Question about Microwave Ovens
Cannon 20175e oven heating element & fan fault
    Brigadier General:
  • 8,909 Answers
Lots of spares for those through ebay or espares. Should be no problem getting replacements and the price will be quite good.
The fan has probably seized up, a drop of cycle oil on the front bearing will fix that for a few more years. The element will need replacing if burnt out.
Hope that helps.
Posted on Jan 02, 2011
Stops after 4 mins
Can you hear the "whirl" of the fan? It is possible the fan is not turning & cooling the oven therefore it will shut down when it reaches a certain temperature. This could be caused by a supply fault to the fan or the fan motor, either way it would need to be tested by a qulified engineer.
Nov 10, 2013 | GE JVM1653 Microwave Oven
Convection oven doesn't heat
Possible that the relay is faulty or there is fault on the control panel. It can also be related to problems on the thermocouple or sensors which can cut off prematurely the element.
Feb 11, 2013 | GE JES1290 Convection/Microwave Oven
Both oven lights blown and fan not working
If you've noticed that your oven is not heating up, there could be a problem with your oven fan thermostat.
its simple to check :
1.
Open oven door and locate the back plate, which can be found at the rear
of the appliance. Remove the back plate from the oven fan (it should be held in place by between two and six screws). The oven fan is located behind the back plate.
2.
Examine the oven fan element and the fan blades (they are exposed once the back plate has been removed). If there are noticeable signs of burning, blowing, bulging or splitting in an area of the oven fan, you can tell where the problem is coming from. It is also common for there to be no visible signs of a problem. This allows you to determine whether or not the oven fan can be replaced from inside, or if it is necessary to enter the back of the appliance.
3.
Remove screws from element and disconnect wires if screw heads are showing. This is commonly the case, as it is unusual to have to further disassemble the oven. After the screws are removed, the element becomes detached from the oven. Use caution to not accidentally pull out electrical wires that are connected to the element.
4.
Take the rear cover off, which is held in place by multiple screws. After that, you should be able to see the wiring harness, fan motor and the components of oven fan element. Parts of the fan element are near the round fan motor, which is located at the center of the oven. There are two electrical connections and one earth wire. Take note of the location that the earth wire is placed, because it needs to be restored to the same position.
5.
Remove the oven fan element. Check the element again for obvious signs of damage. If there are no apparent markings, check the oven with an electrical test meter or a continuity tester. After replacing oven fan element, return all connections and covers to their original positions.
This should help you up to an extent to check it in case of any assistance please revert back.
Jun 10, 2011 | Microwave Ovens
My oven was bought one & a half yrs ago. Just now i on the oven to preheat & there is no temperature. Just wonder my oven is spoilt? Thanks
Did you mention if this is a microwave or a gas or electric oven.
If microwave there is no preheat unless with the food or using the heater, if so the heating element can be faulty. You will need to check this out and then check with the heating coils to confirm.
Someimes it can be only a fault on the contacts, relay or the connections to the heater.
May 07, 2011 | Microwave Ovens
My elba c96df oven has stopped working . The oven lamp comes on but theres no heat . Is it the elements or the thermostat?
Elba Oven not heating? How to replace a Elba fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for Elba element How to Repair Home Appliances
Mar 06, 2011 | Microwave Ovens
Hi we have a black overcounter microwave..9 power levels it will not heat was wondering if have heating element
They are not fitted with a heating element, they are fitted with a magnetron. It sounds as if there is a fault with the magnetron.
Feb 17, 2010 | Hotpoint RVM1435 Microwave Oven
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
Food still cold after cooking
Is this a combi oven? If it is not-and only a micro then there is no heating element. Try it on micro(if its a combi) with a mug of water for approx 30 seconds to test it. If its a combi-is the micro function still working?
Jun 21, 2009 | Emerson Microwave Ovens
I used the oven yesterday to bake a potato. Yesterday evening when my husband tried to ward some leftovers, it did not heat. The fan come and light come on, but the turntable is not turning and the...
hi..If it is electric,then the odds are that the element is out.
Turn the power off at the breaker,and remove screws holding
the element. Pull the element & remove the wires.Now test the
element for continuity.If it has continuity,then it is good and
thermostat is bad.
check it out..
thank u..
kindly rate my response..
May 07, 2009 | Microwave Ovens
Microwave Ovens Logo
43 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
