Question about Goodman CLQ36AR49 Air Conditioner
Goodman a/c unit
I recently had a unit installed and it is not cooling properly. i have two different opinions from two qualified installers as to what the gauge readings should be. could you please give me your input? thanks,
  • burzerko
    burzerko May 11, 2010
    First off what refrigerant type is this unit
    2nd what is the ambient temperature outside?
    3rd Is the unit running or has is been off for at least 24 hours?
    4th What are the gauge pressures on the high and low side?
    Champion:
  • 254 Answers
The pressure depends greatly on the ambient temperature outside. There are two methods I use for charging a system
1. Is calculating the superheat
2. Is calculating the sub cooling.
Any good service technician will use these methods.
Posted on Jul 24, 2008
Goodman AC unit recently service but don't believe the filter I am using is the issue or what the tech did actually fixed my issue. Details below.
Setting the air handler to high speed will draw more current and this will result in an increase in electricity consumption.
Jul 27, 2017 | Goodman Heating & Cooling
Difference in seer
i would check fan speed. it's probably on high. you might be moving more air with new system. a dirty evaporater on old unit woud have gave you a larger temperture drop.
Jun 16, 2014 | Goodman Heating & Cooling
I have a leak
Under warranty from 10 years ago??
I would get it repaired properly by a qualified service engineer after speaking to the manufacturer.
Nov 16, 2017 | Goodman GPH1536M41 3 Ton 15 SEER...
I just had a new Goodman 13 seer installed on 6/5/10 and the unit wont turn off and doesnt seem to cool down the house had new duct installed also they changed out the fan but it runs all day without...
CALL AN EXPERT......THE WIRES AT THE CONDENSER ARE NOT CONNECTED PROPERLY.THE UNIT SHOULD HAVE BEEN VACUUMED/PUMP DOWN BEFORE STARTING UP .POSSIBLE LOW ON REFRIGERANT ALSO.
Jul 13, 2010 | Goodman CLQ36AR49 Air Conditioner
Air condition jsut 10 month old ... not keeping up whith cooling
If it's only 92° outside and the unit won't cool the house, then the unit is either to small or it's low on refrigerant. They are designed to cool a house with outdoor temperatures up to 115° to 120°.Usually you need one ton a/c for every 400 square feet of house, but, you have to take into account for average outdoor temperature and humidity, windows, doors, especially sliding glass or patio doors and which side of the house they are on, insulation in walls and attic.
The air leaving your duct work going into the rooms should be about 20° lower than the room temperature, if you have a 80° room then the air leaving the duct should be around 60°. if it is then the unit is probably to small if, everything is working properly.
Jun 07, 2010 | Goodman CLQ36AR49 Air Conditioner
Questionable installation of a Goodman furnace.
That seems to be the common practice. The low pressure created by the suction of the fan will draw air in from outside.
May 03, 2010 | Goodman GMS90703BXA Heater
A/C fan is running but no cool air
Make sure the outside unit is running. If it is then you may need to get the unit charged.
May 02, 2010 | Goodman CPLT24-1 13 Air Conditioner
Just had a new 3.5 Ton Goodman GSZ13-13 SEER, heatpump installed. Its working OK in Cooling, however whe switched over to heating mode the indor unit makes a loud grumbling sound. The installer stated that...
I install them every day and I have not had one make a loud grumbling sound. Sounds like you might have a low voltage (Thermostat) wiring problem. The only thing different inside the indoors unit from heat and cool is the fan speed, electric heat when on. The fan might be loose or out of balance and it only shows up at low speeds. Either way, the noise is not normal.
Oct 13, 2009 | Goodman CLQ36AR49 Air Conditioner
Newly installed Goodman GPG13 gas/electric package unit installed. Cannot get AC to cycle on. Unit produces heat at all thermostst settings.
new unit and old thermostat/wire? thermostat could be bad or bad thermostat wires. try putting in new of anything old. do this wiring practice with the terminals being the letters.
r- red (24 volts)
w- white ( heat)
y- yellow (cooling)
g- green (fan)
Sep 21, 2008 | Goodman Heating & Cooling
Air conditioning unit
Hi! AC Unit
Sorry you have had so much trouble. Sounds like with the factory warranty being in effect the whole outside condensing unit should be replaced. With this type of problem there could be some blockage in the AC lines. With out some pressure reading it is hard to tell if the expansion tube is plugged, or there is some other major problem. If your service tech is unable to diagnose the problem you may need to get a third opinion. Goodman may have a factory representative in your area. You may be able to find some help with a different dealer or online. Good Luck! I will try and look for any changes.
InMrFxIt
Jul 28, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
97 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
