How do i double click an item on the i pad? - Computers & Internet
    Brigadier General:
  • 8,909 Answers
Tap on the item twice, quickly.
Hope that helps.
Posted on Jan 02, 2011
I only want to use the left click to click on items and not thave the touch pad click on items
Yes, depending on what mouse you have, most of the time you need to install it, if its not installed, go to the control panel, select the mouse category, This will help install the drivers. Should solve the problem. If mouse driver is installed, control panel, select mouse category, and a mouse properties box will display.. check to make sure the switch primary and secondary buttons option is not checked.
Jan 04, 2013 | Acer Aspire One Kav10 Netbook
Hp laptop synaptics touchpad light comes on and shuts off pointer
Had this problem before, very annoying! On mine the idea was double tap to disable the track pad and then double tap again to activate it... In reality tapping rapidly in the area around the LED until the LED shut off seemed to work.
In short; double tap the LED to reactivate the track pad. If that doesn't work tap several times in quick succession until the LED turns off.
Dec 18, 2012 | HP Computers & Internet
Touch pad double click is not working. How to cure?
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected in xp
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
for the double click this will be in the folder options follow previous to get to control panel items
click start control panel navigate folder options tick in the double click to open circle
hope this helps
Jul 09, 2012 | Dell Computers & Internet
How do i turn on touch pad
You probably have a Synaptics Touchpad. What you have to do is look for the Synaptics logo(it's like a white circle on a red background) in your status bar(lower right corner of the scree, neer the clock). Double click that icon. A window called Mouse properties appears. The last tab is Device settings that also has the Synaptics Icon. If you click it you should see a list of all Synaptics devices on your laptop. Since you only have one you will only have one item in the list. Double click that item and a new Properties window will open. You have a list on the left side of that window. Select tapping and make sure Enable tapping is Checked. That should be it.Good Luck!
Nov 16, 2011 | Compaq (153515-001) Touch Pad
How can i return the double click in the key pad....
Open My document >>> click Tools >>>Folder Options... >>> locate Click items as follows >>> (Choose the lower one)>>>Double-click to open an item(single click to select)>>> Apply >>> Ok
akee_akee@live.com
Aug 14, 2011 | Acer Aspire One D255 Netbook
My mouse on my satellite a660 scrolls up,down,left and right without a glitch but i can't get it to double click and enter to open up pages. on the opening windows 7 blue page where the little icon...
hello friend,
I THINK THE PROBLEM IS FROM THE MOUSE PAD, I THINK IS EITHER YOUR HAND IS WET OR SOME LITTLE WATER POURED ON IT, IF NOT, THEN IT IS DEVELOPING SOME FAULTS THAT I THINK MAY TAKE SOME TIME. PLEASE IF YOU CAN LOOK FOR AN EXTERNAL MOUSE TO USE FOR THE MINE TIME NOW AND AVOID TOUCHING THE MOUSE PAD FOR SOME TIME THEN I THINK IT WILL COME BACK TO NORMAL LATTER.
Jul 11, 2011 | Toshiba Satellite A660-BT2G22 Customizable...
How do I turn off the double click function of the mouse pad on my Inspiron 1525 keyboard? I just want the click funtion on the left and right buttons but not the finger pad.
For this you need to follow the following steps:
Click on Start-> Control Panel -> Click on Classic View-> Select Folder Option-> Under General Tab-> Selct select item as follows->Select single click to open item-Click on Apply and then Ok.
Your issue is resolved now.
Take Care
Enjoy :-)
Apr 30, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Touch pad too sensitive, it always messes me up when I'm typing
You could try adjust the touchpad settings. Sometimes there is a touchpad icon in the taskbar that you can right click on to adjust the properties. You can also disable the pad and use a USB mouse instead.
Sep 11, 2009 | Sony 4-660-223-01 Touchpad Keyboard
Synaptics touch pad, double tap not working
look in the sys tray, (lower left of screen) one of the icons will be concerned with the touch pad. you can turn on and of the double tap here. Sounds like yours is switched off.
Nov 04, 2008 | Logitech V220 Mouse
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
