Question about Philips 32PF7321D 32 in. LCD Television
I have a Philips Ambilight 32 PFL 7623D model and the bulbs on one side of the tv are no longer working. Are they easy to get a replacement and if so where from and approximately how much??
    Brigadier General:
  • 8,909 Answers
It is unlikely that all the bulbs have failed at once and more likely that the ballast unit for that side has failed.
If they are available as a spare part they will be listed on ebay as the bakkast unit for your model/size TV or on the manufacturers web site through an authorized repair centre.
Hope that helps.
Posted on Jan 02, 2011
Is there a way to get screen mirroring to work with my Philips 55 pfl 4909/f7
Miracast Samsung - Philips - Support Forum
www.supportforum.philips.com > Forum > TV Forum
Jan 2, 2014 - 13 posts - ‎8 authors
I have a PHILIPS 42 PFL 5008H and a Samsung Galaxy S4 ... Samsung havecompletely butchered Miracast support on their ... Now my TV not seeing sgs4 onscreen mirroring but see it on wifi ... They answered me that the miracast function doesn't work with Philips TV ! .... Last Post: 07-11-2014, 11:55 AM ...
How can I do screen mirroring from my Galaxy S6 to a Philips HD ...
forums.androidcentral.com > ... > Samsung Galaxy S6
Apr 12, 2015 - 14 posts - ‎9 authors
First of all I dont know how to enable screen mirroring on my TV. ... You'd have tohave a compatible Samsung Smart TV in order for the built-in wireless screen mirroring to work. ... I have a Samsung smart TV and I tried to connect my phone to it last night. ... If it doesn't, the Chromecast is the best choice.Missing: 55 ‎pfl
Jan 08, 2016 | Philips Televison & Video
I have a philips tv model number 32 pfl 3805h/12 and was wondering if i can watch movies from an external hard drive? what format does the hard drive need to be?
Your TV does not have a USB port so you cannot connect an external HDD and stream movies on to the TV. But you can buy a HDD based media player which has the necessary output sockets as well as all kinds of decoders built in to stream movies on to your TV.
Apr 26, 2011 | Philips 32PFL5603D 32 in. HDTV LCD TV
Philips widescreen flat TV model #50PF9966-37 50" plasma, as the tv warms up a loud hissing sounds comes from the back. The hissing sound does not go away when you mute the broadcast sound. when you change...
From what I'm seeing online, the bulbs in the Ambilight may be the culprit. I also read that a firmware upgrade could fix the issue too. There was also a recall of some TV's with that issue, so I would check with Philips about your model and serial number and see if your TV was included in the recall. If you raise enough cain and threaten to never buy from them again, they may get your set fixed for you... even if the warranty is up!
Good luck and please post feedback!
Oct 10, 2010 | Philips Televison & Video
The philip 50inch plasma tv i own has ambilight on both sides of the set. the light on the left side of the tv no longer seems to be working. is it simply a matter of changing the light on the tv...
you must replace the circuit board that illuminates display....you will see two(2) boards that look alike...take back off tv and you will understand.....1 of the circuit boards is bad and must be rebuilt or replaced!!!ckt boards are on the sides of TV...only 1 of them bad they both look alike . gl
May 19, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
50 in philips hd plasma with ambilight model number 50PF9631D/37
The x-sus and y-sus panels have some fuses,check to find out wich panel is broken and replace.
Sep 04, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
50pf9631d ambilight has gone out on one side, how do I repair it with out paying philips (or an authorized dealer) outrageous rates, for a problem that has clearly affected MANY Ambilight owners? This is...
ok its possible it is the light itself which would be cheaper- or- it could be the ambilight driver- each ambilight has a driver that tells it to turn on supplys power etc-its not difficult to change-usually located on either one side and the lights all run from it or one on each side-depends- its small rectangular and you can follow the wire from the light back to where it plugs in to the driver- try shopjimmy dot com for parts
Aug 18, 2009 | Televison & Video
I have a philips 42PF9641D/10 and the ambilight on the left side will not come on (lcd tv) any ideas? On turning on the TV both ambilights came on then the left side went off after about a minute!
probably you got a processing unit problem, which makes your tv stopping recognizing the screen information .
you should try resetting all factory default settings, if this doesn't work, you will have to take the TV to an assistance center .
Jul 30, 2009 | Philips 42PF9631D 42 in. Plasma Television
Just bought a philips 42 inch ambilight plasma t.v,and didnt know the plastic screening round the out side is supposed to light up, how do i go about setting this up?
Bottom left button on your remote should turn the light on and off. if this doesn't work sort through the options on remote and select ambiant light functions
Mar 12, 2009 | Philips 42PF9630A 42 in. Plasma Television
How do you turn the Ambilight on our philips tv?
Hi guys, I have the same model, and after reasing the manual a little closer and skimming the setup menu I've discovered that it's not actually a built in ambient light, it's actually a setting in the picture menu under "active control" that measures the ambient light in the room and adjusts the picture quality accordingly to ensure the best contrast and reduce glare/reflect imaging. Hope this helps....
Jan 02, 2009 | Philips 32PFL7332D 32 in. LCD HDTV
Ambilight bulb not working
can u change bulb if not workin
Oct 05, 2007 | Televison & Video
Open Questions:
Philips 32PF7321D 32 in. LCD Television Logo
487 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
