Question about Acer Computers & Internet
My memory card protective cover is stuck inside the memory card slot. how do I remove it out? my laptop is under warranty & you have no service stations in goa.
    Sergeant:
    Champion:
  • 215 Answers
Hi,No need to worry,i'll ask this can you see the Adapter when you look into the memory card slot?if you do,you will need this item:- Forceps or Tweezers use either of these insert it into the slot make sure you dont push the adapter inside grab the adapter and pull to remove.
Posted on Jan 02, 2011
Bios password for delllatitude d620
You can download the device drivers from Dell WEB site,the support download page. Make sure you select your model desktop or laptop,better still, type in the Service Tag number, it is printed on the label on thebottom of the laptop and on the back or sides of a desktop. (If the Service Taglabel is missing then go into the BIOS setting and on one of the BIOS pages,the Service Tag number will be displayed). This will open the page where thespecific drivers for your model computer are located. Also make sure you selectthe Windows of the drivers for your Windows operating system. Click on thislink to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Nov 12, 2011 | Dell Latitude D620 Notebook
I have a hp pavilion dv5200 and my son got a memory card stuck way in the memory card reader slot. How do I get inside to the memory card reader to remove it.
Hi
The best way you can remove the card is by using a thin tweezers from outside. Try to latch on to the card and pull it out gently. By trying to open the covers first of all you will loose the warranty and there is a possibility of damaging the system itself as it requires previous knowledge of doing it. Try doing things without opening the covers its not worth the risk.
Regards.
PLZ. rate my suggestion.
Jul 19, 2011 | HP Pavilion dv5220 Notebook
How to remove write protection from a sandisk hc memory card
Hello Friend,
  • There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
  • There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
  • The mini sd card has some error: Go for a low level formatting.
  • The card has virus: Remove the virus.
  • Change the Usb Port(Recommend you to Use Backside Port)
  • Change the Cable
  • Restart PC
  • Still have Problem Change Card Reader..
Hope this Helped you..Thanks for Contacting FixYa...........
May 28, 2010 | SanDisk 4GB microSDHC Memory Card
Misc card stuck in slot, how do i get it out ?
1. Shut Down The laptop
2. Remove the laptop Battery ( Close the Lid , turn the laptop Up side down, search for a battery Lock tab, move it to Unlock position, You can see a Lock/Unlock mark on the Laptop cover, this will eject the battery from the slot.
3. Get a tweezers carefully pullout the memory card from the card slot, utmost care should be taken not to damage the card slot contacts
4. After taking out the card put back the battery make sure that it is in the locked position
5. Start the computer , try out the system
6. Verify the memory Card reader functionality using a proper card as per the maker guidelines
Jan 31, 2010 | Toshiba Satellite Pro A210-EZ2203X...
Hello, I cannot find the second memory slot
there is only 1 slot under the bottom cover, the other is under the keyboad
Nov 25, 2009 | HP Compaq nc6220 Notebook
Can only find one memory slot/bay for my Inspiron 1720, correct?
The other slot is under the keyboard. You have to remove the top plate then remove the two screws and lift up the keyboard.
Mar 08, 2009 | Dell Inspiron 2200 Notebook
I would like to install bigger memorie in my latitude c610, how do i access the slots ?
http://support.dell.com/support/edocs/systems/latd600/sm/upgrades.htm#999869
Memory Module, Mini PCI Card, and Modules Dell™ Latitude™ D600 Service Manual
bullet.gif Memory Module
bullet.gif Mini PCI Card
bullet.gif Modules
Memory Module caution.gif CAUTION: Before working inside your Dell™ computer, read the safety instructions in your System Information Guide. caution.gif CAUTION: Toprevent static damage to components inside your computer, dischargestatic electricity from your body before you touch any of yourcomputer's electronic components. You can do so by touching anunpainted metal surface. note.gif NOTE: Memory modules purchased from Dell are covered under your computer warranty.
  1. Follow the instructions in "Preparing to Work Inside the Computer."
  2. Turn the computer over, loosen the captive screw from the memory module cover, and lift the cover.
upgrade7.jpg notice.gif NOTICE: To prevent damage to the memory module connector, do not use tools to spread the inner metal tabs that secure the memory module.
  1. If you are replacing a memory module, remove the existing module.
notice.gif NOTICE: Handle memory modules by their edges, and do not touch the components on a module.
    1. Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    1. Remove the module from the connector.
upgrad10.jpg notice.gif NOTICE: If you need to install memory modules in two connectors, install a memory module in the connector labeled "JDIM (Slot 1)" before you install a module in the connector labeled "JDIM2."
  1. Ground yourself and install the new memory module:
    1. Align the notch in the module with the slot in the center of the connector.
    1. Slide the edge of the module firmly into the connector, and rotate the module down until you feel a click. If you do not feel the click, remove the module and reinstall it.
note.gif NOTE: If the memory module is not installed properly, the computer does not boot. No error message indicates this failure.
  1. Replace the cover and screw.
notice.gif NOTICE: If the memory module cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
  1. Insert the battery into the battery bay, or connect the AC adapter to your computer and an electrical outlet.
  2. Turn on the computer.
As the computer boots, it detects the additional memory and automatically updates the system configuration information.
Dec 30, 2008 | Dell Latitude C610 Notebook
How to install 1GB memory card ??
One slot is under a panel on the bottom of the machine, and the other slot is under the keyboard. Here's a link to the service manual for the 700m, it covers just about everything. If you need any further assistance, just ask.
Aug 19, 2008 | Dell Inspiron 700M Notebook
HI, i AM TRYING TO INSTALL memory in the Acer 5315 laptop and I am having trouble removing the back cover. I already removed the screws. Do you know any tricks? What should I do after I remove the...
did you also remove the screws for the panel that protects that memory? Also, some acers have memory inside under the palm rest..did you check on the actual number of slots and where they are?
better make sure to keep that hardware really handy.
Apr 30, 2008 | Computers & Internet
Memory slots?
I found the solution to roger2 and my own problem. The secondary memory add-on slot is on the bottom of the unit, and can be accessed by removing one screw and the slot cover. The other, main memory slot is actually located underneath the keyboard. You should shut down the computer completely, unplug the power plug, and also remove the laptop battery before installing memory. Also, it may void your warranty if you mess around inside of your laptop, so please keep this in mind. You will need to take a very thin flat head screwdriver to gently pry up the panel above the F1-F12 keys. The panel is the entire plastic piece covering the speakers that has the power on, play, stop, ff, rw buttons on it. I used a very thin and flat hair clip that I found laying around to pry up the edges starting from the Pause/Break key moving left towards the ESC key. The screen lid has to be opened all the way for the piece to be completely removed. Once that is taken off, you will see two small screws holding the keyboard in place. Remove these two screws and gently pull out the thin ribbon cable connecting the keyboard to the laptop. The ribbon cable is located directly underneath the spacebar, so move slowly and carefully when removing the keyboard so as not to damage anything. In the center of the exposed area, there is a sort of rectangular metal cover with two screws holding it in place. The one that is about the same size as the slot cover on the other memory slot is the correct one. Remove the screws and open the metal cover. Underneath is the other memory slot. After you install the other memory stick, if you have 4 GB of total RAM, you should know that in 32-bit operating systems, Windows will only be able to use approximately 3.0-3.5GB of RAM. This is because of a limitation of 32 Bit Windows operating systems, and not because of the RAM itself. Only 64-bit operating systems will be able to use all 4 GB. On my system for example, I have the same Toshiba M105-S3041 laptop as you do, running Windows XP Home with two 2 GB sticks, and My Computer properties shows that I have 2.99 GB memory.
Oct 28, 2007 | Compaq Presario Notebook
Computers & Internet Logo
109 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
