Question about Maytag Neptune MAH7500WH Front Load Washer
Mah7500aww After completing wash cycle, the unit still has water in it. When I turn the rotor by hand, I can hear water sloshing in the unit. Yet the clothes spun out well. Should there there be any water left sitting in the drum after a cycle is completed? Thanks for your help! Phil
  • pwyatt Jul 10, 2008
    Checked siphon possibility and confirmed that is not the source.
    Sergeant:
    Champion:
  • 417 Answers
We Here Have That Same Washer And We Still Have Water Like You Described
Posted on Jul 09, 2008
  • nicholas Rokkasarno
    nicholas Rokkasarno Jul 09, 2008
    Even When We Cleans The Filter We Have The Same Result
    Scholar:
  • 148 Answers
What it sounds like is the drain from your house wher the washing machine drain hose hooks into is daraining slow so after it spins and pumps the water out the pump shuts off but the drain hose is syphoning the water back into the machine,theres probally lint built up in your drain pipe
Standing water under tub in washer
Some washers don't pump out completely during the spin cycle.
Aug 16, 2016 | Samsung 4.8 Cu. Ft. Top Load Washer -...
When I hand turn the drum I still hear water behind the drum please help
You most likely are not hearing water remaining in the tub. You are hearing the water slosh around in the balance ring that is attached to the spin basket. There is a balance ring attached to the spin basket that is half filled with water. When the basket is turned by hand you will hear the water in the balance ring. This is normal.
Mar 24, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune front loading washer, After a complete wash cycle I hear water sloshing in the machine when I open the door and turn the durm. Is water supposed to be in the machine after the cycle...
Yes. The tan/gray colored inner ring attatched to the inner wash tub actually has a calcium chloride solution in it to aid in balancing the machine out during spin. Clothes go to one side, liquid to the other. It's all good. It is sealed so it cannot leak out or create odors.
Hope this answers your question!
Jun 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
WHEN WASH IS COMPLETE, WHEN YOU SPIN THE TUB BY HAND YOU CAN HEAR WATER SLASHING.
The pump cannot completely drain all the water out of washers. There will be some water left in the bottom of the tub that you can't see but here slosh around if you move the basket. If your clothes are not wet, this is probably normal.
Jan 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Solve Your water left in washer.
Check the belt, you shouldn't be able to turn the drum by hand.
Aug 11, 2009 | Washing Machines
Draining neptune washer
The sloshing sounds you hear are supposed to be there. Actually, it was there when you first purchased the washer and had never used it before. It's part of the balance system. When the machine goes into high speed spin, the balance system kicks in. The water portion of it is forced outward by centrifugal force. Now when the machine slows down and stops, the water settles back down so that when you reach in and turn the drum by hand, you can hear it sloshing about.
Hope this helps,
SG
Mar 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't drain completely
water sond when tub is spun by hand is normal. there will always be wa terinside machine betwen tubs, maytag even uses a waterfilled tub ring for counter balance, totlly normal to hear. as far as mildew smells, use www.affresh.com
Apr 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water left in barrel (not the tumbler)
If you can't see any water and just hear it, this is completely normal. This is a front load washer and has a special cover of the inner tub basket. This cover contains some water that has been sealed in at the factory to keep the load balanced while it is spinning.
Nov 25, 2006 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH7500WH Front Load Washer Logo
201 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
