Question about Logitech Z-5500 Computer Speakers
Hello there, I recently purchased a Logitech z-5500 speaker system online, I have plugged all the speakers and set it all up correctly. It makes sound when I pres the "Test" command on the wireless remote, but wont make any noise when i try to play a song or watch a movie through my computer.... Please help, thank you.
  • 277 Answers
Verify if the computer has a digital output that matches your speakers (5.1 or 7.1). Also, verify that the cable leading from the PC to the main speaker box is OK. Also, the speakers may come with an installation CD, so you'll need to install the accompanying control application.
Posted on Jan 02, 2011
Hi, i just recently bought some logitech z-5500 and have tried to hook them to my mac. The problem is that the speakers are far too quiet they all work but they are not giving out 505watts rms. My mac only...
Hey there,
The 3.5mm socket is the only thing you can plug into on a mac for speakers.
Have you checked to make sure that the system volume is turned up? Use the volume buttons on the mac keyboard to turn it up.
Let me know if this does or doesnt work and we'll try something else!
Good luck :)
Mar 08, 2011 | Logitech Z-5500 Computer Speakers
Hi have recently purchased logitech 5500 system, it was working fine for a few days but now even with no sound running through it when you turn it on blast out a loud sreeching short out sound, just...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 25, 2011 | Logitech Z-5500 Computer Speakers
I don't have a sound card.but how can i connect logitech Z-5500 speakers to my pc
Since Logitec Z-5500 is a 5.1 Speaker System you need to purchase a Sound Card to be able to connect it with your pc. You can get a Sound card starting with a price tag of 20 Pounds.
Hope this will help you solve your problem Best Regards NextDoorNerd
Jul 28, 2010 | Logitech Z-5500 Computer Speakers
Logitech Z-5500, no sound out of speakers
Hi there bud , There could be a number of problems as it is a refurbished Speaker Set ,It could be The Subwoofer yes , Have you tried it on other PC's? if it does the same then it is The SPeakers that are faulty :(
Hope this helps
Happy new year :)
Jan 06, 2010 | Logitech Z-5500 Computer Speakers
Logitech Z-5500 DON'T POWER ON. HELP!!!
check its power supply if its working, first.check the outlets(electrical sockets)just to be sure of proper fit.
May 31, 2009 | Logitech Z-5500 Computer Speakers
Z-5500 speakers
It depends on what audio outs your tv has. Newer TVs may have a SPDIF port on the back for audio out. Look at the connections on the back of your tv (and in some cases if you have connections on the front, check those too.) and see if any say audio out.
Aug 30, 2008 | Logitech Z-5500 Computer Speakers
Logitech z-5500
Try to click the EFFECT BUTTON a few times to change the effect settings (see also in display) from e.g. Stereo (which uses only two front speakers) to other settings (for which some will use the other (rear/center/sub)speakers as well). Success,
Jun 20, 2008 | Logitech Z-5500 Computer Speakers
Operating with/without the control panel
You could try hooking them up to another speaker that has the input connections. I have done this before with several different speakers and daisy chained the connections with several speaker connections and they worked great. I had surround sound all over the room. You might run into a problem with the main speaker that you plug into not being able to push all of the speakers that you have but you might get lucky. Those speakers say that that carry 550 watts.
I recently bought a set of speakers that stated that they push 100 watts. The sub was putting out 50 watts and the others were only putting out 25 each. I hooked up a 100 watt speaker to it and it worked. You might be able to contact logitech to get the other speaker that you need. That set of speakers looks awesome on the site. This is the specs for the other speakers
I think that this is what you wanted to know. If it was not your solution, let me know. I will help you more. I might not be understanding your question correct. I have referred your question to someone on the site that works with logitech.
Jun 09, 2008 | Logitech Z-5500 5.1 Digital Speaker System...
No sound coming out of z-5500
To troubleshoot a speaker system where sound is not issuing from all speakers, please do the following:
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the source selector switch or the M3D button on the controller unit (if available). You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Try these articles as well:
Manual
Setting up the Z5500 with PC, Mac, Xbox, Playstation, DVD Player, etc.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 24, 2008 | Logitech Z-5500 Computer Speakers
No sound from speakers at all
Manual
Cheers!
IrishDruid
Logitech Z-5500 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
