Water continues to fill machine,i can even have the machine off and unpluged and water will still fill machine
  • 784 Answers
This is caused by a bad mixer valve. ( it is stuck in a open position ).
to fix this problem you will need to undue the hoses from the machine and remove the back panel of the washer, remove and replace the mixer valve. ( mixer valve is held in place by one small screw -- take note to what wires go to the hot side and what wires go to the cold side ).
c...
Posted on Jan 02, 2011
Testimonial: "u da man,thanks, this is something i can fix myself,very helpful"
  • Anonymous Jan 02, 2011
    thanks, snowghost1
  • chris wheeler
    chris wheeler Jan 02, 2011
    anytime --- if you have any other questions about this fix - feel free to ask, I will do my best to walk you though it.
    Have a great New Year !!
    c...
What is the problem of the washnine the water comes out from inletvalve thus not stop even he reach water level?
If the water continues to fill the tub above the requested unplug the machine and see if the water continues to enter the machine. If it does than the inlet water solenoid has failed and needs to be replaced.
Washer Water Inlet Valve Replacement Whirlpool Kenmore Top Load Washer...
Jan 09, 2016 | Washing Machines
My LG TROMM Hot water continually fills even after machine is turned off and unplugged. I have to shut off water supply to stop it.
Unplug the washer removing all electrical power from the machine. Turn the water back on and confirm that water is still entering the machine.
If the condition is true no power to washer and water enters machine it is very likely that the fill solenoid has failed.
this part is not that difficult to replace.
Water Inlet Valve part 5220FR2008F LG Washer Repair
Dec 31, 2015 | LG Washing Machines
Water continues to flush through dispenser tray even when machine is unplugged & water valve off. Washer fills but I continually put it through drain cycle to avoid leaking.
You have a faulty water control valve that is not closing all the way. You can go on line and research the part with the model and serial numbers.
Oct 22, 2015 | Maytag MAH2400A Front Load Washer
How to fix amana w10240534c washer wont fill?
check your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. no fill If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
May 31, 2014 | Amana 3.2 cu. ft. Top-Load Washer
My washing machine is a hotpoint WF240. It started to overflow with water and spilling onto floor. We pulled it out from wall and found outgoing pump had fallen down, we put it back where it was supposed...
The machine will fill with it connected to the Electrical supply then stop if unplugged providing the fill valves/ water is okay....If it keeps on filling after unpluged then sounds like faulty fill valve,if on the other hand it fills without stopping when plugged in then its your air hose or Pressure switch at fault,Good luck
Apr 06, 2011 | Washing Machines
Help! My fisher paykel washing machine won't stop filling up!
If the water continues to fill even if unplugged the water valve is sticking and needs replaced. if removing power turns the water off the water level pressure switch is bad or there is something plugging the sensor tube somewhere.
Eric
Nov 22, 2009 | Washing Machines
Washer won't stop filling
if you can turn the washer off while it is still filling. and the water continues to enter the machine you have a bad inlet valve.
Do me a favor turn the washer to fill, with the washer still running unplug from the wall. If the water is still entering the unit you have a bad inlet valve
Jan 05, 2009 | Roper RAS8445KQ Top Load Washer
Water will not shut off, continues to fill
does the water run when you unplug the machine? if so then you have a bad fill valve,
Nov 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag performa washer hot water runs continuously
dudett, uplug the washer and turn the water valves on. If the washer is filling with the washer unplugged the valve is bad. Part number 22001196. Not a hard job. If you need help installing, just e-mail the cat here at catriver1@gmail.com Catriver..post back.
Feb 19, 2007 | Maytag Performa PAV2200
Nespresso D300 says "Fill Water" even after I have filled container.
Even if you fill the tank with water, the machine will display this message when it is empty inside (the pipes, heating element, etc.) You need to prime it: run some water through it by running the steamer/hot water wand.  That should take care of it.
Jul 23, 2006 | Nespresso D300 Espresso Machine
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
