Question about Sennheiser RS 120 Consumer Headphones
My Sennheiser RS 110 headphones won't work. I followed the installation directions but all I get is static. What else can I do?
    Novelist:
  • 155 Answers
First thing is you need to have a signal going to the headphones for them to work.
If you are getting a signal the green light should be lit.
If only the red lamp is lit the headphones are not getting a signal.
If hooked into a television you should have them plugged into a Fixed Output not variable output..
If you only have a variable output then you must turn the speakers off on the television and then turn the volume up on the TV in order to send a signal to the headphones.
If you are using a amplifier make sure you are using the correct output. Tape Monitors generally will not work as this output is not amplified.
Lastly try using an rca to headphone adapter and plug them into a headphone jack.
Don
Posted on Feb 12, 2011
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sennheiser Master
  • 1,001 Answers
Headphone is easy to pair to most Smart Phones and Bluetooth-enabled Tablet.
You can wear the earphone while you're running or working out, and do not have to stick your iPhone in pocket.
make you enjoy the exercise. Amazon com Bluetooth Headphone Charm sonic for Gym Runing Exercise Sports...
Posted on Dec 14, 2016
My sennhauser 110 only work on left speaker ,nothing ,no sound on right?????headphones
The first thing to do is to disconnect the Sennheiser wireless unit and try another headphone, preferably a cable type and see if both channels work. If the sound is OK on both channels, the fault is within the headphones. If you are lucky it will be the wireless unit plug or the cable and can easily be tested and repaired by somebody familiar with electronics. Otherwise you will probably need to have it repaired by a service shop or a technician. I hope the guarantee is stilll valid.
Sep 16, 2015 | Sennheiser RS-110 Wireless Headphones
No power sennheiser rs120
Probably a defective item, Try for a return.
Oct 13, 2014 | Sennheiser RS 120 Consumer Headphones
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Mar 20, 2014 | Sennheiser RS 120 Consumer Headphones
Till yesterday Seinnheiser rs 110 worked fine when i switched it today only one speaker is working i.e is right speaker.I thought batteries were weak then i recharged but have the same problem.When i tried...
  • The wiring has disconnected inside your headphones. They will not work unless you have someone re-wire the headphones for you. This happens after time with most headphones.
  • Please reply if you have any more questions. Good Luck!
Jul 07, 2011 | Sennheiser RS 110 Consumer Headphones
I am attempting to use my sennheiser rs 110 headphones with my lcd-led tv. the componet jacks coming out of the transmitter are red and black. All my componets on the tv are red and white. so when i plug...
What are you plugging your 2 RCA connectors (from the headphones) into on the television?
You are correct, usually:
White = Left Red = Right
In this case
Black = Left Red = Right
Not sure....guess some manufacturers need to be different...
Back to the issue,
You to need to connect the Black to White and Red to Red to the TV BUT you need to make sure you are connecting to an OUTPUT and not to an INPUT on the TV. Most newer TV's do have an "audio out RCA jacks" on the TV but not all. It should be labeled at the connector if it is an output, or just another input. You can always consult the TV manual to be sure.
Few things you can do to test
  • Does your TV have a "headphone jack", use the adapter (2 RCA female - 3.5mm connector) to plug into the headphone jack and see if there is sound
  • Connect the Black and Red RCAs from the headphones directly to the another output, like a DVD player, CD Player etc....
I hope this helps,
Magoo
Mar 10, 2011 | Sennheiser RS 110 Consumer Headphones
I need replacement ear cushions for sennheiser wireless headphone RS 110 (HDR 110) or some equivalent air cushions that would fit into the RS 110. Thanks
Check out My tip on headphones, at the bottom of it you will find a link to a place that should have them. Just click my user name to find the tip.
Feb 16, 2011 | Sennheiser RS 110 Consumer Headphones
Turns itself off every 5 min to extremely loud static
If you're using a mac, I've made an instructable on how to make this a little more bearable..
http://www.instructables.com/id/Wireless-Headphones-3-minute-transmitter-cut-off-f/
Hope it helps..
Rob.
Jan 16, 2011 | Sennheiser RS 110 Consumer Headphones
No sound thru my Sennheiser RS 110 headphones!
check with the manufacturer's website . Perhaps they have technical support
Jun 01, 2009 | Sennheiser RS 110 Consumer Headphones
No power to transmitter rs 110
it powers only when there is sound input
Jul 29, 2008 | Sennheiser RS 110 Consumer Headphones
Unable to listen to my wireless
They need a minimum level of signal to switch on the transmitter.
Verify if it works on yet another system.
Make sure you have the right output on your Samsung.
Try to increase the output level of your Samsung...(up the volume, but it may be a fixed output..)
Dec 02, 2007 | Sennheiser RS 110 Consumer Headphones
Sennheiser RS 120 Consumer Headphones Logo
3,327 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
