Question about Grundig 15 in. LCD TV/DVD Combo
Grundig TV/DVD Combo 1904 flat screen TV. When I turn on the TV instead of getting a blue light and the screen comming on i just get a blue flashing light and a blank screen with not sound.
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: No sound on a 21in
Hi.
Using AV entry ensure that the red/white leads have been connected properly to TV Audio input. SCART is supposed to have built in sound. Test using a different scart.
Try disconnecting power cord for fifteen minutes, that will discharge internal component and reset the TV. Double check audio settings just in case.
If all that does not help, then the problem is likely the sound circuit inside TV. In this case the audio circuit is built-in the main board. Usually with the 19'' LCD TVs you need to replace the main board. Parts for this model are not available from third party distributors. In case the TV is defective, I suggest calling the Grundig number listed on your owners manual to arrange repair or to check part availability. To find contacts you can also use the 'International' tab on top of this page:Welcome to Grundig.
Regards.
Ginko.
Posted on Apr 11, 2011
caroldon
  • 17130 Answers
SOURCE: i have a Grundig XENTIA 82 FLAT MFW 82-430/8 TV,
If this is happening on all the channels I think you will need a total reset. If so open menu and check the settings for child lock when you manually tune. An option is to reset the channels once again after the lock is opened. Choose a new channel scan to reset the memory. However if the lock seems to be only on specified channels you can open the settings of the channel and unlock on the menu.
Posted on Oct 17, 2011
Why does grundig tv have a blue screen ?
It's not detecting a proper input. You will have to tell it what input to use most likely, or it is bad.
Nov 28, 2015 | Grundig Televison & Video
Grundig gu19wdvd10
Flashing of power light indicates a n internal circuit fault. A continuous flash might have due to the block of it SCL-SDA bus, and is related to its main digital board. If you wish to get some more details about the blinking codes, check the site linked here. It has details about blinking codes to many brand TVs, including Grundig. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
Jul 20, 2013 | Televison & Video
Grundig elegance 72 flat screen problem
sounds like frame collapse check out repair costs as can be rather expensive
Dec 01, 2012 | Grundig Televison & Video
A line has appeared across the bottom of the screen and also along the middle. the bottom line is white/red.blue and the middle line is mainly green
If your TV is still under guarantee then change it asap, if not you have a problem, the panel has failed, in very rare cases the lines will disappear when the set is at its maximum operating temperature, that said it will never be 100% again, sorry
Apr 19, 2010 | Grundig GU26DVD 26 in. LCD TV/DVD Combo
My grundig lcd vision32lxw82-8510 has sound but no picture this problem is intermitant can you help? Thanks
If the screen goes completely black but still have sound then the backlight inverter board may be going out.
Oct 31, 2009 | Grundig 15 in. LCD TV/DVD Combo
Portable Grundig TV/vcr combo - screen goes blue and then set switches off.
Hi mcloud Your problem is your video circuit.the component could be faulty or it has lose solder.have a tech look on your set for repairs.good luck.
Apr 25, 2007 | Grundig GF70-600 TV
Grundig 15 in. LCD TV/DVD Combo Logo
78 people viewed this question
Top Grundig Televison & Video Experts
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
