Question about Sony BRAVIA DAVHDX58 Theater System
I m having sony home theater Dav ? dz590M when setting with internet only 2 speakers working rest 4 not working and when using by CD/DVD 01 speaker is not working.
SOURCE: Sony BRAVIA DAV-HDX265 Changing the region code
buy a region free player :)
Posted on Mar 17, 2008
petraman7
  • 1175 Answers
SOURCE: how to make sony dav-s300 dvd player multi region
Do you have the manual?
I'd check there first. You'll probably need the remote as well.
Posted on Jul 07, 2008
SOURCE: Sony speaker connectors
Try this guy on eBay who is selling 2 varieties of Sony connectors, plus a ton of others
http://stores.ebay.com/BOGUE-ENGINEERING-GROUP
I'm about to pull the trigger on a set of his 4.2mm connectors for Sony HCD-HDX500 for $26
Posted on Oct 11, 2008
SOURCE: hook up Sony Bravia Home Theater DAV-HDX277WC
Hi....I haven't hooked mine to the TV yet.....building my cabinet now....but I did hook up the components to make sure they worked and just didnt include a TV on it. My S-Air wireless linked up the first time I tried it....I will say this though, the little wireless transceivers blocks you have to plug into the DVD player and the S-Air do not go in like you would think. They actually look like they are upside down when you get them in, and the must snap in very securely. Make sure they dont just LOOK like they are plugged in. Also, dont get em to far away through too many walls, Try linking it sitting right close to the DVD. Also remember the S-Air remote has its own volume control as well as other controls....
I know I wasnt much help but I just got mine and I will be back with more after I try the surround sound on the TV.
Posted on May 03, 2009
SOURCE: Code for making Sony DAV DZ270 region free
HOLA QUE TAL COMO ESTAN ... TENGO UN PROBLEMA CON MI DVD MODELO DAV DZ270 ENCIENDE PERO ME DICE PROTECTOR Y LUEGO PUSH POWER ...Y NO SE QUE HACER .....ME IMAGINO QUE ES PROTECTOR Y NO SE COMO QUITARLO ... ALGUIEN ME PODRA AYUDAR... LE AGRADECERIA MUCHO... GRACIAS
Posted on Oct 18, 2010
My DAVHDX576WF surround system is connected to my TV by HDMI, but I hear no sound. The home theater test/setup is audible, radio is audible, but nothing from the TV
Which direction do you expect audio to be flowing: from or to the TV? The HDMI is an outbound connection for video. Page 71 describes how to enable the DVD AUDIO ONLY if you really want TV speakers to be competing with the DAV.
http://www.retrevo.com/support/Sony-DAV-HDX576-Home-Theater-Systems-manual/id/13756ag215/t/2/
Sep 10, 2011 | Sony BRAVIA® DAV-HDX576WF Theater System...
Hi I have bought a new sony DAV-DZ310 model home theatre.I have connected all the speakers and a woofer.All are working fine except the center speaker.It is not at all working.I have made the connections...
This may not be Dependant on the Music or DVD, but with the setting on the Home Theater system. Try out all the modes - such as 2 Speaker, Multi etc. within the Home Theatre system. In one of the mode only the center speaker works.
Hope this helps. Good Luck.
~SmokinJoe~
May 24, 2011 | Audio Players & Recorders
Sony Home Theater System DAV-HDX277WC - I get sound and video when playing a DVD, but no voices. Tried many different movies. Any suggestions would be appreciated.
Verify that all speakers work for test tones first. The center carries most of the dialog. It's in the manual, as is your symptom (page 101).
May 21, 2011 | Sony BRAVIA® DAV-HDX277WC Theater System...
I have the Sony HDX265 5.1 home theatre system, I moved on 7/1/2010 & lost a few stuff (including the 4 surround speakers). How can I buy just the speakers? Please help!
all you need to do is by a set of new speakers same size and have then wire up to the player they will work just as well almost all speaker oulets sell speaker packs of 2 or 4 or 5
Dec 29, 2010 | Sony BRAVIA DAV-HDX267W Theater System...
I've had my Sony Carousel CD player wiorking with DAV-HDX279W home theater system before. I used the TV/Video mode and it played. Now it doesn't. I can't find any setting that might have changed. ...
make sure the input is set to( analog in) on the stereo --this will enable the red and white jacks----it might have changed to digital which would enable the optical and coax jack--
Sep 05, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
The DVD an CD doesn't work
Check speaker connections and wires and make sure all wires are plugged properly. If problem still exist then unplug speaker one=by-one and test home theater to determine what speaker is causing Protect error.
May 17, 2009 | Sony DAV-C700 System
I can only get 2.1 sound from my Playstation3
optical cable connection in tv is only input and same in receiver it is both inputs.you need to find the right encoding in your receiver mode/set-up
Apr 21, 2009 | Sony DAV-HDX500 System
No sound from our Sony Wireless Home Cinema System
Basic checks first. Have you checked they are connected properly? Maybe used a different cable to check whether the rear cables are faulty? You may just have turned your system to 2.1 surrououn sound by accident or be playing a format that only supports 2.1. Check that in the system menu under dec. mode that if it is set to AFD STD that you are playing a DVD which shows can support 5.1 on the back of its cover. Also try running the setup manually and choosing your speaker configuration. Hope this helps.
Jan 10, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Sony BRAVIA DAVHDX58 Theater System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
