I have a simpson EZIset 750 7.5kg washing machine, model # 22s750m When the machine fills up and start it cycle everything is fine until it comes time to do the first drain and spin, the lid lock light flashes and continually beeps and the cycle will not progress any further. Can you offer any advice please. Kind regards Dani Thomas
Ihad the same problem. I cleaned out the blocked inlet to the pump and it now works fine. It would not pump out so would not start to spin until empty.
Posted on Dec 07, 2011
Hi There, I have the same machine with the same problem. I replaced the lid lock switch with the new upgrade kit, though you might need a tec to install it! approx $100.00
Posted on Mar 05, 2011
Simpson eziset 500 will fill but wont wash or spin and then it will empty if I put it on that cycle manually
Go to www.repairclinic.com enter your model number and it will guide you on doing it yourself.
Nov 01, 2016 | Simpson Washing Machines
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
I have a simpson EZI set 750 went to use this morning turned machine on nothing happened no lights on panel
Hello Barney - sorry about your washing machine and I can only offer you this link to some reviews of the machine. A couple of reviews down the page have links to Simpson representatives, who may be able to help you out with the issue. Take care. Kind regards,
Simpson EZIset 22S750L 22S750M
Mar 18, 2014 | Ariston Technologies AWD 121
My simpson eziset 7.5 washing maching does not hold water
Be sure that the drain line is above tub level.
Dec 04, 2012 | Simpson Washing Machines
Eziset 550 Drains as it fills
Replace the fuse inside the control panel make sure you turn if off.
depending on where you are the fuse is more than likly a "4amp slow blow" fuse
hope this helps
Dec 02, 2012 | Washing Machines
My Simpson eziset 650 won't complete a cycle it
The machine has detected that it's taking too long to fill, check the hose filters in the inlet solenoids (remove the hoses and you will see them) make sure your taps are turned up, If all seems ok then you have work inlet solenoid(s) and will need to replace 1 or both of them depending on if it does it on both hot and cold cycles.
Mar 05, 2012 | Samsung Washing Machines
Hi I have a simpson eziset 605 washing machine and it has stopped spinning.. I have checked the belt and thats seems fine the washing machine just wont spin.. if anyone has any idea of what it could be...
Hi Carlee just read your posting.Now the Simpson Eziset machines come in top and front loader versions.Which type is yours?Please reply with this additional information and I will help you rectify this fault.
Oct 03, 2010 | Washing Machines
Washing Machines Logo
1,235 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
