Question about Smeg 18 in. STX45-1 Stainless Steel Built-in Dishwasher
SMEG STX45 built in dishwasher. E1 message do not have the user manual. It is trying but does not seem to be able to draw in water? more recently its been checked by a technician as it was tripping the fuse box, technician circuit tested and said it was fine?
watugot
  • 290 Answers
SOURCE: dishwasher is tripping off our safety switch
It depends on what kind of test he was doing. He was probably checking the amp draw which checks how much power the whole machine was pulling. This would be the way to check the problem you have as long as he checked it with everything running, motor, heater,..etc. If you find the amp draw to be too high, then you go to individual components.
Posted on Oct 05, 2007
zeusfaber
  • 247 Answers
SOURCE: smeg dishwasher
The second problem is almost certainly a symptom of the first - leaking water is reaching some of the electrical terminals and shorting them to earth.
First thing to do is to make sure the strainer in the bottom of the cabinet is clear - if it's really badly choked, you can brew up quite a spectacular flood.
After that, best I can suggest is to move the machine onto a piece of dry carpet, run it for a short while and see whereabouts the carpet gets wet first. Use this to guide your subsequent leak-hunting.
If there's any hint that the leak is from the front of the machine, check the seal between the lower edge of the door and the bottom of the washing chamber. On some machines, this gets covered with a thick layer of hardened grease (which is fine, until bits of the grease start to break off). If this is your problem, scrape the remaining gunge off, give the metal surface a good clean,and expect the last vestiges of the leak to cure over the next couple of washes as the seal recovers its proper shape.
Next thing to look for is the device which senses when the machine is full enough (and tells it to stop filling). Let the machine get to the stage when it is leaking nicely, then turn it off, open the door, and see if the cabinet has filled to overflowing. If it has, then drain it, then unplug the machine and take the back cover off. Look for a thin hose coming out the bottom of the washing chamber and running up to a small unit mounted on the case some way up with a pair of wires going to it. Check this hose for cuts, splits and blockage.
If the leak is coming from further back, then you are going to need to look inside to see how much of the inside of it is wet. Use this to guide you to where you need to do a more detailed inspection.
Check all the nearby hoses, looking for splits - especially where they push onto fittings, cuts (especially anywhere they're pulled over sharp edges) and just generally to see if they've pulled off completely.
Next, check any plastic fittings in the area to make sure they haven't cracked, and look to see if there's any evidence of water seeping out of the joints between the different fittings (in case you've blown an O ring, rotted a gasket away, or just had some screw work loose)
A.
Posted on Apr 13, 2008
  • 1462 Answers
SOURCE: SMEG DWI410 TRIPS CIRCUIT LATE IN WASHING CYCLE
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Posted on Jul 18, 2008
SOURCE: Dishwasher Smeg DWD409SS
Hi
Please go to www.smeg-service.co.uk/support
Posted on Aug 21, 2008
SOURCE: Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
Posted on Dec 09, 2009
Dishwasher tablet not dissolving when dishwasher beingrun
is your water or water temperature setting too cold? The hotter the water the better chance to dissolve the tablet.
Maybe try running on the heated or sanitize cycle to see if it works better. I always run the sink tap until there is hot water coming out before turning the dishwasher on....
Sep 08, 2013 | Smeg 18 in. STX45-1 Stainless Steel...
How do I clean the inlet water filter on built in 18" dishwasher
Hello, neil
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Sep 27, 2011 | Smeg 18 in. STX45-1 Stainless Steel...
What is error code E1? Dishwasher is not drawing in water on any programmes and this is the code I get
I get this a lot. Its due to a leak inside the bodywork, letting water build up in hte base and operating the float switch. You will have to pull out the dishwasher, tip it backwards and mop up all the water that comes out. (usual precautions about turning it off etc apply). That will get it going. Then find the leak. Mine leaks from the O ring seals on the air break chamber inside the right hand cover. I have used silicon sealant in the past, but I need to remove it and replace the O rings. Trouble is, I cant see how it comes undone on the inside (is it a bit nut?)
Kinata
Aug 16, 2010 | Smeg DWI614 Built-in Dishwasher
My dishes are still wet after the cycle has finished why?
Hi.
Ensure that there is no water at the bottom of the tub. If there is water, check drain well and drain hose, then test pressure switch in the drain system.
If there is no water, the the thermostat (or the dryness) sensor must be replaced.
In that case, cintact Smeg at the number listed on the owners manual.
Regards.
May 02, 2010 | Smeg 18 in. STX45-1 Stainless Steel...
My Smeg dishwasher model DW1 410 is not drawing the water any more.
More than likely water inlet valve is bad. Maybe replaceable.
Nov 04, 2009 | Smeg CSU2001 Built-in Dishwasher
Missing Instruction manual smeg dishwasher SA945X
try going to servicematters.com. You can download owners manuals there.
Apr 03, 2009 | Smeg 18 in. STX45-1 Stainless Steel...
Circuit board?
Please refer to the user manual, That is near the input power.
melnavz
Jul 28, 2008 | Smeg 18 in. STX45-1 Stainless Steel...
Hi
Jun 22, 2008 | Smeg 18 in. DWD409SS Built-in Dishwasher
Dishwasher stops after rinse
Seems to be an error with the float switch on the anti flood device http://www.smeg-service.co.uk/support/index.php?a=1&cat=4
Apr 18, 2008 | Smeg 24 in. STX2 Built-in Dishwasher
Smeg 18 in. STX45-1 Stainless Steel Built-in Dishwasher Logo
54 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
Garth Jackson
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
