Question about Compaq Keyboard
Have a packard bell keyboard 9201 - Compaq Keyboard
How i unlock my keyboard. lts packard bell easynote TE11 BZ
Hello
Does the whole keyboard not work or only some keys?
Try the following shut down the computer , disconnect the power cable and remove the battery from underneath then press power button for about 20 seconds then reconnect the battery and the mains power and switch on the laptop again.
Did you spill any liquid on the keyboard?
Jan 23, 2015 | Packard Bell Computers & Internet
Packard Bell MIT-RHEA-S keyboard compatibility
Depends on your country code. The letters and symbols may be in the wrong place.
Apr 23, 2014 | Packard Bell Computers & Internet
I have a packard bell touch screen moniter and computer all in 1 and the keyboard just stoped working whats wrong and how can i fix it
add via USB an external keyboard, like me, because some keys are no more working on the bad Chinese used keyboard.!!
Jan 11, 2013 | Packard Bell oneTwo L A6524uk All In One...
Need to buy Packard Bell keyboard relacement for S/N BCKB21006311: P/N 6837780001. Can you advise/?
Packard bell should be a standard PS2 keyboard, I would just get one at your local thrift store for a couple bucks. Look at the connector where it plugs into the tower and then just make sure the new one looks the same, should work good. Most modern keyboards are USB, but packard bell is old and may not work with this type. You could go find a new PS2 keyboard at a store but it will be about $20
Jun 12, 2010 | Computers & Internet
I am unable to use the hot keys on a Packard Bell keyboard (SK-2300H) installed on a generic PC running Vista. The PC sees the keyboard as a standard PS/2 keyboard. Some of the buttons are active. e.g the...
Your Packard-Bell keyboard was designed to work specificaly with your PB system. The old computer came (probably pre-installed) with software and drivers that map the extra keys to functions like e-mail, calculator, volume control etc. It may be possible to make the keyboard work like it did on your old system by locating and installing the Packard Bell keyboard driver and software. Go to the PB website and select UK-Irish support location. From there go to support section and follow the automated support by filling in info such as model number etc. No guarantee it will work but worth a try.
Oct 29, 2009 | Computers & Internet
I have a packard bell 9201 keyboard andsome of the letters and numbers when pressed come up with different numbers and letters is this a easy thing to sort out
THE KEYBOARD NEEDS TO BE TAKEN APART AND CLEANED WITH SOME ALCOHOL AND DRIED WITH A NON LINT TOWEL, SPRAY A CAN OF COMPTRESSED AIR OR IF YOU HAVE AIR COMPRESSER WILL WORK ALSO., SOME FORIENING MATTER OR OIL OR A DRINK OF SOME SORT GOT ON THE CIRCIUT BOARD AAAND WHEN YOU DEPRESS THE KEY YOU GET A DIFFERENT SYMBOL.
FIRST YOU MAY WANT TO UPDATE THE DRIVERS JUST TO BE ON THE SAFE SIDE.
IF YOU HAVE ONE THAT USES A POWER DEVICE CHECK THE POWER AND REPLACE THE BATTERIES AND RESET THE TO PUT THE DEVICES ON THE FREQUENCY
ROD
Mar 04, 2009 | Compaq Keyboard
Packard bell easynote keyboard not working
my keyobard won't work on my packard bell laptop
Nov 23, 2008 | Packard Bell Easy One Silver 2101 Notebook
How do I add more ram to Packard Bell Notebook
all you need to do is to remove the keyboard and the slots should be under it..
Aug 15, 2008 | Packard Bell Computers & Internet
Non working keys on laptop
You should just need to replace the keyboard.
However finding a keyboard for a packard bell in the US can be hard. That brand hasnt been sold here in years.
If you are in europe it should be less of a problem though.
Made sure to get the exact model of the laptop to get the right keyboard.
Dec 20, 2007 | Packard Bell Easy One Silver 2101 Notebook
Compaq Keyboard Logo
140 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
