Freezers Logo
Posted on Jan 02, 2011
My siemens electronic active no frost Fridge freezer model ks40u620gb/02 Has all its lights flashing at aprox 1 second interval. It has been doing this on and off for a few weeks but was still working & keeping things frozen. I thought maybe that interaly it had frozen up so defrosted it one night by leaving it turned off with the freezer door open now it doesnt cool down at all any udea if this is a bin job or an easy repair job? Regards martin
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Oct 18, 2008
SOURCE: servis frost free fridge freezer makin crackin noise afew tyms a day
this is not unusual on any make. the cracking noise is the cabinet creaking with change in temperatue. don't worry about it
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 25, 2008
SOURCE: red light on not cold enouth
The red light bis indicating that the temp is too high, if you can ,turn the thermostat to a colder setting, if this makes no difference, then you have a serious problem, you will have to call an engineer.
Plz rate this solution,
Thanks.
Anonymous
  • 86 Answers
  • Posted on Jan 02, 2009
SOURCE: frosting & water dripping from freezer in Frost free freezer
Hi, You will find that your problem relates to the defrost heater in the freezer. You will need to take the drawers out and remove the back panel to access the evaporator. There is a foil heater that lays underneath the evaporator and it will need to be changed. Along with the klixon that controls it. This will ensure that both parts are good. Your problem will then be fixed no more water!
Good luck................
Anonymous
  • 4793 Answers
  • Posted on Feb 11, 2010
SOURCE: Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Anonymous
  • 389 Answers
  • Posted on Apr 21, 2010
SOURCE: brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
4helpful
My new frigidaire freezer the digital display on outside of door flashes off what to do?
Hello - Typically "OF" indicates that the freezer is turn off. To activate freezer, press UP three times until display shows "1" then press UP to desired setting. If it will not allow you to change setting and freezer continues to be off, try resetting the freezer by unplugging it or flipping the breaker off. Wait approximately ten minutes and turn it on. If "OF" continues to display, the unit could possibly have a communication problem with the electronic control assembly. Contact a professional to move forward accurately.
Compressor starts and runs for 2 to 3 seconds and kicks off for approximately 1 minute and starts the cycle again.
Please set your thermostat a bit lower. This will keep your compressor longer on/off interval.
Regards
4helpful
3answers
Samsung RSA1WTMH i just blew my fusebox and my fridge freezer just flashing 1 led light
hope the following helps you, I had a similar problem with my RSH1 and it took me a few hours searching online before I found the following.
"Hi, I have it on good authority that this is the system check for Samsungs (RS21, SRS20, etc) during normal operation, is to hold the top two buttons down, just until display flashes - this will reset the electronics.
Secondly, if the top two buttons are held down for longer (8 seconds) the display goes blank and will show any error messages in the form of DASHES
I have experimented with unplugging air or frost probes - and the error code you get -on a blank screen is different parts of the last digit lighting up.
Example: when i disconnect the fridge air-probe, shut both doors, hold down top buttons around display - The SIDE of the last "8" digit lights up ! ...strange but true.
But, I need to know what it means when the BOTTOM of the "8" digit lights up"
I am still trying to find a list of the error codes the lines refer to but so far my unit is working fine.
Angus
Sep 21, 2010 • Freezers
Fridge/freezer. Freezer works great but fridge is
Air from the freezer is blown into the fridge by a fan, some new type frigs have electronic controls that open and close a vent to frig. the older ones have two vents in the frig from the freezer and when covered with frost or ice the air will not reach the frig. check for ice or just defrost the freezer if there is ice or frost, also check for food or plastic over vents in freezer. Also check that the freezer fan is running as these sometimes become blocked or defective motor.
2answers
Model m331blk1 fridge freezer warning light flashing what is the problem will my freeze be ok it is only 1 yr old
4helpful
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 • Freezers
1helpful
Servis frostfree fridge freezer
Hi, I had that last year - It was the control board!
Oct 24, 2008 • Freezers
3helpful
Servis fridge freezer
It may be that the temperature of the unit is not yet up to temp.The flashing light will indicate this.Warning the user the unit is not ready,or up to safe temp.. Let the unit run to catch up,since you just started it.
Top Siemens Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Siemens Freezer Expert? Answer questions, earn points and help others
