I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
2)Remove the louver by removing the three Hood Louver Screws.
3)Push in the upper tabs and pull the louver away from your appliance.
4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
If you are trying to change the light bulbs underneath your Microwave:
1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
2)To open Light Cover, remove the screw on the light cover.
3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
4)Close the Light Cover and secure with screw removed at step 2.
If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
You need to replace the diode. Scratch that. The voltage let alone the radiation could kill you. Call a technician. If it is a table top unit, buy a new one. It will be cheaper,
The magnetron is over heating causing the thermal fuse to open to cut power, the only option is replace the part, but keep in mind it is the most expensive item to install.
This is happening due to either the magnetron, or the Power Diode, or both, is breaking down, under load, then the unit detects the fault condition, & then, for safety reasons, to avoid a fire or explosion, shuts down the system. You need to take it in to be looked at please obtain a "Quote" before proceeding with any work. This way you can decide to repair or replace.
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
