How To Fix A Laptop Sony Vaio With Water Damage & not turn up
  • 2,567 Answers
When this happens, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the laptop.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Posted on Jan 02, 2011
How to fix sony vaio laptop if when opening pc, It says "Operating System not found"
hi good day
it might the hard disc not rebooting, due to some loose connection. you can tried to open the back cover using a screw diver then look for a loose connection, fix it then reboot the unit. hope this can help thanks for using the fixya.
Feb 23, 2012 | Computers & Internet
How do I restore my laptop to factory new?
Press the Alt + F10 to get factory default set up menu in Sony Vaio.
Dec 19, 2010 | Sony VAIO VGN-AR630E Notebook
Vaio shuts down suddenly, not due to battery
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 16, 2010 | Sony VAIO Notebook
My Sony VAIO has shutdown problem. when i do
i think you need to reformat and reinstall the OS on the machine to fix the problem. Some internal data is corrupt and does contribute to the failure of turning off and turning on.
May 10, 2010 | Sony VAIO VGN-CS215J/W Notebook
Sony VAIO Laptop won't turn on. The power lights
Unplug from A/C adapter & remove battery and let sit fo a while..
Put battery back and plug in the A/C adapter, then turn back on.
Mar 31, 2010 | Sony VAIO Notebook
My vaio laptop will not turn on. no lights, no nothing.
Its may be due to over heating that your laptop shut down automatically in order to prevent further damage of hardware;clean you laptop by opening it from the back side and blow it with a regular small air compressor blower.
it will solve your Problem
Dec 10, 2009 | Sony Computers & Internet
Sony Vaio VGN-A417M. Could someone please tell me how to siort out my laptop. Whenevr i turn it on it comes up with balck screen with'Error Loading Operating system'? thanks in advance.
Hello snowdonian,
You may need to reformat your Vaio. Some important components of your operating system may be corrupted.
If you're using Windows XP, check this link out,
http://helpdesk.its.uiowa.edu/windows/instructions/reformat.htm
But before you reformat, you might want to give it a shot & go to safe mode. If you're able to go to safe mode, you can save important files like pictures, documents, etc.
To go to safe mode, keep pressing the F2 button when you turn your laptop on.
Just choose safe mode & you should be all set.
If it won't go to safe mode, then you can proceed & reformat your laptop.
Hope this helps & best of luck!
Art Pena
Tech Support
Dec 06, 2009 | Sony VAIO V2M (VGCV2M) PC Desktop
My vaio turned off suddenly an the side light was blinking when i was trying to turn it on. Now i doesn't even turn on.What should i do?
Hi There !!
Thank you for choosing fixya.com
It's could be because of two reasons.
1. The Laptop is Overheated
2. The battery of the Laptop has some problems.
To diagnose this:
Step 1: Let the computer, be turned off for 15-30 minutes. Unplug the battery, Unplug any external Hardware connected to the laptop. Could be any external drive or any thing.
Step 2: After 30 minutes of disassembling the laptop. Let's put the battery back in & don' plug the power chord. Just give it a try to turn it on without plugging it in to the power jack.
Step 3: Still no joy, Try to plug the power chord back again & try to adjust it. Because Power port detects the power cord only after much adjusting of the cord and putting a weight on top of the cord so that the cord somehow makes contact with the power port on the laptop.
This is really the case with Vaio & Acer laptop because of their complex design.
Step 4: Check the voltage of your CMOS battery. if your battery is low it will fail to power up the system. if you leave it sit for a long period of time, it may be having a chance to "recharge" itself. This step should be done by a professional, because you might damage other part of the machine .
If your computer in warranty, Call Vaio Helpline right know. And, if any chance your computer is little old dont call Vaio help line because they charge heavily. Contact the local tech shop, even for your reference http://www.compusa.com/ it's cheap & good service dealer for laptop.
Hope this'll direct you in the right direction.
Sep 03, 2009 | Sony VAIO VGN-FW290JTB Notebook PC
Webcam in vaio vgn-ar630e not work
Go to this link & I'm sure it could solve your problem... Trust me... :-)
http://www.laptops-drivers.com
Jun 03, 2009 | Sony VAIO VGN-AR630E Notebook
My Sony VGN-FE550G wont boot
this is virus problem
pls install antivirus and update it
& scan ur laptop
May 12, 2009 | Sony VAIO A270 Notebook
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
