Question about IntelliTouch Communications On Hold Plus 8000 (128 MB) MP3 Player
Alba MPK4065BUK and i do not how to put it on hold, also it does go on hold every so often without me pressing anything and i do not know how to get it off hold.
Tip
How to use F1, F2 ?..Function buttons on Acer laptop.
For those who do not know how to use the F1, F2, F3..... buttons on Acer laptops, here is an opportunity for you to know.
We see these buttons on most laptops but don't know what they are used for. F1, F2....... buttons are the first set of buttons on the keyboard. These buttons makes it easy for anyone to access some programs on the computer without using mouse.
Follow the below procedures on how to use some of these functions
>To put your Acer laptop on stand-by or to view shut down options, Press and hold Fn button on your keyboard, (without leaving it) then press F4 (Fn + F4).
>To make your Acer laptop be on sleep mode, Press and hold, Fn button, then press F6 (Fn + F6).
>To lock your Acer laptop's Touchpad, press and hold Fn button, then press F7 (Fn + F7).
>To put your Acer laptop on mute Press and hold Fn button, then press F8 (Fn + F8).
>To shut down your laptop or to view other shut down options, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
>To close any page on your Acer laptop, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
Good luck.
on Oct 23, 2010 | Computers & Internet
How do i lock the controls on my Alba MPK8065BUK mp3 player ?
hold the upper right key and it will say "hold" do the same to unhold
Jan 29, 2012 | Jwin Audio Players & Recorders
Bought alba mpk4065buk for my sons christmas but it will not let me play any songs saying it has a format error. I have gone over te manual step by step but it does not help
Different MP3 players use different media formats, sounds like you need to convert the music files you have into a different type of file.
Check your owners manual to see what type media file your player has to have.
If it is different from the one you have, convert the files to work for your player.
Please Rate Me
You can download a FREE media converter here: http://www.formatoz.com/
Dec 29, 2010 | Meizu Mini Digital Media Player
Alba hd tv, no remote and the child lock is on just need to bypass it model no lcd3288ohdf
Okay - this is a secret child lock that Alba puts onto their tvs - not the child lock accessible via the menu which is 0000 as default. Basically there is a childlock built into the handset. Basically if you hold the menu exit button for more than 10 seconds the handset locks - all that happens then is when you press buttons you will see the blue panel flash on the tv but nothing works. This lock happens when the remote falls down the side of the settee or your child gets their hands on it!!! To unlock, find the menu button on the right hand side of the TV panel and hold it for 15 seconds and the menu screen will pop up - Really important you hold for 15 seconds before releasing. Then simply press the menu exit button on the remote and 'hey presto' - you have control of your TV again! Kind Regards, BIG BAD JON !!!
Oct 31, 2010 | Televison & Video
I have the alba mpk4065buk 4gig. it is a present and i am testin git first, the response time for playing the chosen album is about ten seconds after i have chosen it . is that usual
i have the
Alba MPK4065BUK and i dont know how to put it on hold? any help. occasionly it goes on hold for no reason and i cant take it off. any help there too?
Aug 25, 2010 | UXcell Alba LST-048 (2 GB) Digital Media...
Music stored on MP3 player won't play now for more than 10 seconds per song. This has only started happening today. What can I do to enable the song to be played? Is there a setting on the Mp3 Player. Alba...
The setting for 10 seconds per song in the Alba MPK4065BUK is under the Repeat Mode, when Music is selected.
The 10 seconds mode is called Intro.
How to change / setup the repeat mode:
Overview list of all repeat modes:
You can also look in the manual for this setup:
http://www.curtisint.com/html/CustService/Manuals/CUR_MPK4065BUK_EN.PDF
This pdf file can be read with Adobe Reader.
When not having this reader installed, get the reader here:
http://get.adobe.com/reader/
Aug 08, 2010 | Audio Players & Recorders
Hi, my son has an alba dvd player and the charger needs replacing
You can buy universal power supply at electronic stores, put in list this information when buying, Your device is 9Volts and consuming 2.2 amperes of current, so this should be the rating of your powersuply, ask help for the attendant to set the settings that will match your device look for the polarity shown on your device...
This polarity states the voltage orientation, once you neglect this, your device will be permanently destroyed and burn...
Oct 21, 2009 | Televison & Video
I need codes for a remote ,BD512
there are no coides published for ALBA TV ,try Pressing SET (&hold)and (1) key ,indicator will flash eg. 4 times for Digit 4 etc,repeat this step ,with (2)key for the 2nd digit and (3) key for 3rd digit,good luck
Mar 25, 2009 | Jensen JER-422 Universal Remote Control
IntelliTouch Communications On Hold Plus 8000 (128 MB) MP3 Player Logo
119 people viewed this question
Top IntelliTouch Communications Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an IntelliTouch Communications Audio Player and Recorder Expert? Answer questions, earn points and help others
