Question about Locks & Locksmithing
Chubb lock stuck in lock position key turns in lock but nothing happens
  • 784 Answers
This happens because, either a stuck ball in the lock is not falling out of the way and not releasing the shackle or the tail end of the cylinder has broke. there are a couple things to try and get the shackle to release --- first, spray some lubrication into the top of the lock around the shackle area and also in the key hole,, let this sit for a few minutes and try the key again. if it still will not unlock - try to turn the key AND at the same time smack the side of the lock with a hammer and see if you can get the shackle to free itself that way. since you will not know what side is which -- try to hit the lock from both sides ( make sure you hold the key in the unlock position while smacking it ). also -- with the key turned, kinda push in and pull out WITH great force the shackle and see if this frees it up. if none of these tricks work you are going to have to grind off with a grinder.
c...
Posted on Jan 02, 2011
How to replace tumblers in ignition switch for 1999 jeep grand cherkee lardeo
You can't remove tumbler unless ignition barrel is remove there's a few ways to remove barrel if not in on position ether drill out locking pin or snap the lock and tumblers to twist in on position so it can be removed I most of the time drill out lock if I can't pick it
Feb 06, 2015 | 1999 Jeep Grand Cherokee
How can I get my scooter seat which is stuck locked in the down position open?
you may have to access the lock mount from under the scooter---you should be able to un screw the lock assembly---remove the mud guard to access the assembly
May 01, 2014 | 2004 Honda Elite 80 Base
Ignition stuck in locked position
you have to turn the key the correct way.
Feb 24, 2013 | 2004 Chevrolet TrailBlazer
The key on my 1999 volkswagen beetle is stuck in the door lock. As the key was held in the unlock position both windows were rolled down. No amount of jiggling or turning and twisting can get the key out....
dont know if you recd my previous so again...unlock/hold over windows go down,lock/hold over windows go up/sunroof closes.(alarm/immobiliser resets)....key stuck in lock, pull hard when upright,moving the key up/down when pulling, should do it.also bootlid lock two positions,turn left,then release or turn right and release,see what happens......(boot isolation from the central locking)
Sep 25, 2010 | 1999 Volkswagen Beetle
2001 dodge durango ignition switch is stuck in locked position
Your tumblers are worn. You can "Bump" the lock to get it to work, but this is a very temporary fix. To bump the lock, simply tap on the end of the key with something heavy like a short 2X4 , the heal of a shoe or something similar - while in the ignition while attempting to turn the key to the start position. DO NOT turn the engine back of until you get the car home or to a repair facility.
Mar 31, 2009 | 2001 Dodge Durango
2002 oldmobile bravada ignition key is stuck in lock position
try and turn your steering wheel a little bit left or right and and the same time try and turn the key when it turns toward the dash then try and turn the key back. try and repeat this several times if neccessary. this should work. please rate this solution. thanks
Aug 30, 2008 | 2002 Oldsmobile Bravada
200 Jeep GC Ignition Stuck in Lock Position
Have you pushed the button behind the key ? Small button between key and dash must be pushed to remove key.
Aug 22, 2008 | 2000 Jeep Grand Cherokee
Key Stuck
Try a different key, if that doesn't work replace lock cylinder.(commom)
Jul 23, 2008 | 2001 Honda Civic
Locks & Locksmithing Logo
810 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
