Question about IBM LCD Panel, 14.1-in. XGA TP R50/p, R51, R50e, R52 - Sub 92P6675 11P8352 (92P6745) CD-ROM Drive
My monitor doesnot run - IBM LCD Panel, 14.1-in. XGA TP R50/p, R51, R50e, R52 - Sub 92P6675 11P8352 (92P6745) CD-ROM Drive
  • 277 Answers
Try an external monitor to verify if the laptop is working just fine.
If you get a clear picture on the external monitor, see if the laptop LCD is dim, or has no image at all.
If dim, you will need to replace the backlight or inverter.
If there is no image at all on the LCD, see if there's a small microswitch at the base of the LCD, this microswitch turns of the LCD assembly when the lid is closed. Usually these microswitches can easily get stuck due to dust and dew. You'll have to wigle it out with a toothpick or similar pointy object.
If there is no microswitch, perhaps it may be that the LCD cable is loose and is out of its socket, and you'll need to open up the laptop and re-seat a long (about an inch) rectangular-shaped connector leading from the motherboard into the LCD assembly.
Posted on Jan 02, 2011
I have a AOC L520 MONITOR and the touch screen doesnot work.Were I can found the software?
Here, from the manufacturer's website.
ftp://ftp.aoc-europe.com/Drivers/LCD-monitors/LM520&LM520A.zip
Rulan
Jun 16, 2011 | AOC LM 520 15" LCD Monitor
My PC "ViewSonic 15" "
Looks like a virus attack to some extent. Run a virus scan. If that doesnot work, then check the keyboard and replace it.
Mar 03, 2011 | ViewSonic G90fb 19" CRT Monitor
Everything seems to be running fine, except the monitor, the monitor that came with it works fine with my mac as does the other monitor but on the hp desktop keeps coming up no display? does this sound...
yes it can be the video card issue , might be the video card doesnot support the monitor jst check how big is the monitor and also what type of the video card is installed on the HP pc.
May 19, 2010 | HP m8020n PC Desktop
In asus P5VDCMX motherboard power led and ide led doesnot glow , but pressing power switch cpu fan run,monitor screen blank.
mybe something wrong with your hardisk or Motherboards.you can sheck with manually open the case and try to reconect and conect again the cable.
Mar 24, 2010 | ASUS Computers & Internet
My dell optiplex gx270 can not display to a monitor
You can visit the following link
http://support.dell.com/support/edocs/systems/opgx270/en/ug/solve.htm#1177038
click on the option
Video and monitor problems
Thanks for using Fixya
Proton
Nov 09, 2009 | Dell OptiPlex GX270 PC Desktop
I have the same problem with the same flat screen
hi
please check that the settings is okie on the control pannel in display setting for the monitor ,
if it is okie then go to run and in run type msconfig ,once u do this it will give u a system configuration box ,then in the sytem try to do the normal startup for the computer ..
if it still doesnot work then try to run a tool called dial a fix and u can get this is google
Jul 19, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Dell Monitor S2409W
check your vga/dvi cable connected properly.
this happens because your system doesnot sends any signals to your lcd.
this actually solved my problem.
Apr 10, 2009 | Dell E193FP 19" LCD Monitor
My monitor won't work
log on to the system using safe mode.
press F5 on startup and choose frm the menu safe mode.
i should wrk
change the settings back to normal..
in case this doesnot help
restore ur system to "LAST KNOWN GOOD CONFIGURATION" again frm the F5 menu
if this doesnot help then get back to me.
Jul 08, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Problem in monitor the screen doesnot get full wide of it by control panel
Assuming your running Windows as the operating system on your computer, go into Display Properties and set the refresh rate to something other than 60 hz or default. On my XP computer this can be done by right clicking on the desktop, clicking Properties -> Settings -> Advanced -> Monitor. Anything in the 70, 72, or 75 hz range should work fine. If this does not fix the problem and the monitor is out of warranty trash it and get another one.
Nov 10, 2007 | Hansol 730E 17" CRT Monitor
Computers & Internet Logo
51 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
