Question about Remington R-650s Electric Shaver
Model remington r7130 one of the heads keeps falling of while shaving i have stripped it down several times and find nothing broken
SOURCE: Remington MS2-250 shaver disassembly?
This shaver was pretty clearly not designed for battery replacement. To open, first remove the screen and blades, and unhook the metal collar from the tab on the back of the case. Then carefully pry off the black inset on the front of the shaver. Underneath it, near the bottom are two screws. Remove these. The case is now only held together by several plastic latches, which can be carefully pried apart with a small screwdriver. The two 2/3A size batteries are soldered to the printed circuit board, which can be pulled out (don't break the wires to the motor) by a little wiggling. The original batteries in mine are 1100mAh, and I have just ordered 1600mAh replacements. The new ones don't have tabs - so soldering them in place is probably going to be a challenge.
Good luck.
Posted on Dec 28, 2008
  • 153 Answers
SOURCE: shaved hairs fall out of shaver head
u have to less off the speed of ur shaver
Posted on Jul 21, 2009
SOURCE: After two weeks use of my new Remington R5130, now
My R5130 kept falling apart when I shaved. I really like Remington Shavers (Spectrum Brands) and have had good luck with them until the R5130 model.
Two points.
1.) -THEY SHIPPED ME A NEW HEAD ASSEMBLY (BUT)- The original one I got had poorly formed plastics tabs on the blade retainer (head) I Googled Remington Shavers and used their Consumer Service tab to request a fix. They sent me a new head assembly free of charge and yes it worked much better. However, it eventually the heads started falling off again.
2.) RUBBER BAND FIXED IT - I looked it over again and thought that the range of movement and forces on the assembly pieces was just more than the design could handle so I looked for a way to contain some of the movement. I slipped a single thin (1/16"x1/8") - 2" diameter rubber band around the three head assembly and the problem has been completely eliminated. I can shave normally now. The rubber band nearly disappears under the black head flanges so it doesn't even look bad. The shave is a little firmer now but it still has most of the flexibility of the original design.
This simple fix will be a hard one for Remington (Spectrum Brands) to adopt but you might help spread the word. I am sure they will avoid this problem in the next models.
Posted on Sep 01, 2009
brector3
  • 1600 Answers
SOURCE: Hello, I have droped my Remington R7130 and
You need a new hed holder. You will find this item at shaveroutlet.com. See link below
http://shaveroutlet.com/remington-head-assembly-without-cutters-for-select-models-p-808.html
Posted on Jan 31, 2010
  • 1739 Answers
SOURCE: my remington r7130 hair trimmer's
You can have the battery replaced. This however needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
http://www.remingtonproducts.com/ConsumerService/AuthorizedServiceDealers.aspx
If you are in another country, go to the top right of the screen, mouse over the Country and select your country. Look for a tab for the Authorized Service Dealer search function.
Posted on Apr 05, 2011
I am looking for a replacement power cord for remington R7130, where can i get one
remington pa-400 12v adapter power cord for electric shaver remington r7130 charger replacement parts.
Input: 100-240 VAC 50-60 HZ, Output 12VDC 400 MA
remington r7130 charger power cord
May 22, 2012 | Remington R7130 Hair Trimmer
I have a Remington 360 rotary shaver - model no. R7130. One of the small springs inside one of the rotating cutting heads is missing. Am I able to purchase a spring to fit please?
These springs are not available from Remington for replacement. Your best bet is to go to your local hardware store where they should have a variety of springs available
Sep 01, 2011 | Remington Health & Beauty
How often do you have to change the three cutters on my Remington R7130 electric razor
Remington suggests changing the head on model R7130 every 12 months. You will find replacement heads for this model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-spr-titanium-360-pivot-and-flex-replacement-heads-with-frame.html
Feb 21, 2011 | Health & Beauty
I have a R4130 and the bottom roter keeps fallling off.\r\nAndy
It sounds like it i either not installed correctly or th frame that it fits in is broken.
You will find installation instructions at shaveroutlet.com. See link below
http://shaveroutlet.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/f/i/file_36_1.jpg
Check to make sure that you have installed this head correctly.
If you have it installed correctly but it still falls out, you will need to replace the frame. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-head-assembly-without-cutters-for-select-models-p-808.html
Or if you prefer to change the entire head assembly, it is here:
Sep 26, 2010 | Remington Health & Beauty
Pop up trimmer stopped working Remington R830
Make sure you are using the trimmer with the shaving heads on the shaver. With heads removed, the trimmer on the back will not work properly. If thats not the problem, the trimmer is broken or jammed. clen the blades really well with a toothbrush and rubbing alcohol. If they're jammed, this will probably free them up. If that doesnt do it, the trimmer is probably broken and that part is no longer available from Remington. If you really like this model, you can find a replacement at shaveroutlet.com
Jan 10, 2010 | Remington Health & Beauty
After two weeks use of my new Remington R5130, now one of the three heads keeps popping off during almost during every shave. Any suggestions?
Two points.
Jul 08, 2009 | Remington R510 Electric Shaver
Remington es1000
The Remington ES-1000 was probably the best slot-head shaver ever made by Remington. I cannot believe that the market demand was so low as to prompt a cancellation of production. I believe that the production run was limited to about 4 years or so. I have 8 of these shavers and keep a couple old Remington slot heads around as well. The ES-1000 was not perfect. The batteries were way too small and stressed so battery life was poor.You could not buy individual blades as you could with past Remington slot-head units.Also, the edge of the head was too exposed and sharp and when used for body shaving would tend to cut the skin.Slot-head shavers are superior for body shaving and for skin that is suseptible to shaving bumps.They are also great for young men that are prone to ingrown hairs.My guess is that the Norelco 3 head has taken it's place. Those shavers actually use 3 small slot heads. Rumor has it that shavers.com is trying to have a new slot head manufactured in Asia.
Dec 05, 2007 | Remington ES-1000 Electric Shaver
Remington R-650s Electric Shaver Logo
59 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
