Question about Refrigerators
REFRIGERATOR OUR HOTPOINT REFRIGERATOR IS TWO YRS OLD; IT'S BLOWING HOT AIR INTO THE FREEZER; IS THIS WORTH TO HAVE IT REPAIRED; IT'S NOT THE TOP OF THE LINE; WE PURCHASED IT FROM HOME DEPOT.
  • 25 Answers
Well if it has a freon leak or bad compressor it will still b covered under warranty
if u hear a clicking noise and it sounds like compressor is trying to cut on it most likely has a bad compressor relay
i wud bet relay is bad
Posted on Jul 09, 2008
Smeg fridge freezer FA421XS not cooling
There is copper lines by the compressor it sounds like its low on freeon the cooling chemical you can purchase a kit and weld a valve on the in line and load it up with more freeon that may work
Oct 12, 2014 | Smeg FA421X Top Freezer Refrigerator
My Hotpoint Fridge/Freezer only works with the freezer at the bottom and the fridge is fed from the freezer via ducting to the fridge at the top ---- can anyone tell me why the freezer works perfectly and...
There has to be something restricting the air flow to the fridge. If the fan is running blowing cold air into the freezer, then it should be cooling the fridge too. Empty out the fridge and freezer and use a blow drier to blow hot air into the duct work. There could be an ice blockage not visible in the duct work.
Aug 15, 2014 | Hotpoint Refrigerators
Hi, I have a Hotpoint top freezer and refer MD# CTX22DKG and I have know idea how old it is. The freezer works good but the refergerator stoped working. Is it worth fixing or do you have any advice what...
top freezer hotpoint style have a fan in the freezer behind the back plate and if it isn't working then it will not blow the cold down . other it might have iced over the air duct caused by the drain in bottom of freezer being plugger . . so when you open the freezer door you should hear the fan . and if you see ice in the bottom -back side its a drain problem . hope this helps mm
Oct 14, 2010 | Hotpoint 21.7 cu. ft. Side-by-Side...
Water in fridge
First, empty freezer and fridge. Unplug and leave door open for at least 3-4 hours. Blow out drain lines with compressed air. It is more likely that the drain line is clogged than frozen; but a clogged drain line will freeze-up quickly.
Aug 08, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
48" side by side Monogram center between doors getting very hot
this problem is due to low or no air flow aross the condenser coil on your refrigerator. according to sthe model number you listed I'm assuming this is a bult in unit so the condenser coils are going to be on top of the unit. Here are the steps to check and possibly repair your unit:
  • Open compartment cover on top.
  • check and clean the coils that will be exposed, you can either vacum or blow them out with compressed air depending on how dirty they are
  • there is also a fan that cools this coil, check that it is running. this is probably why it is getting so hot in center post and freezer isnt doing good.
if the motor is bad you can position a regular house fan blowing into the motor compartment and it will get everything back to normal until the unit is repaired.
Fyi: there is a hot gas freon line that runs between the doors that controls exterior unit moisture and when there is poor or no air flow across the condenser coil it causes this area to get extremely hot. There is no fire hazzard tho.
If I can be of further assistance please ask.Thanks Peyton
Mar 13, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Fridge problem
I don't know about the hot points for sure, but all the maytags (I used to work for maytag) have a damper valve in the air tunnel that feeds cold air to the refrigerator. If the damper went bad, it would block cold air flow into the refrigerator. (assuming this model has a damper)
Feb 16, 2008 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
GE refrigerator not cooling
on most refrigeration, the refrigerant goes to the freezer first and the tail end to the fridge. it is probable that the compressor is failing. compressors are quite hotg when running but not too hot to touch. if the compressor is too hot that also indicates failure. doubt it is worth repair
May 19, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
164 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
