Question about Philips Audio Players & Recorders
Unit is AS765C, problems using CD player. Difficult to get it to play a CD, Says "No Disc" but will sometimes play a disc but no more and can't work out how to get it to work again. Thanks deniscolbourn@gmail.com
  • 70 Answers
Could be dust on the laser lens. Can get a cleaning CD which has a small brush to clean it, or if you can see the lens (don't look directly at it when switched on as the invisible infra-red laser is bad for your eyes) then clean it gently with a cotton bud (q-tip).
If cleaning does not fix it and the CDs are in good condition then the laser unit is bad and needs replacing which is possible but might cost the same as buying a new CD player.
Posted on Jan 02, 2011
Testimonial: "Thanks for the advice. I had to remove the CD player from the 3-in-1 and eventually was able to find space to clean the little lens. It now seems OK"
Ford Freestar 2006 cd player not working, says "check player"
test this topics and fix it. God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Jul 25, 2013 | Cars & Trucks
CD player skipping
Make sure the unit is mounted level and not to secured that its pinching down on the unit
Jul 23, 2012 | GE 7-5295 Undercounter DC /Radio Combo -...
CD player reads
Laser dirty or faulty. Try it with a different audio CD. Usually its easier to replace the whole thing than to take it apart and change the laser unit.
Jun 20, 2012 | Teac CD-P1250 CD Player
"No disc" message while CD is in
either a dirty or bad optical pickup in the unit that reads the disc so it can play.
Jun 15, 2012 | Cambridge Audio Sonata DV30 Player
Panasonic BD35 won't play blu ray discs, but will play dvds
You may have come close to what the issue is---Blu Ray for several design reasons is much more critical than DVD---seen a lot with this issue----either a dirty or a failing optical pickup in the unit---I know as when first started seeing it in our shop changed a few and since under warranty found the answer--optical unit was the problem---shortly after that they started just exchanging the cheaper units.
Jun 13, 2012 | Panasonic Televison & Video
Cd player won't play disc it says
Hello
Clean the laser pickup lens by insert a lens cleaning disc into the set, and play it at least three times. If it does not help you. replace the laser pickup unit, with same type and number. OK.
Jan 19, 2012 | Panasonic Audio Players & Recorders
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    Will not play dvd's plays cd's
    Just like my Samsung unit, it sometimes play, sometime not, Try different dvd, if one plays, leave it playing until finish, try another one and so on. dvd machines need to have some exercise too
    Aug 09, 2009 | Zenith DVP615 Portable DVD Player
    Denon CD unit will not play due to err
    The problem is in the mechanism,maybe when you put another disc while playing that is cause. There is a misaligment there in the tray you better checked it out,and also the lense by using a cotton buds.thats all for now Hespbb....
    Jun 19, 2008 | Denon Audio Players & Recorders
    176 people viewed this question
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
     Grubhead
    Grubhead
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
