Question about Video Game Consoles & Games
Which game is most graphics you ever seen? - Video Game Consoles & Games
Pota
Posted on Jan 02, 2011
How can i make my computer faster???? What should i change motherboard or CPU and the graphic is onboard. Does it mean if i change motherboard then i have to change Graphic Card???
The biggest impact on the speed have adding more RAM and replacing the CPU. Motherboard is replaced when there is no possibility to upgrade CPU and RAM. The onboard graphic also is not very fast but this is seen in games only. For everyday work any video is OK. If the computer is very slow this may be result of viruses, other unnecessary software and even antivirus software. If you replace the motherboard with a one without internal graphic, you will have to buy also a graphic card.
Apr 08, 2012 | Computers & Internet
My graphics card is GeForce 9400 GT 1gb and whwn i play IGI 1 the screen gets blurred nothing can be seen my motherboard is of gigabyte
try these following steps:
1: update your graphics driver to one of the most recent one:
2: Lower down the hardware acceleration to minimum.
3: If you can see things in the pause menu of the game please disable all the extra graphics effect ( like anty aliasing, etc )
Hope this would help.
Mar 19, 2011 | ASUS NVIDIA GeForce 9400 GT,, PCI Express...
I have a problem with a game called BARNYARD. It's a graphic problem, most of the features (buildings etc) cannot be seen and the ground looks like the sky... I have a intel(r)82845G/GL/GE/PE/GV graphics...
You have to upgrade your VGA card most probably but anyway you can try the following:
Install the latest VGA drivers from Intel website which can improve performance
Install DX 9.0c to remove some glitches/bugs
The amount of graphic processing is below par for your built-in graphic card when it is unable to draw objects in real time at FPS rate of 30 or above.
Let me know if the above steps help to improve the performance of the game or not.
Mar 12, 2011 | THQ Video Game Consoles & Games
I instaled a new video card and now i get a error message when i load games saying check graphics card directx 3dgraphics is there a onboard graphcs that i may have messed with by nividea
It seems that you have not installed software DIRECT-X needed to run the big games. Check Game's requirements which may be seen in readme/manual. Check which version of DIRECT-X is required. Install the same from Games Cds.
Sep 22, 2010 | Gigabyte GA-K8NSC-939 Motherboard
I have Geforce Fx5200 128mb pixel shadder 2.0 and i cant run crysis, call of duty 4 is there any way to run these games ?
Yes with a better graphics card. You need Shader 4.0 at least on that graphics card. (Plus a lot more Stream Processors)
The GeForce FX 5200 is an AGP style of graphics card, and uses 8X speed. (0.8 Volts)
It is a Budget graphics card, and does not have the graphics 'power' needed for the games you stated.
(If memory serves it has 16 Stream Processors)
There is no 'miracle' program, or tweaking of settings, that will allow you to run the above stated games at a decent capability. Even at low settings for the games.
I would suggest an ATI HD Radeon 3850 at least.
HOWEVER, other things come into play.
You need a 400 Watt power supply that has 30 Amps on the 12 volt power rail. The power supply must have a 2x4 power cable. (Example:
http://www.playtool.com/pages/psuconnectors/connectors.html#eps4plus4 )
OR, enough 4-pin Molex power cables that are unused to put in a 2x4 power cable adapter.
Your processor has have the processing power needed also, or you will have a 'bottleneck' of graphics information.
A graphics card has it's own processor. (GPU. Graphics Processing Unit)
It also has it's own Ram Memory. (Graphics ram memory)
However if the processor is too slow, the graphics information cannot be processed from the processor to the game program, and vice-versa, in a speedily fashion.
Graphics information, (Data), hangs up. Frames freeze, and frame rate slows down.
Post the computer name , model name. and model number, and we'll see if a better graphics card will help.
(Example: HP Pavilion D5200t)
Sep 24, 2009 | Computers & Internet
Is the GV-R465D2-1G graphics card compatible with
Yes they are compatible and should work well together, but I have had issues with the nVidia nForce3 chipsets. I have only seen Windows 7 use all the capabilities of the chipset. Good Luck and enjoy the games.
Sep 19, 2009 | Computers & Internet
CAN NOT PLAY GAMES
I would start by upgrading the video card, because it is most likely the problem. Also try lowering the quality settings within the games themselves to increase performance. RAM also plays a factor in games, these days 2GB of RAM and up is ideal for gaming.
May 06, 2009 | Intel Motherboard
Can't play small games on my computer
There are a few options open to you.
I will first say, all games are not created equal
First: get the new drivers for the onboard vid card.
also, is the card nVidia based? its seen in dispaly in control panel.
Also go to Microsoft and get lasted "DIRECTX" 9.0C or later driver.Let me know...
Mastersage!
Feb 01, 2009 | MSI : 661FM-L P4 SIS661FX FSB800...
My notebook restarts during graphics intensive games
It is a thermal problem. Try upgrading your internal fans & if possible install a graphics card cooler. Hope this helps.
Jan 08, 2009 | Acer Aspire 5630 Notebook
Installing Problems
It's a hardware incompatibility with windows vista. for example your graphics card on your Inspiron might not be fully supported in windows vista and your Laptop's graphics card is supported by Vista. Most of the times we can find this incompatibility is with graphics cards. Download and install the newest drivers for your inspiron's graphics card. I have seen your inspiron has an ATI Radeon X1300 graphics card. The windows Vista drivers can be downloaded here http://game.amd.com/us-en/drivers_catalyst.aspx?p=vista32/common-vista32
Oct 10, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Video Game Consoles & Games Logo
12 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
