Question about Technics SL-MC6 CD Player
Discx wont play.I've used cleaning disc.I have to clean each time before I want to use the payer.Often the cleaning disc wont work either
  • 70 Answers
If cleaning doesn't help then the laser unit is probably going bad. It can be replaced by a repair shop.
Posted on Jan 02, 2011
The dvd payer is not working.
see this instruction and follow for fix it. God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Jul 17, 2013 | Televison & Video
Every CD I put in I get a message," no disc"
Hello
The laser pickup lens of your DVD payer is either dirty of faulty. Just put in a claeaning disc, and play if for at least three times. If there is any dust or dirt accumulated on the lens, the cleaning disc will clean it up. If this does not help you, laser pickup assmebly should be replaced with same type and number. OK.
Nov 28, 2011 | RCA DRC277 DVD Player
My samsung ht-x200 wont play dvds or cds it just displays no disc
Have you tried cleaning the laser with a DVD Cleaning Disc or more in depth by removing the top cover and using DVD Cleaning Fluid & QTips.
If you've tried both these without success then I'm affraid that your laser has failed and in most cases even when replacement lasers are available it's not cost effective to replace it.
Jun 20, 2011 | Samsung HT-X200 Theater System
When trying to record a home video VHS to DVD this is what I get. E-4 54040990 Cannot record on this disc. The disc is brand new.
Have you've tried cleaning the laser with a cleaning disc?
Failing this it may be worth removing the cover and cleaning the lens directly with a QTip and some lens cleaning fluid. Only use a drop and then wipe off with a clean dry QTip.
The other option is that you are using an incompatible format of blank DVDs. I've heard of people having problems using DVD-R & DVD-RW and although it is lised as being suitable for all types of recordable DVDs I belive you're best using DVD+R & DVD+RW.
The Manual states
Recordable disc
• We strongly recommend for good recording quality:
SONY DVD+RW 4x, MAXELL DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, TDK DVD+R 4x/8x/16x,
MAXELL DVD-RW 4x, MAXELL DVD-R 8x/16x
• Discs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+RW 4x VERBATIM DVD+R 8x
VERBATIM DVD-RW x VERBATIM DVD-R 8x JVC DVD-RW 4x MAXELL DVD-R 16x
May 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a caset i play it for 15minute and it stop playing and tell me to clean the disc with a soft cloth and restart the console it
if you are talking about a disc try using a little bit of deoderant or after shave on a soft cloth and rub in a small circular motion starting at one side and working your way around (see video). dont use too much but if you just use a little bit and rub it properly it should work. if that doesnt work then the disc is scratched at a certain part and cannot be fixed. my method is proven to work if done right. i have had games cleaned by video store cleaners and i have even bought special disc cleaning kits and that and nothing could fix my discs but when i did this method i have had even the dirtiest scratched discs work again. this method works 90% of the time but like i said if this wont fix it nothing will. hope this helps.
Nov 27, 2010 | EA Sports Video Game Consoles & Games
My Bose Wave radio/cd won`t play cd`s anymore. The radio works great. The cd player worked tonite, the would stick in a certain part of a song. Very intermittent. Now tries to read the disc, then says disc...
"I`ve used an aerosol air can to clean thru the cd slot"What type? not an "empty" can of paint, hairspray, chemical of some sort i hope. Compressed air at most I hope. If not, that's your Bose out the window!
The lense sounds like it needs a clean, you can buy these in disc for with tiny brushes on. Made by BIB and Allsop amongst many brands
Aug 30, 2010 | Bose Wave Music System CD Shelf System
I have the uv8 phase linear and burnt cds wont play only store b
I had the same problem - its because when you burn the disc, you don't use up all the recording time; and the read light on the player is so sensative that if there is any unused time, it will not accept the disc. So, make sure your recording time exceeds the disc space, and make sure the last song you burn is not your favorite because it will cut off midway through the song.
Jul 02, 2009 | Phase Linear UDV9010 Car DVD Player
I have a DVD-1920. DVD discs wont load most times, gives a message that there if a fault on th disc (disc is okay on other payer), I have used a laser cleaner and looked at the set up. It it worth...
hi,
please try cleaning the lens manually with cotton or check if the flexible board connecting the lens to the mpeg board is ok or may be loose. if the same problem appears, maybe you've got defective lens or affective mpeg board.
joemari
Mar 09, 2008 | Televison & Video
Dvd's not playing
This might be a problem with the alignment of the actual laser in your device. You mentioned that you cleaned the player? Question, how? The reason I ask is because if you used alcohol and canned air you many have left a residue on the laser facet which would cause such a problem. I would suggest that you use an apporved fiber optic cleaning solution and attempt to clean the laser, (it is best to let a pro do this). Then check the laser alignment and power with a laser power meter.
Sep 02, 2007 | Jwin JD-TV1300 13 in. TV/DVD Combo
Technics SL-MC6 CD Player Logo
82 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
