Question about Ruud Heating & Cooling
Where can i get a parts list for a rudd furnace silhouette II
  • 472 Answers
You can find parts on line if you have your model number to unit and know whaat you are lookign for..if you have problems call my office @ toll free1-877-523-2101 monday -friday we can get parts and ship to you... licensed a/c heating and appliance company for over 18 years now...
good luck
Posted on Jan 03, 2011
Rudd silhouette ii blower
Send direct power to the blower by bypassing relay . See if motor runs
Jul 19, 2017 | Ruud UBHC Air Conditioner
Getting excessive condensation causing water problems at base of unit. Bought new pump but problem returned. Cleaned lines to outside by using wet/dry vac. How do I get to evaporator coil to spray it and...
Hello, in order to get to the evaporator coil you must cut into the plenum above the Furnace. This will require sheet metal tools and being very careful not to puncture the coil. Many times a cracked condensate pan under the evapoartor coil can cause water to leak down to the base of the unit.
Sep 15, 2011 | Ruud UBHC Air Conditioner
I need the manual for a rudd silhouette II gas furnance
Fixya has all the manuals you,ll ever need!
Dec 16, 2009 | Heating & Cooling
Meaning of rudd furnace trouble codes
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
Dec 12, 2009 | Heating & Cooling
Sticky manual gas valve
Sounfds like the thermostat is on the blink.?
Oct 17, 2009 | Heating & Cooling
Schematic diagram Rudd silouette II a/c gas furnace needed
There should be a small set of screw lugs on the electronic board in the furnace. Look for a red wire that comes out of the transformer and follow it to find where the 24V connections are.
Sep 21, 2009 | Ruud UBHC Air Conditioner
Ruud Silhouette II Fails to Ignite
sounds like you have bad flame sensor or the sensor is in a bad postition. To get eliminate the lockout turn the power off to the unit and back on again. Look at the circuit board light and see what the troubleshooting code is.
Jan 13, 2009 | Heating & Cooling
Heating & Cooling Logo
232 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
