Question about Zanussi 18 in. DA4342 Free-standing Dishwasher
My dishwasher isn't rinsing properly, the stuff on the top have bits of veg or other bits on them and the china feels rough and gritty not smooth and clean, I have cleaned the filters, put through a cleaning product but to no avail, any suggestions please?
  • Zanussi Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on May 01, 2011
Milky water when rinsing in dishwasher & gritty covering on dishes
I have spent many years (47) in the catering industry using catering dishwashers, under counter models, corner- wash stations and also conveyer machines..
The milky water is a by-product of the wash water and rinse water mixing.
The spray are has to rotate freely or the dishes won't wash or rinse properly. They spins a lot faster than you realise and this adds pressure to the water, but also a pulsating effect to remove dirt.
Over doing the salt can cause more problems that it solves. The gritty film may indeed BE salt. I actually prefer Calgon as a softener.
My advice is to remove both top and bottom spray arms. Check the slots/holes for obstruction, and run water through them under a tap, outside to inside (the opposite to how it is in the machine) rocking the arms up and down to allow any obstructions to flush out. Lemon pips and toothpicks are out biggest problem! Put the arms back and make sure they spin freely. Sometimes they just lock up for no apparent reason!
Use CLR descaler in the machine to clean it using the instructions on the bottle. Then run the dishwasher using the recommended doses of detergent and rinse aid.
Jan 19, 2016 | Siemens Dishwashers
Which is the best powdered cascade product for the china/crystal setting on my miele?
Most european dishwashers are water conserving and energy saving. You have to be very careful in the type of detergent that you use. Plain, original cascade powder works fine in your Miele. Use 1/2 of the recommended amount, as your dishwasher uses much less water than the american machines that the amounts are written for. avoid cascade with additives such as bleach, or dawn. these additional components in the detergent do not rinse off well with the reduced water quantity, and will leave a gritty white residue on your dishes. Stick with the plain powder. I use Finish tablets with the red powerball, and I dont add rinse aid. These tablets work great in the Miele, asko, Bosch, and other imported dishwashers.
One caution on your china and crystal setting, your manual states that if you want to use the china and crystal cycle, the dishwasher should be connected to cold water only. The temperature of the china and crystal setting is limited to 115 degrees. your hot water is probably much hotter. if your dishwasher is connected to hot water, it will defeat the purpose of the lower temperature cycle. you will get etching on your crystal glasses.
Remember, the Miele will heat its own water one batch at a time. Connect it to cold for energy efficiency, hot for shorter cycle times. but cold only for china and crystal.
Enjoy your machine.
Nov 18, 2010 | Miele G2183SCSFSS Builtin Dishwasher
After my dishwasher is finished everything has a gritty feeling to it,and the glasses have turned all cloudy and the forks have white stuff on them
You are not getting your rinse cycle. It sounds like your wash cycle is starting, then stopping if yo get grit. I take it you are using powder detergent. That is where the grit comes from. It should all dissolve by the end of the wash cycle, which leads me to believe the wash cycle is not finishing. And it sounds like the rinse cycle never occurs. You may have a bad timer which enables each cycle, if I had to guess.
Oct 08, 2010 | Whirlpool Dishwashers
Gritty Dishes
The only thing that can cause grit in the dishwasher is something you put in it or it's not rinsing as it should. As you use tablets we can probably rule that out. If you don't have hard water we can rule that out too.. So next up is not rinsing properly. The spray arm in the bottom of the unit has little holes in it. Many times junk that gets by the filter end up in these holes. When that happens the water will not spray out correctly, your dishes don't get properly cleaned and rinsed. Pull out the bottom rack, you might need a flashlight but you need to look at each hole in each arm and see if they are clogged. Even if you don't physically see anything remove the spray arm and clean it, sometimes stuff will fall back into the arm when there is no more water trying to flow. It is very easy to remove. Anyway, remove the spray arm, pick out anything you see stuck in the holes, run water back thru the holes in your sink and re-install the spray arm.. Hopefully this is your problem. Here is a video (it's not mine) which shows how to remove the spray arm.. good luck !
https://www.youtube.com/watch?v=KZWGrb8ZV3E
Jan 23, 2018 | KitchenAid 24 in. KUDS25SH Built-in...
A gritty feel is left on glasses and some dishes
Hard water! Try Cascade Rinse Aid.
Mar 25, 2009 | Dishwashers
Dishes have soap residue despite using rinse aid. Machine is quite abrasive on coffee mugs etc. Unit is Fisher & Paykel DD605SS
use less soap.....excess soap in the rinse cycle will not allow the dishes to rinse properly causing white etching on the glasses and the dishes will have that gritty feeling
Aug 02, 2008 | Dishwashers
Not washing properly
This D/W should have been re- called ,toooo many flaws.Sorry!
Nov 22, 2007 | Indesit 24 in. D63 Free-standing...
Zanussi 18 in. DA4342 Free-standing Dishwasher Logo
203 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
