Question about Frigidaire Kitchen Ranges
I have a frigidaire over model number FGF337AUE that has the same problem many others seem to have which is that the over just won't heat up. It was heating up VERY SLOWLY until today and now it's just not heating up. Stove top still works though. Is this something I can fix myself and of course what is the problem? Thanks so much for any help!
  • cmills57 Jul 10, 2008
    ok, i took off the bottom of the oven floor to acess it. The bake burner is the v-shaped long piece right under it that has one screw holding it on right? Just want to make sure before I go disconnecting things. thanks
  • jjmwbl Jul 16, 2008
    I have the same problem! Same thing happen, oven was warming up, not as warm as it should but now it does NOT warm up at all AND NONE of the burners work.
    All electronics work though
    Help!
    President:
  • Frigidaire Master
  • 2,651 Answers
Sounds as if you need a new bake ignitor, def somethin you can do your self, remove the bottom of the oven floor to acess it, its screwed onto the bake burner and either plugged in or 2 wires disconnect right there, bring to a l;ocal wharehouse for the part, $50-$75. installs same way as comes out, remember to unplug unit before servicing wires will be live
Posted on Jul 09, 2008
Thats the bake bar, and the ignitor is the white ceramic part screwed 2 it, you got it!
Posted on Jul 11, 2008
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
I have a Frigidaire Dryer model number GLER341AS2. The dryer runs fine, but won't get hot. I pulled the dryer from the wall to see anything obvious. I noticed what I thought at first to be anim
Are you mechanically inclined? You may have several problems. 1st, heating element is most likely burnt out. Then I would check ball and socket assembly that back of drum fits into. Also check felt in front of machine that drum rides on. May need competent service person on this.
Sep 13, 2017 | Frigidaire Electric Dryer
Reset frigidaire dishwasher model FDB1100RHC
I had the same issue. I unplugged the dishwasher and plugged it back in. Bam! It's working fine now.
Oct 16, 2012 | Frigidaire Dishwashers
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Timer won't advance on autosense,seems to work normally otherwise. timer advances fine on all other settings. was thinking it was the cycling thermostat, but the blower seems to be cycling. puzzled
when on auto the heat comes on and then shuts off and then the timer advances,when the heat comes back on the timer stops advancing,when on time dry the timer will advance no matter what's happening with the heat.next time send the brand name and model number so i can help you better,if it's gas you could have bad gas coils,you'll have heat for like the first 15 to 30 minutes then when the coils get hot they fail and no heat until they cool down,also if the vent line and the duct that the lint filter goes into hasn't been cleaned out the heat will shut down and if that happens the timer isn't gonna move.check that out and let me know what you find and send the brand and model number.
Sep 24, 2011 | Roper Dryers
Frigidaire dryer no heat thermal fuse seems ok? dryer is a 2005 model. model number and serial numbers worn off tag?
check your vent, make sure it is not plug with lent. If it is not then your heating elements.
Dec 06, 2009 | Frigidaire Dryers
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Kitchen Ranges Logo
138 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
