Question about Watches
Watch needs new battery - Watches
    President:
  • 2,501 Answers
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for
the small cost saving in doing it yourself.
Posted on Jan 02, 2011
Watch has stopped how can I restart it
What brand of watch? Does it need a new battery?
If it is an expensive watch take it to the retailer.
May 15, 2017 | Watches
Need new battery, last owner took original battery out.
Take Watch to Watch shop for them to fit new battery .. As you don't have original battery in your watch, you would not what type to buy if you wanted to fit it yourself.
Mar 13, 2015 | Fossil Watches
What's the proper battery for my Gucci 6400L?
Ensure the watch battery is dead. A Gucci watch is not exactly a cheap trinket, thus the battery should have a fairly long lifespan before requiring a replacement. Once you see the hands of time stop on the face of your luxury item, you can be sure it is time to purhase a new battery. The typical cost for a new battery starts at $50. There are three categories for a Gucci watch: Automatic watches, quartz watches, and bracelet watches. Depending on the type, you will need a battery that suits one of these classifications. Batteries for Gucci watches can usually be obtained on any discount/surplus website (e.g. eBay, batteryright.com, or the actual Gucci store).
Read more : http://www.ehow.com/how_4966607_change-gucci-watch-battery.html
Jul 03, 2014 | Watches
Why would a tissot t-touch need an overhaul to replace a dead battery
These babies are notorious for going down the tubes with a battery change. I bet if you get it back it won't work with a new battery. Twice I have replaced batteries and the watch didn't work when I finished. One of them was my own watch, I think $450 is about half the price of a new watch and that is sad. Cool watch just not very long life
Oct 01, 2012 | Tissot T-Touch T33759851
Elini New Yorker stopped running. could it need a battery? Where can I take it?
Yes, normally if a watch stopped running it needs a new battery. Well, you can bring it to the nearest watch shop in your area.
Sep 17, 2011 | Elini New Yorker Grand Chronograph Red...
Have fitted a new battery but no joy, any tips I can try?
mcdevito75 here, Some quartz watches and I believe Citizen is on of which need the exact factory number battery installed / replaced. if you did use the exact battery number and the new battery is not working, remove the battery and carefully clean the battery contacts with a Q-tip and rubbibg alchohol do not soak the battery contacts just clean them. Also your new battery could be dead, who knows how long it was on the store shelf. Alaso wipe off any oil from your fingers on the new battery before you install it in the watch, make sure the battery is seated correctly in the watch, the back cover may also have to be installed back onto the watch to complete the battery circut for the watch to work. If all this fails you can try to contact Citizen online, Contact CitizenWatch.com and get their recommended battery size for your watch, OR, look for a small watch repair shop in your area. One Last thing, Your Citizen watches Quartz mechanism could also have gone bad, in this case you"ll need a new watch.
Feb 11, 2011 | Citizen Watches
Second hand moving in 4 second increments instead of 1 second clicks. Does this mean it needs service or just a new battery?
This means it needs a new battery. But if your watch is about 5 years old it is best to have it serviced. The oils in the movement will be drying out and this causes the gear train to require more power from the battery to make it move. By drawing more power from the battery, the battery will not last as long. This shortening of the battery life continues until the watch is serviced or eventually a new battery will not get the watch to run.
All watches require regular service to stay working properly.
Hope this helps,
Ken
www.YellowStoneWatch.com
Apr 10, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
New battery needed and fitted to a Polar heart rate monitor
This is really easy to do yourself. Get a CR1632 battery, unscrew the four screws on the back (dont tip the watch as there is a small spring in the watch), unclip the metal band holding in the old battery noting the way 'round the battery is in (minus side up), pop in new battery and push clip back down, when re-fitting the back make sure the spring mentioned earlier lines up with the white sticker with a hole in it on the inside of the watch back, screw down the back. After you have re done all your settings you may need to re-aquaint the watch with the strap, to do this put on the watch and strap, set the heart monitoring going, bring the watch up close to the 'Polar' logo on the chest strap until the time is displayed, should now be all set up.
Andy
Oct 28, 2009 | Polar F4 Heart Rate Monitor Watch
Battery Replacement
I thought you are supposed to touch the neg side of the battery
Jun 01, 2008 | Casio DBC1501 Wrist Watch
Have timex watch had battery replaced and watch quit working, she had to use clamp device to instal battery
If you had the battery replaced, I'm guessing that the watch wasn't working when you brought it in for a new battery. It may not have needed a new battery. You might need a new watch. I've never heard of anyone needing a clamp for a Timex digital watch. In my experience, they use phillips screws to hold the back to the case. I have a case press for snap-on backs, but that's still unusual for a Timex unless it has a BIG case. I think your watch was shot before you replaced the battery.
Apr 26, 2008 | Casio Atomic-Solar Watch GW300
Watches Logo
23 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
