Question about Dell M992 19" CRT Monitor
Picture dissappeared suddenly. Power Fuse ok but
Picture dissappeared suddenly. Power Fuse ok but not switching on -what could it be?
  • 70 Answers
Faulty component in power supply or line drive circuits. Take to repair shop or find a second hand one, CRT monitors can be had for free or very cheap now.
Posted on Jan 02, 2011
My 1995 mercedes Vito 113 just stopped running while driving along the road. I was accelerating and all of a sudden it stopped runnning, the dash lights all immediately came on.
run the fault codes
could be a broken timing belt or chain
could have blown the main power fuse next to the battery ( around 80 amps ) and that would have switched everything off
Sep 29, 2016 | Seat Cars & Trucks
Ac/heater blower quit
Not sure what fuse or fuses you have replaced. I know there is a fuse marked BLWR in the fuse panel under the hood but the is also another fuse that is a vital part dealing with the blower motor working. Above in the second picture is the fuse layout in the fuse panel inside the truck. I marked the fuse you need to check (HTR A/C). If that fuse is good then you need to check where your power loss is. In the first picture above, that is one of the connectors on the control panel (power control switch &if you have a manual control not auto). The terminal marked with an arrow you need to chaeck for power at that terminal (Should be a brown wire. If no power, find the open wire from there to the HTR A/C fuse. If your good there you can make sure your getting power to the blower motor. Not sure of the wire color but it's the one that's not black. Make sure you have power there with the switch on. remember to use a seperate ground and not the other wire (the black one) on the connector at the blower motor. If no power the find the open wire from there to the replay. If all is good then there's much more tracing but I would start here. Hope it's just that other fuse. Hope this helps....
May 14, 2013 | 2005 Chevrolet Silverado 1500 2WD
Which fuse powers drivers side window motor 1988 Sierra 1500
check for power at switch power at motor when switch is on then it is in motor
Mar 27, 2013 | Cars & Trucks
I have a 2008 MKZ and the driver power seat suddenly. Quit working. The main fuse is OK and the control switch checked out good..is there a secondary fuse. Or does th)e motor need replacing
When you toggle the switch to the different positions of seat movement do the motors receive power? Also if one or more of the motors (there are 3 I think) is defective they are not available separately, you must replace the entire power seat track assembly.
Apr 10, 2012 | 2008 Lincoln Mkz
My wireless network suddenly dissappears while working on my laptop i.e. the wireless light on the laptop dissappears and I can't connect to the wireless network. Only solution I know of is to re-boot the...
go to the properties (power management) of the wired (!) connection and disable the setting that the computer can shut this down to save power. Sometimes it will also shut down your wireless.
Nov 20, 2010 | Dell (430-3572) Wireless Adapter
Lost all power all of a sudden 1977 corvette
do you know what fuse links are,and what they look like? usually down at the starter,the 2 or 3 hot wires besides the main battery cable all connect they feed the power to the fuse box,ignition and accessories,they have black square rubber blocks on them usually 3 or 4 inches from the starter they are built in fuses in the wires themselves check continuity throught them,if you already know about them ,the head light switch and the ignition switch are the first place i would look ,especially if they are original
Jul 11, 2009 | 1972 Chevrolet Corvette
Maytag top loader MAV 8000MWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Checkto see whether power is getting to the washing machine. Is it pluggedin? Has a fuse blown or is a circuit breaker tripped?
Lid switch Ifthe lid switch is defective, your washer can't spin and may notfunction at all. The switch is inside the washing machine main housingnear the door frame. Often you have to raise or open the top or frontof the washer to get to the switch. If it's defective, you need toreplace it.
Some machines have a special lid-switch fuse nearthe lid switch, inside the control panel. If this fuse blows, the unitwon't fill with water until you replace the fuse.
Sep 27, 2008 | Maytag Atlantis MAV8000
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
Dell M992 19" CRT Monitor Logo
76 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
