Hardly any water is coming into the machine on start of wash
  • Washing Mach... Master
  • 1,527 Answers
Hello, make sure the water pressure is not low and theres no kinks in the pipe also check the water inlet valves see if there they are blocked do this with the power off also the check the pressure switch this usually located at the top of the machine. it's idenified as large circular switch that has several wires and a plastic tube this plastic tube.this sits at the bottom of the washer hope it helps ps if it's still not working get back to me
regards
shaun
Posted on Jan 02, 2011
2 Suggested Answers
  • 25 Answers
SOURCE: Amana washing machine
prob faulty door seal or iff really bad hole in outer tub
Posted on Jul 03, 2008
Hi I have an Ariston washing machine the lights come on but the machine wont start
hi have you made sure the water supply is back on,,also is the door lock connecting properly, good hard close and then a small push,maybe a distant connection if previos wash was a tad to much ad pushed onto the door,,
Jul 20, 2016 | Washing Machines
Have a maytag neptune washer is taking in water but throwing the water back out the hose and not washing it just started today before it would not spin but washed and clothes would come out very very
Too may things could be wrong with it, with out actually seeing it , it would be hard to diagnose this problem..
I believe those are computer controlled.
so it could be a computer problem.
make sure discharge hose is above level of machine, meaning if your hose needs to be vertical to the machine or the water will flow right out. The pump should not be running while the machine is filling. If it is, then that would also indicate a computer problem.
Nov 26, 2014 | Maytag Washing Machines
Water leak from front loading machine
at a guess i would say there is a cut in the rubber seal around the door sometimes its hard to spot it but if you pour a cup of water on the seal and see if the water comes down under the machine if so you wil need a repair man/woman it a hard job
Oct 14, 2014 | Maytag MHWE201YW Laundry : Front Load...
Fills with water, skips wash and rinse cycle, starts spin cycle and sprays water out of the top
I would look at lid switch on this model and plunger to lid .Under lid is spray flume that can be damaged by large loads ,check that close. put it in wash full and drop lid hard it may come on.
Nov 19, 2013 | Maytag Dependable Care LAT9206
Hot water is a small trickle into the machine - warm water gives you a bit more water coming into the machine & cold water has a moderate bit of water coming into the machine. We have extremely hard...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 01, 2010 | Frigidaire FWS833A Top Load Washer
Water does not come into machinetub -front load stacker
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Apr 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
LG WF T6517TC Washing Machine does not fill water
sir
my washing machine WF-T6517TC
when it start to wash get Alarm "dE" beep and stop machine.
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
Dirt in rinse cycle causes clean clothes to come out with dirt all over them and inside of the washing tub has dirt everywhere!
Several things could be happening...The machine is NOT "spitting" all the water out and there is STILL some dirty h2o (water) in the wash. You could be putting in dirty WELL water ? If you have HARD water and your "hard water filter, cleaner not working. Your cloths could be SOOOOOOOOO dirty ( no offence !!! because there are many D I R T Y jobs that could take two(2) washings ) that they are not getting clean.
Aug 31, 2009 | Washing Machines
Water coming in too slowly to washing machine GE WVSR 1060B3WW
NOOOOO don't junk it unless the transmission goes out. then its easier to buy new.... It sounds like you live in an area that has dirty or hard water. Start with turning off water supply to the washer. Then remove the hoses and check the screens in the hoses and in the water inlets on the washer. If they are dirty clean them. If this doesn't solve the problem then have an appliance tech come and change out your water inlet solenoids. that should fix it. The total fix should only be about 50 bucks in parts and the service call. Hope this helps. Good luck.
May 11, 2009 | GE WBSR3140DW Top Load Washer
Only hot water is coming through the washing machine
make sure the hose is not plugged,and if you have hard water claen the skreen,i had the same problem the skreen was plugged.
Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
