Question about Fuji J15 Digital Camera
GDay, I have a black spot in my image. I previously dropped the camera in the sand. Sand had blocked up the opening shutter. I have since tried to remove the sand in the opening mechanism. Any ideas about the black spot? And how to remove it. Many thanks
  • 70 Answers
The spot will be caused by a dust particle or sand grain on the image sensor. I have successfully taken a camera apart before and cleaned the sensor (which is only about 1/4" across), but it is fiddly and easy to damage it, but worth a try if it is unusable. It is not usually worth taking to a repair shop as it is as cheap to buy a new camera.
Posted on Jan 02, 2011
My father dropped my Kodak camera into the sand and it won't work now
If there's sand in the mechanics of the shutter flap and you can hear more that's stuck inside, there's nothing you can do except take it to a camera technician. It'll need to be disassembled, thoroughly cleaned and reassembled.
You will more than likely do more damage if you try turning it on or shaking it to get the sand out.
Sorry to hear about it!
Aug 02, 2012 | Kodak Md863 Easyshare Digital Camera...
Lens shutters are stuck
If you have recently dropped the camera or exposed it to excessive dust/sand or dirt the shutters guide tracks may be jammed and unable to move. I would advice taking it to a camera repair shop, and to avoid opening the camera on your own as it may cause further damage/voiding of warranty.
Jan 26, 2012 | GE A730 Digital Camera
Panasonic PT-AE2000U yellow spot
I believe your referring to a lens flare...if so, you must smoothly sand the lens with the finest sand paper and then buff it to perfection
Jan 04, 2012 | Panasonic PT-AE2000U Projector
When pressing the power button, the shutter opens, the lens comes out, the screen comes on for about 2 seconds. Then the screen turns off, the lens goes back in, but the shutter stays open. I let someone...
Look closely for sand particles that may be lodged around the gaps of the lens barrel. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 18, 2011 | Kodak Easyshare C182 12MP Digital Camera
My camers fell down and the shutter is not closing. The screen is fine n the images are fine too. There is a message that says close the power and try again. what do i do
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 14, 2010 | Cameras
Lens shutter problem
Jul 07, 2010 | Canon Powershot A2000 IS Digital Camera
Camera shutter not opening
The best thing you could do is take it to a competent repair shop, tell them what happened, and have them fix it. If it is just sand jamming the lens cover, they shouldn't charge too much to fix it.
Alternatively, if you can move the lens covers at all, try gently working them back and forth in very small movements while holding the camera with the lens pointing down - basically just try to work the sand out and let gravity help you. Be careful though, you may get sand deeper into the camera's mechanisms this way!
Oct 31, 2009 | Canon PowerShot A590 IS Digital Camera
Digital camera got dropped into the sand, and some sand worked its way into the lens and focusing system, and now the camera cannot zoom or focus, but still turns on and takes pictures i have a lumix dmc...
THIS SOUNDS TERMINAL, BUT YOU MIGHT TRY USING CANNED AIR LIKE YOU USE TO BLOW DUST OUT OF YOUR COMPUTER, AND SEE IF IT HELPS ANY. MOST OF THESE CAMERAS ARE MADE WITH THE IDEA THAT THEY WILL NEVER BE TAKEN APART OR OPENED FOR CLEANING ETC. SO, THAT IS THE ONE PROBLEM YOU ARE FACING. I DOUBT IF IT WOULD BE WORTH SPENDING THE MONEY TO SEND IT IN TO BE CLEANED. THAT CAN GET VERY EXPENSIVE IN A HURRY, PLUS TAKE A GOOD MONTH OR MORE FOR THE REPAIR. SORRY, I CAN'T HAVE MORE CHEERY NEWS, BUT THINGS LIKE THIS JUST AREN'T TAKEN INTO ACCORD WHEN THEY MAKE THESE CAMERAS. IF I CAN HELP MORE JUST REPLY TO:
ARCLIGHT1217
Nov 04, 2008 | Cameras
Got sand in my sony cybeshot DSC-W55
It sounds as if the sand is jamming the lens/shutter mechanism.
I would be very cautious about using compressed air to try and solve the problem. You could well end up just blowing the sand further into the camera and causing more serious problems.
I would recommend taking it to a professional, but if you do want to dive-in yourself, I would do the following:
If possible, try and brush any grains of sand away.
Avoid using compressed air - Use a proper camera blower instead.
Avoid touching the sensor!
Matt
Feb 26, 2008 | Cameras
Sand in camera
no need to take apart just power up and gently pull the lens out and vaccuum the sand out, camera now works perfectly
Nov 09, 2007 | Casio Exilim EX-Z57 Digital Camera
Fuji J15 Digital Camera Logo
75 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
