Question about Apple iPhone 3G
Hi my iphone screen went white, then the phone switched off, now the computer says the USB device has malfunctioned and doesnt recognize it, so cant reboot in Itunes
  • 2,069 Answers
Well you could try to boot your iphone in DFU mode and see if it is recognised. if yes, the itunes will detect it in DFU mode and immediately demand for a restore operation. post back if need more information. otherwise, on how to boot iphone in DFU mode, click here.
Posted on Jan 03, 2011
My apple ihone is disabled connectto itunes
There are many reasons why iTunes will not recognize your iPhone, whether it's dust or dirt blocking your dock connector or a system setting gone wrong. No matter what model iPhone you have, here are a few suggestions for helping the problem of iTunes not recognizing iPhone:
1. Generally speaking, when iTunes does not recognize iPhone, it may have something to do with the version of iTunes. If you are using an old version of iTunes on your computer, it may not be capable of recognizing your iOS devices. So updating iTunes to the latest version is a fastest way to get the problem solved.
2. If you are running iTunes in the latest version, but still can't get your iPhone recognized, you may want to take a look at your computer, sometimes if your computer lacks necessary software, it might lead to the malfunction of iTunes.
3. USB port on your computer can be another reason why iPhone not recognized by iTunes. So you can try more than one USB port to see whether the USB port works well.
4. Of course, your iPhone may also be the cause of iTunes not recognizing iPhone. At this moment, you can restart your iPhone by holding the Sleep/Wake button and Home button at the same time until you see the Apple logo, then connect iPhone to computer with USB cable again.
5. You should also make sure your iPhone trusts your computer, because after changing a new system on computer, your iPhone will regard it as a new computer. What's more, you should check out whether Apple Mobile Device Support is installed on computer.
6. After checking out all the aspects mentioned above, you can try to connect iPhone to computer with the USB cable again.
If none of these methods work out, you may want to try set your iPhone up as new after iTunes not recognizing iPhone. You only need to tap General > Settings > Reset > Erase All Content and Settings, and then choose Set Up as New. When you have set iPhone up as a new device, you are able to connect iPhone to computer with USB cable. But before erasing all contents on your iPhone, you may want to back up iPhone files to computer to keep them safe.
http://www.leawo.org/tutorial/what-to-do-when-itunes-not-recognizing-iphone.html
Feb 07, 2017 | Apple iPhone Cell Phones
My iphone shut down when connect o my computer. i get a error message unknown device not recognize usb
The possible explanation to this issue would be than the usb port is very old or damaged and it doesnt recognize the ipod usb cable
you should try to update the usb drivers or buy an new usb interface car if you have a desktop
Mar 18, 2011 | Apple iPhone Smartphone
My apple iphone USB Device Not Recognize what will
Go to www.itunes.com and download and install itunes, then reconnect the phone. If you already have itunes do this, but realize this will clear the info from your iphone, but if you have the info in itunes, it will sync back anyway. So just know, this does a factory reset:
Turn iphone off by holding power button on top left and sliding the red bar to shutdown.
Now, take the usb cable and have it not connected to the computer, but connect it to your iphone, so now you have the usb cable just connected to the iphone which is completely off.
Now, hold down the circle button on the iphone, and keep it held down. Then insert the usb cable into the computer, while still holding the button down. After a minute or two, you will get a screen on the iphone with a white usb wire pictured on the screen, and if you did it right, the connection should then pop up on windows. After you do the restore, you can then use itunes and plug in the usb like normal, all should be fine.
good luck!
Nov 28, 2009 | Apple iPhone 3G
My EasyCAP doesnt work!~
hi there,
if your usb port is not recognized by your computer anything you want to install in your usb will not function,try to check your usb on device maneger and updated your driver through website,
if your game controler is not recognized by your computer go to control panel click game controler and add your device follow the wisard instruction and install your controler,controler is plug and play device.have a nice day,regards
Jul 10, 2009 | DekCell (CPA-1040)
My sansa screen went white
Try resetting the device by holding teh power switch in the ON position for about 15 seconds, then while it's OFF, slide the power switch DOWN to the HOLD position. Now for the tricky part, let's force a manual MSC connection. Press and hold the center button while plugging in to the USB port. Let us know if the screen lights, and the battery begins charging in this mode. If it's charging, let her charge for a while to give the battery a chance. Then, open a Windows Explorer window. I like to use [Windows key] + E, or go to My Computer. See if the Fuze appears under "devices with removable storage". If it's communicating, you have the options of formatting the device and reloading the firmware.
Jun 06, 2009 | SanDisk Sansa Fuze MP3 Player
Cable connection has malfunctioned
other usb connection did u get?....if u get change ur wire...if not u just install the usb file frm mother board disc
May 06, 2009 | Cell Phones
Iphone jail break
Try rebooting the iPhone while it is plugged into your computer with iTunes running. Hold down the home button and the sleep button for a few seconds to reboot it. iTunes should then recognize the iPhone as being in recovery mode and you can then use iTunes to restore your firmware.
Jun 11, 2008 | Apple iPhone Smartphone
Apple iPhone 3G Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
