Question about Samsung HCN653W 65" Rear Projection Television
My tv gets zig zag lines on the screen
Per last comment I replaced the convergence Amp board BP95-00142P it came with ic's Now i don't see three collors in motion but i still have zig zag lines on the screen what can i do about that
  • 137 Answers
Hello luckyone1,
According to your name you get one lucky fix..not two
OK, OK ...That was funny
What do you meant by zigzag line? Do they look like what we would call herring bone. lines going sideways? Please let me know. If this is the case, I have never been able to solve that problem. I am very close with the tech over there at Samsung. We spent hours on this problem. We changed Complete main board. We also changed Power supply. The problem maybe coming off the Yoke or a somewhat defective picture tube.
Please post reply if someone did correct such problem
Best regards
Posted on Jul 23, 2008
I have a 65 inch Hitachi projection TV and all of a sudden lines apperaed on the screen that runs across the upper part of screen. I tried using the"Magic Focus" setting to get rid of these lines...
The tv Magic Focus button don't solved these R,G,B colors lines mis alignments problems.Mean ur tv have a convergence pictures problems,it is dead.Ur tv now have any colors lines like R,G,B mis alignments,have a colors shadows picture or a 3D pictures look alike?Yes,mean ur tv convergence board it is dead to causes all of these pictures problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 24, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
My Mitsubishi HD1080 series screen is coming inward from the top & bottom.. and occasionally red & green lines or black lines will flash through it... It started out just being inwards once in a...
You have either bad convergence ICs or just bad grounds on the IC. I would go ahead and replace the ICs and check those small ohm resistors, as you have to pull the signal board out anyway. For futher instructions see the website They may have what you are looking for. Be sure you have the TV model number next to you. Thanks for asking and show a few hands of support!
Nov 07, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Hi, My Samsung tv had the bad coloring issues described of as convergence/IC issues. Now it just has a red slanted line going across the top of the tv. In the self focus menu I get an error that says...
You can just replace the convergence board which for your model is part # BP95-00415C They are under $100 dollars and are just a plug in board. You should be able to purchase from
Aug 28, 2010 | Samsung HC-P4363W 43 in. TV/DVD Combo
JVC AV-48WP30 convergence drifting after IC replacement
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
Mar 16, 2010 | JVC AV-48WP30 48" Rear Projection...
I have a Toshiba rear projection TV model # 50H71 for about a month the tv would randomly pop off (lose sound and picture) for about 45 seconds and then come back on now th picture is reduced in size by...
Good Day,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number
23905094 (STK392-110) using the revised “T” version IC Part Number
23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version. Inspect the Convergence Output IC’s for the “T” type version as
shown in Figure 2. Replace the Convergence Output IC’s using the “T”
type version Part Number 23135090 (STK392-110T).
Thanks for choosing FixYA, Big Irish
Nov 22, 2009 | Toshiba TZ50V51 50" Rear Projection...
Toshiba 57H82 entire screen flickers. Not clear. mult images
Sounds like the Hyper board is needing replacement very common problem for toshibas.
Dec 27, 2008 | Toshiba 57H82 57" Rear Projection...
I replaced the convergence board but still have the same problem.
The problem is not with the convergence board. Its the Convergence ICs which are located on the sub board. Use two stk392-040 ICs as your model probably has the 392-010 now. But you can get two new replacement ICs at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Heres the link you will need two STK392-040 Convergence ICs.
May 22, 2008 | Samsung HCM4215W 42" Rear Projection...
My samsung hcn4226wx rear projection tv
IT SOUNS LIKE YOU NEED THE Convergence Module BP9500415B BP95-00415B
Feb 28, 2008 | Samsung HCN4226W 42" Rear Projection...
My phillips ts2746c221 model
If it is a horizontal line is straite or zig zag, if it is straite then problem in your vertical section,please check the supply of vertical section or output ic of vertical, if it is zig zag line then it could be dry solder in the yoke connector or vertical yoke open, please let me know the vertical ic no.
Oct 22, 2007 | Philips 27PT71B 27" TV
Distorted picture
when you say distorded, is it like a 3-d effect? or more of zig zag type lines in the picture. If there are color outlines like a 3-d effect, then you are having a convergence preakdown, and are going to need to have the convergence IC's replaced. if the problem is the piture is zagged edges and zig zag, lines or a smearing effect, most likly it is the PIP modle is going bad, and even if you dont use the PIP, the video still goes through that module. If it does not have a PIP feature, then there are bad capacitors in the sweep power supply and the problem will get progessivly worse till the set wont come on anymore. Hope this helps. Good Luck
Dec 28, 2006 | Mitsubishi WD-52825 52" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
265 people viewed this question
Jerry Greenberg
Jerry Greenberg
