Question about LG LSC26905TT Side by Side Refrigerator
Like the person with the first question below, I have water coming from under the unit too. I can't budge the machine to check it out, but assuming its the condensate drain pan, as suggested in the answer, what is the solution? The answer suggests that heat from compressor evaporates it, but if that is not happening, what is the problema and what do I need to do? Thanks.
  • 29 Answers
Make sure there is no lint or dust in the fan motor located on the lower back of the fridge.
Posted on Jan 02, 2011
Miele cva 615 water leak
I assume youyr talking about a leak inside the machine and not at front or behind front door. Assuming this I would suggest drying the iside of machine, re-assemblig all covers (to ensure machien is safely earthed) and then make one coffee. Thsi diconnect from mains, open cover and chck where water has come from. It may be that the seatc for the o-rings has a scale build up ad this prevents even new o-rings from selaing properly. regards
I assume you're talking about a leak inside the machine and not at front or behind front door. Assuming this I would suggest drying the inside of machine, re-assemble all covers (to ensure machine is safely earthed) and then make one coffee. Then disconnect from mains, open cover and check where water has come from. It may be that the seat for the o-rings has a scale build up and this prevents even new o-rings from sealing properly. regards
Apr 07, 2014 | Miele Coffee System
Tip
Dishwasher will not run. DW 101 how to fix
Start with the simple things and work your way from there. You will be amazed how many people call a plumber who flips a breaker or simply clears a stuck float valve (for $80 minimal fee).
If no lights are coming on.
First check the breaker to the machine.
If you have an exposed power source to the machine such as a plug or junction box open the box and check the wiring is intact and not rusted etc. Take care here and shut the breaker off first.
No go so far?
Check if your float valve is jammed.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine.
Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
Not the float valve either?
Check the door interlock latch.
Much like a washing machine a dishwasher will only operate with the door closed (or when it thinks it is closed!). There is a metal tab that engages a switch in the door. This is the same switch that activates as you operate the handle to open the door. If it is misaligned it will not signal the machine that the door is closed and the machine will not operate.
You can check this by overriding the locking tab. Put a screwdriver in the door latch and press the switch. You should see the lights come on and power flow to the machine.
Note: if the machine is in run mode you will get water spraying.
To fix this problem bend the tab to properly engage the switch. Or if necessary loosen the screws retaining the switch and move it to correctly align with the tab.
Not it?
OK now you are into electronics.
First is quite simple. Some units have an internal fuse to protect the control panel. Check that first. Take your time and take care. Turn the breaker off.
The control panel is screwed in place. Remove the screws and gently remove the control panel. Take care not to have parts of the door latch fall out or springs drop out etc. On newer units it is very simple as it is just a circuit board. Look for the fuse and check that it is OK. Replace if necessary with correctly rated thermal fuse.
Do you have water in the bottom of the machine?
Power is there, lights are one, seems to want to work. Water will come in but will not drain.
A small amount around the drain is normal for some machines. This is held to keep the pump primed in some units. However it should not fill the bottom of the unit. You know what it normally looked like so it if is full then you probably have a jammed float valve as above or a clog in the drain.
Drain clog.
Remove the cover from the drain in the bottom of the dishwasher. They usually lift out or have a few screws holding them down. Simple to figure out just take your time and try not to force anything. Look for a clog and clear if necessary.
Your drain can run either direct to the drain under the sink or to the disposal unit if you have one. The drain can clog at either point.
Check by disconnecting the drain line from the dishwasher where if connects to the sink or disposal unit. Look for a clog and clear if necessary.
Water exits the machine via the drain pump. If it is not operating the machine will not drain. It will fill usually to the point where the float valve lifts and does its job by stopping the machine before if floods your house.
If you have water in the machine to the point the float valve is lifted then drain it out first.
Your machine should be running now. Lights will come on and it will run again to the point where if fills with water and trips the float valve again. If so then check the pump and timer (see also timer below).
Remove the units as per below.
If your pump is belt driven check he belt (very few have belts).
If direct drive switch the unit on and let if run to the drain cycle. If the pump does not come on check for voltage at the pump during the drain cycle. If you have voltage replace the pump. If not it is the timer that is faulty (see below).
OK now your are getting to some deeper issues. Not necessarily hard but only go here if the simple things are OK.
If you are not getting water into the unit but you have lights on and you hear clicking and the timer runs and things are trying to work then we know you have power and the timer is running.
No water coming to the unit.
Make sure nobody shut the supply line off. There should be a tap under the sink on the water supply line to the unit.
Turn the unit on an listen at the base for a click as the water supply solenoid (electric switch) opens. No click?
Check the solenoid. Remove the machine from under the counter. There will be screws holding it to the underside of the counter. You may have to lower the legs to get it out. They turn with a wrench to lower.
Under the unit where the water supply line comes in is a solenoid switch it opens to allow the water to enter the machine. Water comes in under household pressure (it is not pumped in by the unit). Chances are it is faulty. Replace it as it can't be serviced.
Still no luck?
The unit is guided by a timer. The timer tells the machine what to do and for how long. If it fails the unit will stop or jam in one cycle. If you have a physical switch the you turn to select the type of wash cycle check it. If you are all touch control then replace the whole board or machine.
To check the switch open the control panel above and use a voltage tester to see if you have current at each cycle point. Cleaning sometimes helps if not replace.
Hope this helps you. Please rate this tip for me.
Adrian
on Mar 09, 2010 | Dishwashers
I just got a eam 3500 machine. On first time instructions, no hot water would come out. produces a good cup of coffee though. When i've tried to froth milk for a latte, no milk is added to coffee. I have...
There is a blockage in the steam/ hot water circuit. By trying repeatedly to use these functions the steam boiler has now overheated and blown a thermal fuse ( thats why the alarm is displayed and now the infuser is in the wrong position for removal). If this machine is under warranty you should return it as soon as possible. If no warranty and you are a handy person (genuinely) then post again and i can help you fix it. No Good luck Rick.
Dec 10, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
My dishwasher simply won't start
No go so far?
Not it?
Drain clog.
Still no luck?
Adrian
May 03, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
WONT START LIGHT BLINKING
Following is a complete trouble shooting process. Take what you feel applies to you.
Most probable is that your float valve is jammed.
To fix this problem bend the tap to properly engage the switch. Or if necessary loosen the screws retaining the switch and move it to correctly align with the tab.
Not it?
The control panel is screwed in place. Remove the screws and gently remove the control panel. Take care not to have parts of the door latch fall out or springs drop out etc. On newer units it is very simple as it is just a circuit board. Look for the fuse and check that it is OK. Replace if necessary.
Drain clog.
Still no luck?
Adrian
Mar 14, 2010 | Dishwashers
No water is coming thru the water valve to fill the dishwasher. The water is turned on. I had a Kenmore portable dishwasher and we just converted it to a built-in. The electricity is on and the water line...
Most probable cause a faulty intake solenoid.
OK start simple and go from there.
If your have power and light etc come on then we know you are good for power. I'll assume that is OK.
If you are not getting any lights on the machine you have a power issue or a stuck float valve. That requires another explanation.
Check the shutoff for the water supply to the unit.
I will also assume there is no water collecting inside the unit.
Water enters this machine under city water pressure. It is not pumped in. A solenoid switch opens the system and allows the water in. The solenoid is controlled by the timer. So those at the two things you need to check.
When the machine starts you should hear a click as the solenoid opens. The solenoid in located under the machine. Turn the machine on and listen for the click. If you do not hear a click we have a problem.
Remove the machine. It is usually screwed to the underside of the counter. You may have to lower it by turning the feet with a wrench. Usually you can lift it enough to get it to slide out.
With the machine on in the start of the cycle your timer should be telling the solenoid to open. To test put a test light or voltage meter across the terminals of the solenoid. The solenoid is located where the water supply line connects under the unit. If you have power the timer is working. You would replace the solenoid. If you do not have power the timer is faulty.
Chances are it is the solenoid. Just unscrew, disconnect the water lines and find a replacement part. Installation is the reverse of removal.
Hope this helps. Please rate this answer if it helps you.
Mar 13, 2010 | Dishwashers
Please help me figure out why my Frigidaire dishwaher will not tu
My first guess for you is a stuck float valve. Check below and you will see the process to check.
No go so far?
Not it?
Drain clog.
Still no luck?
Adrian
Mar 13, 2010 | Frigidaire 24 in. PLD2850 Built-in...
No water enter the machine
I will also assume there is not water collecting inside the unit.
Mar 12, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Water won't come on
Mar 10, 2010 | GE Nautilus 24" Built-in Dishwasher
No pump activity
Following is Dishwasher 101.
No go so far?
Not it?
Drain clog.
Still no luck?
Adrian
Mar 09, 2010 | Bosch Dishwashers
LG LSC26905TT Side by Side Refrigerator Logo
47 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
