Question about Refrigerators
Our BEKO TZS490 has decided to defrost itself without our having done anything to it. Electricity supply is OK: the orange light is on, but neither the green nor red light is showing. Please could you advise: - How to get it to freeze; - What might have caused the problem?
  • 29 Answers
Make sure there is no lint or dust in the fan motor located on the lower back of the fridge.
Posted on Jan 02, 2011
Have a BEKO TZS490 Freezer. It is tripping my House RCD . is there a fuse in it, (other than the plug)?
no fuses
the tripping of the rcd indicates a dead short or faulty insulation of the unit
check the power lead to the unit for broken wires
other than that it is possible that the compressor motor has burnt out
call a technician for an electrical check
Jan 13, 2017 | Ovens
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
Samsung plasma tv orange led
The set has a power supply circuit board INSIDE that needs to be looked at (not the power cord itself) and if bad replaced.
Dec 08, 2012 | Samsung Televison & Video
Our two identical Ocean upright freezers have been affected on two successive evenings by a blip in the electricity supply (electric clock and ansafone also affected). The result has been that the...
A bit of a whacky suggestion, but you could get yourself a UPS (Uninterruptable Power Supply).
PC Stores sell them for home PC's, but you would need to check the output capacity of the UPS could handle the fridge. From what you say, you only need to protect from a "Blip" and if the power was to go out for a few minutes and then reset, the freezer would be ok and would reset itself without a problem. IF this is the case then a small UPS might be your answer because it would only have to provide support to the machine for a few moments - If it then failed it would be because the power was actually out for a little while and when it came back up the freezer would do what it should and recover.
Jun 23, 2011 | Freezers
When we switch the dishwasher on it trips the electricity. It's worked fine for 2 years but now won't work at all and just trips the electricity.
Your dishwasher has a serious electrical safety fault which is causing the protective breaker to trip (although it may have a simple and cheap cause). With all due respect, your question clearly demonstrates that you lack the knowledge and skills to carry out a diagnosis and a safe repair (especially vital for anything which uses water and electricity). Before doing anything else, fully disconnect your machine from the main electricity supply by either unplugging it or for a machine connected to a flex outlet by turning off the wall switch and then removing the fuse.
Sorry, but in this instance you only have two choices: get a qualified dishwasher repair engineer in or replace the machine. Anything else could be lethal.
Oct 08, 2010 | Beko Dishwashers
Fridge freezer problem
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
Jul 14, 2010 | Freezers
ICING UP FREEZR
this sounds like a defrost timer issue possibly a bad defrost heater is also involed,what was done the first time seems like it needs to be done again.some thing is not telling it to go into a defrost mode may be a sensor issue as well. good luck with this problem
Jan 21, 2010 | Samsung RS2630SH Side by Side Refrigerator
Fridge Freezer in Autodefrost mode
Power surge can cause problems such as you have. I am not familiar with your brand but it sounds like the defrost timing circuit is your problem. Defrosting the surface of the back wall is not the answer. The cooling coil in the freezer is behind the back wall normally and a surface defrost does not do the trick of defrosting the coil. Have an appliance service tech check it out for you.
May 30, 2008 | Freezers
Xbox 360 red lights power supply light stays yellow
you have to disconnect and reconnect the power cables to the 360. Orange/yellow light means that your power supply is on a standby mode and the 360 is not getting enough power/electricity inside
Mar 04, 2008 | Microsoft Xbox 360 Console
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Refrigerators Logo
133 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
