Microsoft ISATAP adapter #4 dosent work, error code 31. how can i fix it? i need to do something cause the internet dosent work(wifi)
    Brigadier General:
  • 8,909 Answers
I would uninstall the driver by going into control panel, selecting Device Manager and finding the yellow marked driver. Click on it and remove it.
When you re boot the laptop, the OS will place a fresh driver there and hopefully that one will work. If it doesn't, the WiFi board may well be faulty and a replacement may well be required.
Hope that helps.
Posted on Jan 02, 2011
Need new download of ISATAP drivers
Greetings,
On a Windows Vista-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark (!) next to it in Device Manager.
You can safely ignore this error message. This error message does not indicate a problem with the adapter. The adapter will continue to work correctly.
Check out this article for more information on this:
http://support.microsoft.com/kb/932520
If this is still not working,
First try to reset Winsock from command prompt, this will reset all the Network components to default:
Click on start, type CMD,'Right click and Run as Administrator'.
At the command prompt type:
netsh winsock reset catalog
In such a case, I suspect this problem to be caused by network adapter missing or corrupt. Please firstly reinstall the driver for your wireless network adapter. Then try to reinstall Microsoft ISATAP using following steps:
1.In Device Manger, right-click the item of Microsoft ISATAP and select Uninstall.
2.Still in Device Manager, click Action and select Add legacy hardware.
3.Click Next, and select Install the hardware that I manually select from a list (Advanced), click Next.
4.Select Network Adapters and click Next.
5.Select Microsoft in left panel and Microsoft ISATAP Adapter in the right panel.
6.Click Next and finish the remaining wizard.
Hope this helps you to solve the issue. Please do vote or provide feedback on this solution, your response will be appreciated.
Thank you and Kind Regards
Gowtam R
FIXYA Solutions Engineer.
Mar 18, 2013 | Microsoft ISATAP Adapter
ISATAP Code 31?
receive error code 31 if the device driver is not updated.
As you have already updated the device try reinstalling the device driver and check if that works, if that does not resolve the issue you may ignore the error message, below link will you go more information related to this issue:
On a Windows Vista-based computer or on a Windows Server 2008-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark next to it in Device Manager, and you also receive an error message
http://support.microsoft.com/default.aspx/kb/932520
Steps to uninstall and reinstall the device driver:
Uninstall and reinstall the device from device manger. Steps to uninstall the device:
i. Click Start, type devmgmt.msc and press enter.
ii. Locate Microsoft ISATAP Adapter device
iii. Right click on the device and select uninstall
iv. Restart the computer for the changes to happen
Uninstall and reinstall the adapter from Program and features. Steps to follow
i. Click Start and choose Control Panel
ii. In Control Panel double click on the "Programs and Features" icon.
iii. Here you can find all the programs and items which are installed in Windows Vista.
iv. To remove adapter click once on the program and then click on Uninstall/Change and follow the prompts.
hope this helps
Jul 03, 2012 | Microsoft ISATAP Adapter
Microsoft ISATAP Adapter This device is not working properly because Windows cannot load the drivers required for this device.
ISATAP is Microsoft trying to allow IPv6 to function over an IPv4 infrastructure, however, it was released extremely prematurely, and as a result, doesn't like to work, or install. According to Microsoft, your computer should continue to function without ISATAP functioning,and the error message may be ignored. However, if you believe that this may be causing you some problems, then you may navigate to the device manager ( Start > Control Panel > Hardware and Sound > Device Manager ) from this window, see if you can find ISATAP adapter and 4TO6 adapter, right-click these, and select "Disable" NOTE: this may cause Internet Explorer and Windows Mail to run slower and have a few errors.
I hope this helps!
May 08, 2011 | Microsoft Computers & Internet
Hello, i have a hp notebook which code 31 error on
Microsoft says to Ignore the problem, and the adapter will continue to work correctly. If the message is really annoying maybe you can try turning off IPv6.
Control Panel\Network and Internet\Network Connections
right click your network card>properties
uncheck the IPv6 box
that'll turn off IPv6-then just disable the adapter driver
Feb 23, 2010 | HP Pavilion dv6000z Notebook
I have windows vista home premium on my home computer and have been experiencing some internet disruptions. The only two ways I have found to reset the internet connection is (1) unplug my router and then...
In the Control Panel, update the drivers. If still unsuccessful, delete those adapters, restart your workstation and reinstall drivers. Helpful to have another workstation nearby in case you need to download the drivers from the Internet.
Jun 10, 2009 | Computers & Internet
ISATAP adaptor
you have ipv6 enabled, this is to help the worldwide convergence to ipv6 form ipv4 . were running out of addresses if not already have ran out.
so from what i can tell it works with the tunneling adapter. altho it is still doing stuff on your computer, it's needed to make the internet work right now, if anyone of you have a "microsoft wi-fi miniport adapter" all of a sudden and you also don't like that you can't get rid of it unless you go to the web and download the old driver.
neither the miniport or the isatap adapter are actually "needed" you can get by without isatap if you either disable or uninstall ipv6. virtual wifi isn't needed, but it's uber cool cause it's for your wireless card and if you connect wireless to the internet, it will let you wirelessly share out that connection wirelessly , (like your a wireless router)
i think i should not that "eventually" you will need to install ipv6 to browse the internet.
more importantly it actually isn't designed to be a "TAP" but it certainly could be the target of hackers in the future including the mini-port (only because they are both new)
http://www.istartedsomething.com/20090516/windows-7-native-virtual-wifi-technology-microsoft-research/
http://en.wikipedia.org/wiki/ISATAP
Oct 05, 2008 | Computers & Internet
Re-install microsoft isatap adapter
reinstall windows vista and when it comes to a screen that says repair new os or boot you want to hit repair this will initialize vista program to install back in what has been taken out and go threw instructions and follow them till completly done
May 31, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
470 people viewed this question
David Payne
David Payne
