We received system problem with no display...then we replaced mainboard.after replacing it ,when i switch it on display is coming but it is splitted into six...BIOS screen also like that.... i replaced the mainboard two times..and i swapped the same lcd and cable to another system that it was ok..lcd ,cable and invertor card is good...motherboard also good....what will be the problem ? i think there is only supporting problem..can you help me
    Brigadier General:
  • 8,909 Answers
If you go back to basics, it may show up the error.
Remove the hard drive connectors. Remove the RAM. Leaving a basic "empty" motherboard with just a video card or onboard video working, power it up. The mother board should POST. If it does, and ignore the BIOS whingeing that it has no toys to play with, I would say the mother board is OK.
Then add RAM and test again. Then add hard drives.
If the display shows multiple pictures, it is possibly set at the wrong resolution. With the machine basically working, now is the time to set up an 800X600 basic SVGA resolution. After that is should be a case of downloading the correct drivers for the hardware.
Hope that helps.
Posted on Jan 02, 2011
I have an Olevia Model #: 747-B11 P/N: FM1-047000E-S00 S/N: VLCD 79140278 Unit comes on gives you the Olevia screen than you get "NO SIGNAL" at the left bottom corner. Cannot switch SOURCE...
Hi Hernould,
First of all thank you for posting your question here at Fixya.com.
My first advice is to do system reset by unplugging the unit from the outlet(AC source) for at least 1 hour to refresh it and back to factory settings.
If the symptoms remain the same after the system reset, this is an indication that there's a faulty board inside. The symptoms you've described indicated that the T-con board, inverter board, power supply board, backlight of your unit is working but there's a problem on the mainboard that's why it display the words "No Signal" and unresponsive to remote control and front panel button key.
The mainboard has a lot of circuitry that has each functions. Suspected faulty circuitry on the mainboard are the Microcomputer, AV circuitry, I/O circuitry, EEPROM. Click it HERE for the mainboard replacement.
But before you replace the mainboard I would advice you to inspect the electrolytic capacitor on the power supply board feeding the mainboard. If one of the supply voltage is gone to malfunction, the circuitry on the mainboard will be disable. Check the encircled capacitor.
Most of the faulty electrolytic capacitor has a physical indication of fault like bulged/dome at the top and can be easily identify through visual inspection. See sample picture below of faulty capacitor with dome at the top.
Also, don't forget to check if your unit is under warranty period before an attempt to open the back cover, avail it because the manufacturer will fix it for free.
Please let me know if you need further assistance.
Rating and feedback are highly appreciated.
Have a nice day!
Good luck and take care!
Kind Regards,
Mjsazon
Dec 09, 2011 | Olevia LT37HVS 37 in. LCD HDTV
When power is turned on, standby light comes on normally, but in any playing mode, the receiver switches off and the standby light flashes.
It looks like this is a common problem with a lot of the Sherwood Receivers. I've had the same problem with my R-125RDS for a while now. Finally hit on solution today by replacing a power transistor. The transistor in question is not on the power amp board but instead screwed to the chassis and wired to the mainboard. I believe it is part of the output short protection circuit. In my case the component was a 2SD2059 (silicon NPN 100V,5A) replaced by equivalent 2SD1407. The transistor seems to run pretty warm so I guess this is why they ultimately fail after a few years.
Sep 17, 2011 | Sherwood RX-5502 Receiver
Hi Swithced my pc on and have no display. couple of days ago pc switched off by itself. New powersupply installed but problem still persists. please advise Regards A
It sounds to me that your computer mainboard is faulty.
I have created a published guide entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Note the section on clearing the BIOS/CMOS.
You could try replacing the silver 3V battery on your computer mainboard.
I think it may be a dead capacitor some-where on your computer mainboard, some technicians will replace it for you.
Thumbs up!
damnor01
Jan 16, 2011 | MSI 915G Combo-FR Motherboard
Power button flashing but tv wont come on
The switch mode supply is working and the microprocessor is allowing the power to switch on but with errors.
The back panel must be removed so that you can start to check if the mainboard is receiving the +B voltage required for the switch on.
Check the 130 volt to the output ( LOT) if it is absent check if the driver is short or if hte LOT is short.
Remove the main lead and if the voltage comes up the LOT is faulty.
Order and replace
Sep 01, 2010 | RCA F32650 32" TV
White display when switch on
This often happens because of a faulty display, poor connection or a faulty mainboard on the phone.
if reconnecting the display doesn't help, and if replacing the screen does not help, then the phone is faulty, it needs to be repaired by a experienced professional, as the phone is too small and complex to be repaired at home in most cases.
in most cases the repairer will simply replace the mainboard to another one.
If you are outside of warranty, I might consider a new phone, if you are in warranty, use it.
Aug 15, 2010 | Sony Ericsson K610i Cellular Phone
DS lite displays wrong colors on top screen
I agree, applying pressure should (key word) not effect the display if it's the mainboard. Either the technician that replaced the screen was not fully qualified for his job, or he just wanted to do a quick fix to get some money. Here are a few suggestions:
1) Go to ebay or craigslist and get the same one for a cheaper price.
2) Send it back again and tell them that you've already invested a great deal of money into this system and refuse to pay for a faulty console.
3) Do a pressure check. Find that spot that fixed it and a way to consecutively fix the problem by pushing it in that spot so that when you send it back, you can show them that it is in fact the display.
4) There is a small (i forget the exact term) ribbon of wires connecting the display to the mainboard that could be the problem; hence they said it is the mainboard. You'd be better off buying another system before you throw away your money into this one.
If you wind up getting another one, invest in a rubber skin or a hard-shell skin so that if it is dropped again, there should be no problem.
Nov 30, 2009 | Nintendo DS Lite Console
EMachines T2824. Does nothing but light on mainboard coming on...
This is a motherboard problem. You'll need to replace it. Although, it may be cheaper just to buy a new PC (eMachines are never very expensive, or well-made for that matter)
Sep 22, 2009 | Computers & Internet
Hp nx8220 display problems
I think I came across to a similar situation, try resetting the RAM by pulling it out and inset it back properly. If it does not work, try replacing the RAM from a working Laptop and see. Normally after disassembling the laptop assembling it again the RAM does not sits down properly causing the no display or a faulty RAM either.
Aug 10, 2009 | Computers & Internet
No display and no connectivity to the computer
Replace all electrolytic capacitors in power supply section on mainboard. caused by poor quality lower voltage caps being used in powersupply. Problem will reoccur every 2 to 3 years if 105oC caps are not used. If mainboard is replaced with new mainboard problem will reoccur within same timeframe. Fix old mainboard using higher voltage and higher temp caps and problem will be gone for good.
Dec 29, 2008 | Samsung ML-2551N Laser Printer
Mio c 210
Replace the display or verify it's conenctor to mainboard
Mar 08, 2008 | Mitac Mio C210 GPS Receiver
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
