Question about Microwave Ovens
Breville bdf deep fryer keeps tripping out /turning off have to push reset buttons to get it started again after having to wait 10 mins to reset
    Brigadier General:
  • 8,909 Answers
That sounds like either a faulty thermal trip, or a faulty overheating fryer.
Is it clean around the element because if not the heat will build up, much like the fur on a kettle and cause the element to overheat.
Hope this helps.
Posted on Jan 02, 2011
Testimonial: "big help"
The microwave keeps stopping
If you are actually selecting heating time rather than pushing the "quick heat" button, the control board may be defective.
Aug 22, 2016 | Microwave Ovens
Lg microwave mv2297fspl
Magnetron is gone, just to be sure remove the microwave and use on a different socket. sometimes the breaker becomes faulty after 10 AMPS.
Tony
Nov 21, 2013 | Microwave Ovens
Microwave doesn't start but the interior light goes on when you hit the start button
Hello
Remove the plug from the wall outlet and wait about 10 seconds before re-inserting it. The plug must be firmly inserted to transfer electricity to the appliance.
Open your home's circuit breaker box and reset the breaker if it has tripped and is set to the "Off" position. Simply slide the breaker over to the "On" position to fix a breaker that has tripped.
Plug a different appliance into the same outlet to make sure the outlet you are using is functional. Plug the microwave into a different outlet to see if this yields different results.
Press on the microwave door to ensure it is completely closed. The microwave will not function until the door is fully shut.
Press the "Start" pad on the display panel after setting the time. Failing to press this will result in the microwave not knowing that it should start.
Press the "Stop/Reset" pad on the panel if a program different from the program you want to run has already been entered into the system.
Press the "Clock" pad three times to turn off the demo mode. The demo mode will not allow the appliance to turn on and cook as it should.
Oct 04, 2011 | Microwave Ovens
Hi. I have a hotpoint ud47i fan assisted oven which keeps tripping the oven related fuse box. Can't find any obvious faults. Strange thing is that once I reset the fuse box, the oven works again for 5-10...
The oven is tripping the circuit because it is pulling to many amps.
Best thing to do is get an electrician to install a larger amp circuit for you. This will fix the problem and should be cheaper than another stove.
Mar 27, 2011 | Hotpoint Microwave Ovens
I recently bought a breville deep fryer model DFY80 and it doesnt seem to work, but it doesnt have any oil in it yet. So i was wondering if i need to put oil in it before the lights and thermostate work??...
there is a reset button on the back of the element box try that and there is a switch when you slide the element into the frame make sure that it is making contact .hope this fixes your problem. dave.
Oct 26, 2010 | Microwave Ovens
Machine will not turn on
from online Microwave Repair Manual: Totally dead oven (no lights, no clock, no display, no fan, no heat...)First, check power to the outlet using a lamp or radio you know works. The fuse or circuit breaker at your service panel may have blown/tripped due to an overload or fault in the microwave oven or some other appliance. You may just have too many appliances plugged into this circuit - microwave ovens are high current appliances and should be on a dedicated circuit if possible. If you attempt to run a heating appliance like a toaster or fryer at the same time, you *will* blow the fuse or trip the circuit breaker. A refrigerator should never be plugged into the same circuit for this reason as well - you really don't want it to be without power because of your popcorn!
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
Oct 21, 2010 | Microwave Ovens
Where can I get a copy of a Breville Express Cooker (EXC15) manual? I had a cooker given to me but alas no "how to use" instructions.
Hi I have the same model - I absolutely love it. The only problem is that the seal is broken and because Breville no longer supply parts I'm using it more as a slow cooker!
It's pretty simple to use:
The basics:
1. Pull the handles apart (note you must have the 'pressure lock - the only sliding knob on the lid) in the 'unlocked position'.
2. Set the temperature on Max (only until the meat, onions etc are brown, then turn down to 1 or 2- just enough to keep the orange button 'popped' on the top of the machine
3. turn the timer (bottom dial on the front of the cooker) to an hour (you can always turn the dial more if needed, but not reduce time) by the time you've browned meat & chopped veges, etc that will be about 10-15 gone. I've never had it pressure 'cooking for more than an hour for anything'
3. re timing - casserole takes about 40 min from when the orange button on top 'pops' up (ie. steam build up enough pressure to cook quickly)
4. don't over fill - there's a little cast iron bump about an inch from the 'top' inside the cooker - that's about the max.
5. if you're cooking meat dishes have the dial on the top 'pressure release dial' on 3 - lighter dishes (e.g. soups) have on 1 or two.
6. until you get use to it keep an eye on the orange button - you get to know what temp to put it on by how much steam is released - it it's hissing away, turn the temperature down.
7. makes great casseroles, rissotto, soups (even with dried beans, only about 40 min)
if you ever find a supplier for seals, post an answer!
May 19, 2010 | Microwave Ovens
My microwave has 00:00 where the time or cooking mins should be displayed. I am pushing buttons and nothing changes. I can't use the microwave.
Unplug the microwave for 10 minutes and then replug-in. This will reset the unit.after that if it still behaves abnormally , Press cancel button for 10 seconds and then try pressing the timer adjust buttons.
thanks
Aug 31, 2009 | Sharp Microwave Ovens
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Gert
Aug 05, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
122 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
