Question about Belkin (F5D7230-4) Router (587009)
Having trouble mapping a drive for the magicjack to use. So I just plugged it in and the drives appeared but I get a Windows message "Safely remove USB Mass Device Drives (K:,J:)" my magicjack will not install properly and I tried to uninstall (I follow manual instructions to uninstall) and the computer wanted me to remove all my extra mapped drives and won't let me map new ones. What should I do it is driving me crazy?
  • 4,281 Answers
When you power up the computer press F8 key then enter in safe mode.
Then go to device manager and uninstall all usb drivers then check.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Posted on Jan 02, 2011
Testimonial: "Thanks - tried it and it clean up the problem but when I reinstalled my magicjack again it happened again I'm going to post another question. "
Windows xp sp3 stop error message 7e usb
Why not just pull it out instead of clicking on safely remove hardware? Try it and see if it works. Sounds like your usb drive is not windows 7 compatible. Or windows 7 has some driver issue which is not uncommon.
Jun 04, 2012 | Hitachi 1TB LifeStudio 35 Desk Plus...
PNY flash drive will not eject
right click in the bottom toolbar select task manager to see whats runnng in applications also in processes to see whats ticking over
it might be your antivrus or another program thats runing
also
try right clicking on it windows explorer select eject
also you might have to resore it to default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
hope this helps you
Apr 17, 2012 | PNY Electronics - Others
Will not recognize drive
cashekian
If the drive is not being detected this is a sign that ether you just need to map the drive or that there is a problem with the drive encloser.
These links will help you map the drive letter to the drive. Also you might try the drive on another computer so times the the drive will not get safely removed and the drive state needs to be reset.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
If you still have trouble with the drive you may need to look at replacing the encloser for the drive or connect the drive directly to your computer. If you know the drive is working and you want to replace the encloser the link below will have the encloser that will work with your drive.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Aug 22, 2011 | SimpleTech SimpleDrive...
I did not install the software of WM "My Passport Essential" external drive. Therefore the WM logo does not appear on the task bar at the bottom right hand corner of the PC screen. I tried to...
It is indeed safe. When trying to disconnect while the computer is on, make sure all windows related to files/folders on the drive are closed, and check that antivirus software isn't scanning the drive.
Mar 24, 2011 | Computers & Internet
My usb dont appear on "my computer" only safely
Right Click on My Computer, Click Manage. Select Disk Managemen. Try to look for your removable drive then right click and Click "Change Drive Letter and Paths..." .
Mar 21, 2011 | Microsoft Windows XP Professional
Gps has lost its maps, screen says can't unlock maps
There several reasons you may receive the message Can't Unlock Maps on your nuvi or zumo device.
  • Can you press OK and get to the Where To/View map screen?
  • Did you load maps to the unit using the MapSource or MapInstall program?
  • Did you load maps to an SD data card?
If one of the points above applies to you, please follow the steps below to clear the Can't Unlock Maps message:
  1. Remove SD card from unit, if applicable.
  2. Plug the unit into your computer with a compatible USB cable.
  3. Open MyComputer/Computer icon. (Mac users skip this step.)
  4. Right-Click on the Garmin drive and select Open. (Mac users can locate the Garmin drive mounted on the Desktop.)
  5. Open the Garmin folder.1
  6. Locate a file named gmapsupp.img
  7. Right-Click and delete file named gmapsupp.img
  8. Safely disconnect your unit from your computer to see if the Can't Unlock Maps message is gone.
1. Nuvi 1100/1200/1300/1400/1600/3700 and Zumo 665 users will open the Map folder instead.
*If the gmapsupp.img file does not appear in the Garmin folder, please create an unlock file for device.
Nov 28, 2010 | Garmin Nuvi 265W GPS Receiver
Warning you must plug magicjack into usb
I was receiving "You must plug magic jack into usb" error
This is the fix that worked:
please download and Run the remover :
http://upgrades.talk4free.com/tools/mjRemover.exe
after you have done that , download the MS Fix http://go.microsoft.com/?linkid=9645377
then Run the UPGRADE http://upgrades.magicjack.com/upgrade/upgrade.exe
Oct 08, 2008 | Lands Phones
Pen drive not showing in my explorer.
Its a common problem with the pendrive, in windows. some time it doesnot detect or not showing clearly that device. you have to check your pendrive manufacturer and driver details. and also check it out driver signing.
Do you have mapped network drives on your computer? If you have this may cause your problem. When you insert the PEN Drive into USB and the "safely remove hardware" icon appers try to right-click on it and choose "eject" or "remove" (don't remember :), then pull the PEN DRIVE from the USB and connect it again. Go to Windows Explorer and try to open all your mapped drives, then the content of your PEN DRIVE must be loaded into your Windows Explorer. This is happened sometimes, because PEN DRIVE try to assign the first free drive letter after your phisical drive letters, and if you have a mapped drive letter, the PEN DRIVE assign one of them.
Jul 22, 2008 | Microsoft Windows XP Professional With...
Belkin (F5D7230-4) Router (587009) Logo
117 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
