Question about GE WBSR3140DW Top Load Washer
How to remove top cover - GE WBSR3140DW Top Load Washer
    President:
  • 2,468 Answers
Remove 3 screws behind control panel tilt forward and remove control panel and lay out of way,then slide top cover toward you to remove
Posted on Jan 02, 2011
How do i remove the front panel of the asko t721 to replace a broken belt?
REMOVING THE FRONT PANEL
1. Remove the top cover.
2. Remove the lower cover.
3. Remove the door.
4. Remove the front drum frame.
5. Remove the four screws that secure the front panel to the side panels.
6. Remove the two screw that secure the bottom edge of the front panel.
7. Lift off the front panel.
_____________________________________________________
REMOVING THE TOP COVER
1. Remove the three T20 screws at the rear of the
top cover. (Keep the two star washers.)
2. Tilt the cover and pull it backwards.
REMOVING THE LOWER COVER
1. Remove the two 20 torx screws (A) at the
bottom of the lower cover.
2. Next, grasp the sides and pull it forward and
down.
25764946-gtkp3url2ghtdqenstp5bokb-1-2.jpg REMOVING THE FRONT DRUM FRAME
1. Remove the motor (see page 34).
2. T700/760: Remove the exhaust vent by
twisting it free.
3. Remove the wire bundle from the cable clamps
on the front drum frame.
4. Remove the fan housing cover (see page 33).
5. Using flat-nose pliers, take out the thermistor.
6. Open the front door.
7. Unscrew the four screws that secure the drum
frame to the front panel.
8. Lift out the drum frame.
REMOVING THE DOOR
Note : The front door must remain closed during the entire removal procedure (The door magnet will hold it
in place.)
1. Remove the lower cover (see page 24).
2. Unscrew and remove the three screws that secure
the hinge fixture.
3. Lift down the front door.
Dado
Jun 29, 2015 | Asko Dryers
Tip
Maytag Neptune Front-Load Washers Front Panel and Top Cover Removal
Most of the internal components of Maytag Neptune Front-Load Washers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the machine.
The top cover is held on each side of the cabinet by hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Open the door then lift the front of the top cover and tilt it toward the rear of the machine.
The internal components of the machine can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Square-Front (1998) and Sloped-Front (1999) Dryers (Maytag Neptune Dryers). The only difference is the dispenser bezel removal.
on Apr 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Try to replace spug pluks but i dont know how to remove the cover , please i need help thank you.....
REMOVE TOP ENGINE COVER,REMOVE THE TTHREE TOP PLASTIC PLUGS ON TOP OF COVER WITH SMALL SCREW DRIVER TO ACCESS THREE SCREWS RETAINING THE ENGINE COVER.
Jul 27, 2011 | Volkswagen GTI Cars & Trucks
Where on spark plugs and wires on 99 - 4 cyl. Malibu w/ overhead cams
pull the cover that has the 4 bolts in it on top of the engine. that is the coil/ignition module housing. the plugs are under it along with plug boots that you may want to replace.
Jul 25, 2011 | 1999 Chevrolet Malibu
Need to replace a baffle that broke off . MED9800TKo model baffle broke off insde on the dryer drum
Remove the top panel to access the outside of the drum where the baffle securing screws are found. Remove the three hex-head screws from the rear flange of the dryer's top cover the lift the rear of the cover and slide it back so the tabs clear the catches on the bracket and remove the cover from the unit.
Turn the drum until the baffle screws are on top then remove the screws and the baffles. Install the new baffles then the top cover. Make sure that the tabs slide under the bracket catches when you reinstall the top cover. The top cover screws have nylon flat washers on them. Be sure to use these screws when you reinstall the top cover.
Jul 18, 2011 | Maytag MED9800T / MED9800TQ / MED9800TK...
The heat is working but the drum is not spinning. how can I look into replacing the belt assuming there is one?
remove top cover control panel and remove screws and top cover,then remove face covers 2 screws at the top inside and remove face cover then remove and install the new belt and replace the idler pulley that keeps tension on the belt as long as your in there
Jan 02, 2011 | GE DBXR463GB Gas Dryer
How do you remove the face plate the is on the
Remove the top hinge cover , covering the top freezer door hinge , and unplug the visible receptical . This removes power to the dispensor and dorr . Using a butter knife between the grill and the dispensor bottom cover , push down and inward , prying the cover outward . Do this on both sides , about 1 " from each side . This pops the plastic clips off . Raise the cover to release from the upper plastic retainers . Disconnect the plug from the cover and its removed . Do this carefully , because your working with plastic . To reinstall , reconnect the plug to the dispensor cover , slide the top in place and pop the lower tabs back into place . Reinstall the top hinge plug and cover .
Aug 29, 2009 | Whirlpool Refrigerators
Phaser 7700 Error 54
You need to remove both the rear and top cover to access that fan easily.. There are some screws on the right side of the machine for that top cover. There are 4 or 5 in the back of the machine.You may have to remove the lower right cover to access the screws to the top.
They are interlocking covers, some dependant on removing others.
Sep 09, 2008 | Xerox Phaser 7700 Laser Printer
Remove the top cover?
Hi amp422
At the bottom and on the sides of the Projector there should be screws that can be taken out.
Unscrew these and you should be able to open up the unit.
May 01, 2008 | InFocus LP530V Video Projector 2000 ANSI...
Taking cover off dryer
The top cover or rear cover? The rear cover is usuallyr held in place with a small handfull of screws. You might have to slide the cover off some hooks when all the screws are removed. If you want the top of, you will probably have to remove the rear cover first, then loosen the top cover and slide it off, or slide it slightly then lift it off.
May 17, 2007 | LG DLE2514 Electric Dryer
GE WBSR3140DW Top Load Washer Logo
90 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
