Question about Dryers
My tumble dryer was making a grinding noise and has since stopped working
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Posted on Jan 03, 2011
  • 55 Answers
SOURCE: Dryer Making a Grinding Noise
The grinding noise is probably a worn out roller or the central bearing in the back. The center of the drum in the back has a part called a bearing which screws onto the back of the drum and has a stub which sticks out. The stub then goes into a bearing hole in the back panel of the dryer. If you are handy, you could try to replace yourself. I did it once. While you are at it, check the drum belt which goes around the drum and makes it spin. Replace it if looks like it has wear.
Posted on Feb 01, 2008
IFIXALL
  • 868 Answers
SOURCE: ge dryer makes grinding noise when drum is turning
If youve made sure that its not a roller thats dry or a belt idler pulley that dry,than yes its the motor,and oiling that will only make it worse.
Posted on May 21, 2008
SOURCE: My hoover tumble dryer hnv
TheOsteopath is a pure genius - have had an increasingly noisy hnv 380 and was about to get the yellow pages out for an expensive repair (or replacement) but followed the instructions to the 't' and it works perfectly. Many many thanks. You've saved my pocket and my eardrums. JS.
Posted on Jun 28, 2009
hunter19_46m
  • 7482 Answers
SOURCE: druer works, heat and tumbling but it makes a loud
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Oct 28, 2009
arikrom
  • 528 Answers
SOURCE: The dryer is making a loud noise as it tumbles.
you need to open it most of the dryer need maintanace every 4-5 yars and if you keep runing it you may do more damage.
there are several parts that the drum is turning on them and they get bad after few years. like felts,riders,belt...
Posted on May 02, 2010
And Admiral ser# 3281223 When dryer is turned on, it makes a loud grinding sound when it tumbles
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 29, 2011 | Dryers
I have a GE electric dryer and it makes a horrible screeching noise when tumbling. it tumbles and gets hot but when trying to manually turn the drum it gives me some resistance. whats the making this...
heatman101
Jul 25, 2011 | Dryers
Hotpoint vtd20 tumble dryer is making a horrible grinding/grating noise when the drum is rotating and seems worse in 1 direction any ideas??
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances
Jan 02, 2011 | Dryers
Getting a clank from the dryer once is stops tumbling.
heatman101
Asker
Nov 23, 2010 | Maytag Dryers
My maytag performa dryer is drying clothes fine and the drum is tumbling the clothes, but it is making a horrible noise. When you turn the dryer on you can hear something inside the dryer unit tumbling...
heatman101
Oct 13, 2010 | Maytag Dryers
My maytag dryer is making a loud noise when tumbling the clothes. It is heating up okay
heatman101
hfgh
Feb 02, 2010 | Maytag Neptune MDE4000 Electric Dryer
The dryer part started to make a noise as if a sneaker was inside tumbling around.. next thing I know the two screws that attached the drum fell off and it completely stopped working
heatman101
5665thg
Jan 27, 2010 | GE Spacemaker Washer and Dryer Electric...
My dryer makes noise when running
heatman101
hggf
Jan 18, 2010 | GE DHDVH52GFWW Gas Dryer
GE Dryer makes deep sounds when hot and tumbling
heatman101
wrytrtrs
Jan 28, 2009 | General Electric GE 7 0 Cu Ft Super...
Dryers Logo
433 people viewed this question
Top Dryers Experts
