ground, but other sensors connect to it also. So it's not the ground. And they have separate return signal wires. Not them either.
Mar 09, 2015 | 2001 Chrysler PT Cruiser
Code p1391
You could've gotten dirt or grease inside the cam sensor connection. They are real fussy.
Jun 07, 2017 | 2000 Dodge Ram 1500 Truck
Have 97 dakota v6 i keep replacing 1391 andpo351 plugs and wires
Not sure I am following your story.
Code 351 is a problem with the primary OR secondary circuit for the coil.
Code 1391 is a problem with the ABS system.
Dec 21, 2012 | 1999 Dodge Intrepid
What is code 1391 for on 1999 jeep grand cherokee
Code 1391 = An intermittant loss of CMP (crankshaft position sensor) or CKP (crankshaft position sensor. This code could be related to just a bad connection at either sensor or the wiring harness, check the connections and be sure they are clean and tight fitting with no loose wire connections also within the connector itself. Otherwise you may end up replacing one or both of theses sensors to correct this issue,unless you have an oscilloscope to isolate which sensor.
Jul 16, 2010 | 1999 Jeep Grand Cherokee
I'm looking for the engine codes for a dodge intrepid codes are 1391 - 0134 - 1684.... I am trying to replace the oxygen sensors...how do you know which ones to replace?
1391 is a timing code cam or crank sensor
0134 bank 1 sensor 1 usually left front but double check
1684 doesn't match anything i know
Jan 30, 2010 | 1999 Dodge Intrepid
Coad 1391
The code 1391 is : Intermittent loss of CMP or CKP
You are losing either the cam or crank sensor intermittently. Test and replace as needed. Check plug ends first.
Jan 12, 2010 | 2000 Dodge Dakota Quad Cab
Code 0700 with 1391 stand to what
P0700 its a transmission codefrom what i understand while the 1391 is a crank postion sensor. the P0700 comes up when the neutral safety switch starts to fail, but the crank postion sensor...to get that error code, means you timing could be off..have you replaced a timing belt lately, if so, it might be a couple of teeth out, that might do it. i would check the sensor too though
Jul 11, 2009 | 2002 Jeep Liberty
Engine keeps missing. unknown codes
Code 1682 indicates low battery voltage. This could be a problematic alternator, which would likely cause misfiring. Autozone should be able to check this for you for free.
Code 1391 indicates the computer can not see the crank or cam sensor signal. This would likely be a result of the misfires.
Code 0320 indicates the crankshaft position sensor reference signal could not be found while the engine is cranking.
All of these issues point to either a cam/crank sensor malfunction or a charging system problem, either or both of which could cause the misfiring.
May 09, 2009 | 1998 Jeep Wrangler
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
