Question about Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit
FAn and lights won't go on.
What does the blinking light in the lower right corner of the screen mean? I have lost my instruction booklet.
  • 9 Answers
I'm not familar with the remote control for this unit but if anything is blinking is an indication the batteries need to be replace.
Posted on Jul 09, 2008
Netbook screen blinks
you have root pixels change the panel screen for a new
Feb 05, 2014 | MSI Computers & Internet
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
The directions in the booklet don't make any sense. I cant change anything.
press and hold the lower right button, the digits blinks(blinking means changeable) use the "mode"/the lower left button to choose what digits are you going to change. the upper right button is use for adjusting. if your done just press the lower right button. i hope i had been helped you
Sep 12, 2011 | Adidas ADH6079 Watch
We have lost the instruction booklet - How do we detached the stand from the TV? Its a Panasonic TH42V500A
4 big screws ,two in each side of the back of the tv in the lower corners,right on top of the legs of the stands......
May 05, 2011 | Panasonic Televison & Video
How do you set the light delay, I lost my instruction booklet.
The 4½ minute interval can be changed to 1½, 2½ or 3½ minutes as follows: Press and hold the Lock button until the light blinks (about 10 seconds). A single blink indicates the the time is reset to 1½ minutes. Repeat the procedure and the light will blink twice, resetting the timer to 2½ minutes. Repeat again for a 3½ minute interval, etc., up to a maximum of 4 blinks and 4½ minutes.
Jan 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
Hello i lost the remote control booklet and i need the code for an rca tv. i have the gray 4.00 remote control ge/ jc022 the number on the inside is rc24914-d 3852
Use the Built in Code Search and never look for a code again!!!
  • 1 Turn on the device (e.g. TV, VCR or DVD) for which you wish to program.
  • 2 Press and hold the "Setup" button in the middle of the remote, under the "On/Off" button. Hold the button until the indicator light on the top left corner of the remote lights, then release the button.
  • 3 Press and release the button with the label of the device you wish to program. The indicator light will blink before remaining lit.
  • 4 Point the remote towards the device. Press and release the "On/Off" button every two seconds until your device turns off. (You may need to press the "On/Off" button up to 250 times before the correct code is found.)
  • 5 Press the "Enter" button on the lower right side of the remote control when your device turns off. The indicator light will subsequently turn off.
  • Nov 04, 2010 | Televison & Video
    I have a dell inspiron 1525 the battery light was blinking orange and wouldnt come on so listening to an expert i bought a new battery when you first plug it in should the light still be orange??
    Hi. Blinking orange light on battery indicator means it's charging. To make sure, point your mouse to the battery icon on the Taskbar located on the lower right-hand corner of your screen...near the system time and speaker icons. It should say plugged in, charging. If you see "plugged in, not charging, then you need to call Dell Phone Support for additional help.
    ^_^
    ^_^
    May 10, 2010 | Computers & Internet
    I have a toshiba dkt2010-sd how go i program this phone ... right now my display screen has NO.11 in the upper right hand corner and lower left corner it has CALL 11-15
    What do you want to program? to get rid of blinking light press intercom and dial #409 to program display name type Intercom #620 and #621
    Jan 21, 2010 | Toshiba DKT2010SD Phone
    SAMSUNG HLS4676SX UNEXPECTEDLY SHUTS DOWN DURING USE. PILOT LIGHT (GREEN/LOWER RIGHT CORNER) BLINKS FOLLOWING SHUTDOWN. PROBLEM CAUSE? SERVICE MANUAL COVER THIS PROBLEM?
    Mar 10, 2008 | Televison & Video
    Ceiling fan
    hi you have a problem with your fan do you have the remot book how to operate the fan remote we lost the booklet for the instruction maybe you can send me a copy of your booklet instruction for the fan is your fan is from the compagny home collection and the brend or model tampa thank you
    Nov 24, 2007 | Hunter Ceiling Fan Control Switch
    Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit Logo
    79 people viewed this question
    Top Hampton Bay Dryers Experts
    Steve
    Craig Butler
    Craig Butler
    Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
