Question about One For All URC-3021 Remote Control
I need code for mute - One For All URC-3021 Remote Control
  • 139 Answers
I can't get the TV to mute. The AV receiver mutes, but the TV won't. I can't get the volume to go down on the TV either.
Go back through your list of codes and try all codes for you TV model or allow the remote to scan for the code. You need the booklet that came with your remote.
Dec 31, 2010 | Logitech Harmony One Advanced Universal...
Somone reset the parental code and we cant unlock it, have tried 0000 and it doesnt work. is there any way to rest the v-chip itself?
Try to reset factory defaults with the folllowing, either sequence or both together may work:
1+mute+1+mute (mute=mute key on remote)
3+mute+3+mute
Aug 29, 2010 | Sceptre X400BV-FHD 40 in. LCD TV
Same problem as don5625.my moxi box will not control volume mute or power on my olevia lcd hdtv
Is this the style of Moxi remote that you have?
If so try these steps to find your TV
1. Turn on the power to your TV.
2. Press and hold down the MOXI and OK buttons.at the same time until the LED at the top blinks twice.
3. Press the numbers 9910 on the remote and the led should blink twice again.
4. Press the mute button. If the TV mutes then press OK to lock in the code. If the TV does not mute press the up arrow once then press mute and continue to press the up arrow once then press mute until the TV mutes once the TV mutes press the OK button to lock in the code.
*** Note this may take a couple minutes of trying to cycle through the code list to find which one will work with your TV *****
Good Luck...
Jan 05, 2010 | Olevia LT37HVS 37 in. LCD HDTV
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
I to just purchased a sylvaniia LC370SS9 and cannot get the right code for a charter moxi DVR remote no help from charter and tried all the codes from sylvania and all there other brands
Good Luck...
Nov 06, 2009 | Sylvania LC320SS8 32 in. LCD Television
Need code for oriton dvd 600
Hi! kindly try this one, i hope it will work on your unit.
With no cd in, press MENU, 1, 6, 7 and MUTE (unlock all regions)
Or
With no cd in, menu, 9, open, 5, mute.
Aug 11, 2009 | Televison & Video
Need instructions for this SK64002 Zenith model remote I can't seem to get it programmed and can't find any instructions anywhere.
Zenith SK64-002 remote programming. Begin programming by holding down the power and mute buttons together until the red LED stays lit. Remote codes are entered like this: Use V- for first digit. CH- for second digit. V+ for third digit. When you are done, press the mute button (small button in center) to enter. Example: Older Sony TVs are code 801. Press the V- button 8 times. (The CH- button doesn't need to be pressed since the second digit is zero.) Press the V+ button once. This is how you enter the code for 8-0-1. Press Mute to save.
Mar 30, 2009 | Televison & Video
Moxi remote control
The "universal code" 9910 is just the first step in doing a program search. Hold down the MOXI and OK buttons simultaneously until you get the double blink. Then enter 9910 and it will blink twice again. Then begin alternately pushing MUTE and the up arrow (above the OK button). Pushing the up button effectively cycles through the codes and pushing MUTE tests the current code that it is on. Do not go too fast because when you finally push MUTE and it actually mutes (or unmutes) your TV, you must push the OK button to store that code. I just performed this procedure and my first positive code that I stored only affected the mute and volume settings on my TV and would not turn the power on or off. If this happens to you as well, repeat the above process and just skip over the first positive you get until it mutes (or unmutes) your TV again.
Oct 18, 2008 | Televison & Video
NEED CODE
HAI, TRY ANY WILL ONE WORK.
1.PRESS TOGETHER SLEEP AND MENU SWITCH IN REMOTE,AFTER PRESS SLEEP SWITCH AGAIN.
2.PRESS MUTE SWITCH ONE TIMEAND RESS ONE TIME AGAIN.WHEN MUTE SWITCH IS KEPT PRESSED THEN AT THAT TIME PRESS MENU SWITCH IN TV FRONT .
Jul 05, 2008 | Televison & Video
One For All URC-3021 Remote Control Logo
26 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
