Question about Dell Inspiron 5100 Notebook
Does Dell Inspirion 5100 read hard drive bigger than 80 GB (I mean 160 GB)? I want to buy, but I'm afraid it won't be working. Please answer.
    Brigadier General:
  • 8,909 Answers
I would be surprised if it didn't support up to 620Gb and more.
No problem, the motherboard and bios will be happy with that and 160Gb drives are cheap at present.
Hope that helps.
Posted on Jan 02, 2011
  • Dell Master
  • 11,800 Answers
Yes, every hard disk that is less than 2 TB will be accepted.
03-27456719-5981718-cech-2503a
If you mean what size hard drive, go to system settings then system information. There will be a line that reads NNN GB / NNN GB where NNN is a 2 or 3 digit number. The second number gives you the total available hard drive space. The first number is what you are using of that space.
In my case, the second number reads 232 GB when I actually have a 250 GB hard drive (some space is reserved for the system), so round your second number up to whichever is closest to either 12, 20, 40, 60, 80, 120, 160, 250, 320, 500 and that's your answer.
I think your answer is 120 GB based on your model number.
Feb 03, 2014 | Sony Playstation 3 (PS3) Console
Tip
Service manual for Dell inspirion 1100, 5100, and 5150
Hello,<br /><br />Download the service manual for Dell inspirion 1100, 5100, and 5150 by simply click the below link.<br /><br />Note that the manual is in PDF format, so you need to have Adobe Acrobat reader already installed on your computer.<br /><br />Also, your computer configuration speed will determine how fast the service manual will load. Wait for the service manual to load completely before scrolling in order to avoid it hanging.<br /><br />It is advice able that you print it so that you can have a hard copy. Its usually strenuous reading from the computer.<br /><br /><a href="http://www.elhvb.com/mobokive/edwin/laptops/dell/INSPIRON/1100-5100-5150/1100-5100-5150.PDF%20">http://www.elhvb.com/mobokive/edwin/laptops/dell/INSPIRON/1100-5100-5150/1100-5100-5150.PDF</a> <br /><br />Good luck.<br /><br />
on Dec 28, 2010 | Computers & Internet
Dell bio password
To clear a Dell laptop bios password with the Dell Master Bios Password visit http://www.unlockbiosrecovery.com/Unlock_Dell_Bios.php or to clear Dell hard drive password use http://www.unlockbiosrecovery.com/Unlock_Dell_HDD.php
Jul 25, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate Barracuda ATA IV 80 GB won't work in my Dell GX270. Any suggestions.
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket
Nov 05, 2011 | Seagate Barracuda ATA IV (ST380021A) 80 GB...
Tv remote codes
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 21, 2010 | Apricorn Dell Inspirion (d809wcdel51) 80...
It appears that my fan for my Inspiron laptop is not working. How can i test it??
It should start up when you start the machine. This is part of the power on self test, or POST, which is a function of all modern computers.
It may be clogged, at which case, it should be serviced.
Dec 17, 2009 | Apricorn Dell Inspirion (d809wcdel51) 80...
How do i get a bigger hard drive for my laptop
go to staples and ask them in person what they have that can work . we on fixya have no idea .
Aug 10, 2017 | Toshiba MK8034GSX 80 GB SATA Hard Drive
My connection keeps failing when i attempt to log into a chat room on black planet
Check Windows Firewall Settings ensure the proper port is allowed for the black planet application. Just google for the port number.If your behind a router - then ensure that you have UPNP enabled on the router.
Sep 02, 2009 | Apricorn Dell Inspirion (d809wcdel51) 80...
Dropped my 60 GB WD passport
Hello
I am afraid you damaged the hard drive. I am sorry to inform you about that. If it is within an enclosure. Try and check this out. Open the enclosure see if you got the hard drive loose from where it should be plugged, and if you're lucky you should be back in action. Otherwise I am afraid you broke it.
Best Regards
Jan 06, 2009 | Western Digital Passport WDXML800UE...
Upgraded hard drive, from 80gb to 250gb. I have had to reload my os twice. it appears that the bios is not recognizing my hd. a friend said that the inspiron 6000 does not do well with a hd bigger then...
I dont think we can use a hard disk of 160gb in an inspiron 6000. and make sure you bought a ATA hard drive and not a SATA drive. For the Western digital try to reinstall XP and install the device drivers before installing application s/w.
Dec 19, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 5100 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
