Harman kardon AVR 247 Remote
I purchased a Harman Kardon AVR 247 August of 2007. The remote has stopped working. I tried replacing batteries with several different sets of batteries, including buying a new package to be sure that was not the problem.
I have checked the HK web site and they show the remotes, but list them as not being available. How can I get this fixed or replaced?
jack@jriegel.com
5 Suggested Answers
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
dunnbiker
  • 8546 Answers
SOURCE: harman kardon avr 325 fan motor is making a noise.
Fans are typically not serviceable. They die, they get replaced. Maybe you could look inside it and see if it has dust on it, possibly unbalancing it. Then you could assess the scope of removing it yourself. My guess is the fan may be a common variety available at Radio Shack, unless it has an internal sensor circuit for temperature or rotation speed.
Posted on Feb 12, 2010
SOURCE: Harman/kardon avr 247 no audio or LED display on the reciever
I've had the exact problem. HK in the states is no help, you need to deal with a company in Montreal (Jan Industries). Regular techs are unable to fix it without schematics that only authorized dealers have and the manufacturer. This problem happened to me just after 2 years and outside warranty. I've bought a Yamaha today.
Posted on Apr 03, 2010
jonsen
  • 62 Answers
SOURCE: harman kardon avr 100 no power
check the fuses it help the power !
Posted on Jun 10, 2010
dunnbiker
  • 8546 Answers
SOURCE: how to connect my eq
The following is some boilerplate I made up that should explain some usage limitations.
Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? They would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up:
Any of the following audio connections on the HK will work: Tape, Vid1 or Vid 2.
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
So, to sum up, you can only use the EQ or any outboard processor for analog stereo sources. If you actually want to use an analog recording deck you could place it within the typical Equalizer
Posted on Feb 04, 2011
LOST REMOTE OF HARMAN KARDON AVR 4550 MODEL
contact the manufacturer at their 800 number perhaps they can help
Apr 08, 2015 | Harman Kardon Audio Players & Recorders
Harman kardon remote codes
https://www.google.com/#q=+Harman+Kardon+AVR+70 This is where I found it.
Nov 27, 2014 | Harman Kardon AVR 70
Need harman kardon avr 132 remote control
where can i repair harman/kardon avr 132 remote in free service
Nov 07, 2012 | Audio Players & Recorders
My Harman/Kardon AVR 140 is stuck on stand by mode
I have the same problem on my AVR 1550 - its been bugging me for ages then it works again, then it doesn't ...
Aug 28, 2009 | Harman Kardon AVR 140 Receiver
Apr 01, 2009 | Harman Multimedia AVR 247 7.1 Channels...
My Harman Kardon AVR 254 is not responding. None
I am having the same problems with my AVR 254, did you find a solution?
Thanks
Mar 15, 2009 | Harman Kardon AVR 325 Receiver
I PURCHASED FROM ABC WAREHOUSE HARMAN/KARDON AVR 340.ITS A FLOOR MODEL SOLD AS IS WITH OUT OWNERS MANUAL AND REMOTE.I REALLY NEEDA OWNERS MANUAL.CAN YOU HELP ME GET ONE?
Harmon Kardon AVR340 just has no sound and it doesn't pass the video through. Looks normal when on. ( Display shows everything is on)
Aug 26, 2008 | Harman Kardon Audio Players & Recorders
250 people viewed this question
 Grubhead
Grubhead
